SOURCE: 72 inch Mitsubishi Big Screen TV Model VS-6043
your power supply " igniter " has gone bad.
have somebody with some electrical expertise to take a look at it, it may be the fuse that is located right after the power connection. i have replaced several of them, if that fuse is ok. the is your coil.
SOURCE: searching for powersource for a 1994 zenith projection TV
CALL 1-800-632-6637 Zenith Parts abd rebuilt Boards.
SOURCE: 72 inch rear projection tv took a power surge last
if ure handy pop the back off and there should be a main power board and a fuse on it, make sure you use the same fuse if it is blown do not stick another type or size in it, put it back together and turn it on if it blows again it will be somthing else if not it should work
SOURCE: old magnavox 52 inch big screen tv - screen rolls, jumps, loses c
the screen on my hdtv has alot of marks on it how do i get another
