Question about Sony XM-DS1600P5 Car Audio Amplifier
Hello.... i got a sony xm-ds1600p5 monaural amp with subs .... few days ago i took subs out of my trunk ... without disconnecting power and my amp light changed green to red .... i check every wire ... but could not find any shorted circuit ... what do i have to do ?? thank you bye plz email me at kimjongok@hotmail.com
  • 631 Answers
If you disconnect the speaker wires from the speaker terminals on the amp and the amp still goes into protect mode, the amp probably has shorted output transistors. If that's the case, the amp is probably not repairable. The outputs that Sony used were discontinued and there are no other transistors that will work properly (unless some of the newest transistors are compatible).
If it's under warranty, contact Sony. If it's out of warranty, contact one of the authorized Sony service centers to see if they can help. They may have a supply of NOS parts that would work.
Posted on Nov 24, 2008
No power to amp.....all wire connected properly
is protection light coming on when sub is connected? some radios have weak remote that blow out easy..check power on it if power is making it to amp..if its an ANL fuse they can look good but be bad.
Jun 08, 2010 | Sony XM-1502SX Car Audio Amplifier
Power acoustiks amp wont get off protection mode? how do i reset it? please help me i tried everything.
Hello nfox1987,
First you need to determine if the amp is defective or if something else is causing it to go into protection, most often a short in the sub or amp wiring.
Disconnect the sub(s) from the speaker output terminals and the RCA inputs from the head unit, and test if the amp powers up OK. If it does, the problem is in the sub(s) wiring or voice coils, or in the RCA inputs to the amp. Reconnect each one-at-a-time to determine exactly where the short is and repair or replace the defective wiring or unit. If it doesn't power up with the inputs and sub(s) disconnected, the amp itself is most likely defective.
Hope this helps.
Jul 15, 2009 | Sony XM-475GSX Car Audio Amplifier
I have Sony XM-2150GSX amp on offset cant get it off
check for a short on one of the edges or a resistor on the edge of the board
Jul 04, 2009 | Sony XM-2150GSX Car Audio Amplifier
I need a high level input connector for a Sony Car Amplifier
best buy-wal mart-circuit city-ultimate electronics-radio shack- any stereo shop that deals with car audio-hope that helps look to spend between 12 and 35 dollars
Jun 18, 2009 | Sony XM-DS1600P5 Car Audio Amplifier
Xplod XM-DS1600P5 red light
For some reason it has gone into protection mode to limit further damage to the amplifier. Remove the subwoofer wires and power on to eliminate shorted voicecoil. After checking all wires for continuity to ground, a service tech will be required.
Nov 30, 2008 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Power protector light on sony xplode 1000 watt amp
a green light is the power indicator, a red light is when the protector is in affect
May 30, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
No Sound/ lights flashing on Amp
Disconnect your subs from the amp. If the lights go out then your sub is blown and is putting the amp into protect. If the lights keep flashing even with the subs disconnected than the Amp is toast.
Jul 09, 2007 | Sony XM-752EQX Car Audio Amplifier
Amplifier On - No Sub Sound
Are you certain you put the wires back on the amp the exact way they came off. I am not familiar with this amp but most amps if you look at the terminals where the speakers hook up there will be a plus and a minus. And generally there are four terminals. hence stereo plus and minus left and right. Some even have eight for, four channels. Since the amp is on, not getting hot and you tried two different audio inputs I would suspect speaker wiring or maybe the stuff you put in your trunk bumped a switch on the amplifier. I know this is not the exact answer you are probaly looking for but it is at least a place to start
Jan 11, 2007 | Sony XM-DS1300P5 Car Audio Amplifier
Sony XM-DS1600P5 Car Audio Amplifier Logo
100 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
