Question about Miele Novotronic Premier 500 Front Load Washer
Miele front loader w828
Hi Mr Gizmo, I have the same problem with my Miele W828 front loader. Loads the water and then the rinse light flashes for a while and stops. Then the water is pumped out and the machine stops.
The brushes in the motor are OK.
I think that the problem is in the electronic board which costs A$390 to buy (parts only). I think it may only be a relay on the board (worth a few dollars?) that is faulty. But which one? Any ideas?
The shock absorbers were also not good and the Miele assistance told me on the phone that it is a common problem that when the shocks fail they cause something in the electronic board to fail (vibrations? stop and start to balance load?). Any help welcome
3 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: Miele Novotronic W828 Water Control System Front Load Washer
Hello Ellen, welcome to fixya. I would begin by removing the rear panel and checking the belt and insure the basket pulley isn't loose as well. If the belt is in tack ( not broke ) but has come off that sometimes is caused by a loose or bent pulley, hence the suggestion to check the pulley. If the belt is broke, it may simply be a matter of normal "wear & tear" and just time to replace it. Hope that helps point you in the right direction. Please take a moment and rate this info according to it's helpfulness or let me know if I can assist you further. Thanks for visiting "fixya" today and good luck. Macmarkus :)
Posted on Jun 03, 2010
  • 40 Answers
SOURCE: How to change miele novotronic
Turn the machine off and unplug it! There are 3 10mm bolts around the door that need to be removed, the soap dispensing drawer needs to be taken out and you have 3 torx20 screws (one on the left and 2 on the right) that have to be removed. The bottom left corner of the machine there is a small door that you open, remove the hose that's clipped inside it, there is a small tab on the lower left, release the tab, pull open the door. To take out the seal you have to loosen the 8mm bolt band clamp, and pull the seal off. Fit the new seal on until you hear it pop. and reverse the order.
Hope it works for you.
Posted on Feb 28, 2011
I have a Miele w828. The wash programme stops and the check inlet indicator light is flashing but the stopcock is on ,the hose is not blocked and the filters are clean. What do I do?
If you have water going in to the machine then it is probably a blocked pressure bag.
If no water is going in to the machine then its probably a faulty inlet valve or blocked inlet filter.
Sep 21, 2014 | Washing Machines
There is a bad mould build up on the inside seal of my Miele Novotronic W828, Can you help, the smell is terrible, flows through the house.
You need to wipe the seal down with vinegar. Mold needs water to grow. Have you looked at the bottom of the dishwasher after a cycle to see if you have standing water? While you are looking clean the filter.
Nov 02, 2013 | Miele Dishwashers
Miele W828 Check inlet red light flashing
Just wanted to mention mine was retaining the fabric softener and skiping steps in the cycle and intake red light was flashing too. Once
I cleaned the draw and used a toothbrush to unblock the holes in the ceiling its working again perfectly. Miele Novatronic W 828.
Mar 07, 2013 | Miele Novotronic Premier 500 Front Load...
Flashing rinse light miele novotronic w828
Broken electronic as a result of worn shock absorbers. See www.youfixit.eu
Aug 27, 2012 | Miele Novotronic Premier 500 Front Load...
Rinse light flashes on miele w828
1) the water must be preheated, test the heating element if is defective
2)drain line is clogged proceed to fix it see the diagram
3)some sock must be removed, use plier
4)pump defective, inside with the propeler, replace
5)frozen pulley pump, replace
6)improve the drain, if about 4 inches cut of the diference.
b) if lower , install air/gap siphon break assembly.
God bless you
Jun 25, 2012 | Miele Novotronic Premier 500 Front Load...
Mielepremier novo. No power though plug fuse OK. Door won't open.
I had the same problem with a Miele W828. I removed and reinserted what I think was a condensor where the power cord is attached, after which it was OK. I assumed that it was loose but might have just been lucky in bumping something else back in place when I tipped it onto its side.
Mar 28, 2009 | Miele Novotronic Premier 500 Front Load...
The "Check Inlet" light comes on (Flashes) on my Miele W828 washer often. I have checked the hose for kinks and blockages and all is ok. The problem appears to be rectifiable temporarily by...
The solenoid has a rubber diagphram inside it with tiny holes in it which could be blocked or the diagphram is no longer serviceable and requires replacing. you probably have to replace the solenoid body complete.
Aug 14, 2017 | Miele Washing Machines
Miele w828
Hey you! I want to Miele w828 Final Spin Cycle 1100rpm Part 1/3 of 3/3 Part 1of3/3 of 3. Do you understand? Great Now let get to work.
May 24, 2008 | Washing Machines
Miele Novotronic Premier 500 Front Load Washer Logo
67 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
