Question about Black & Decker 3/8" Variable Speed Reversing Drill Kit" [Misc.]
How to change the drill bit
How do I change the drill bit?
    Scholar:
  • 132 Answers
There is a rippled edge close to the very tip of the drill and there is a key supplied with the drill with the corresponding ripples place key into the hole near tip of drill so ripples meet each other and turn key in an anticlockwise direction to loosen put in new drill bit re tighten in clockwise direction hope this helps if not please ask for more info glenn
Posted on Nov 23, 2008
The bit wont lock in the drill, how do i fix this problem
This is a very easy fix - you have a quick change chuck on this tool. Turn the chuck counter-clockwise and pull it straight off - the new one goes on the same way. Quick Change Bit Chuck
May 23, 2014 | Bosch 11236VS Rotary Hammer
I can't loosen the the sleeve that holds the bit and therefore I can't change my bits.
Stick the speed fix to 1, put drill in reverse, and hold on to the chuck as hard as you can, and squeeze the trigger.
Jun 07, 2012 | Makita 12 Volt Cordless Drill/Driver Kit
How do I change the drill bits and then tighten so the bits stay in the drill?
The chuck will not turn. So to loosen just turn the black plastic counter clockwise. The chuck will loosen. Or you can hold the black part on the chuck tight and put the drill in reverse and slowly squeeze the trigger and the chuck will loosen also. Do the opposite to put a new bit in. Put the drill in forward and hold the black part of the chuck and squeeze the trigger with the bit in place and it will tighten down on the bit.
Dec 16, 2010 | Dewalt 18 Volt Compact Drill Kit
How do I change a bit
This drill uses a keyless chuck. which means you have to hold onto the barrel by the end of the drill chuck. Then you need to put the drill in reverse to open the chuck to put a bit in. Insert a bit and then put the drill back into forward and hold chuck to tighten.
Nov 14, 2010 | Milwaukee Tool Milwaukee 0824 24 v18...
Changing Bit
where the bit goes into the drill there is a metal ring. Pull the metal ring away from the drill with one hand and pull the bit out. this model you may have to pull the meteal ring twards the body of the drill.
Feb 26, 2010 | Makita 9.6v Cordless Impact Driver 6903VD
How do I change the bit on makita 6095d The drill bit is on right now and I simply want to change it to the phillips screwdriver bit. Thanks
have you opened up the chuck to remove the drill ? If not then you need to by holding the chuck tightly with your hand and then run the drill in reverse. hope this helps you
Oct 05, 2009 | Makita Drills
Keyless Chuck how do you change the bit? Model
hold outside collar on chuck firmly with your hand and reverse drill
Jul 10, 2009 | Black & Decker 3/8" Variable Speed...
Getting a small drill bit in straight and tight
I would replace the chuck or purchase a 1/16" quick change drill bit.
Apr 04, 2009 | Ryobi 3-piece 18V Drill / Circular Saw /...
Black & Decker 3/8" Variable Speed Reversing Drill Kit" [Misc.] Logo
691 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
