Question about Crown XTi 2000 2-Channel Amplifier
Amp cuts off
I have a crown xti2000 when you first turn it on it works fine after afew mintues of use it cuts off. it dosent shut the power off the lightblinks
  • Anonymous Mar 28, 2009
    on off
  • chetocheto Mar 28, 2009
    when i turn on the xti2000 it show in and out the power
Ok, i have the same proble, what i found until now is the fan is not starting and that allows heat increase,
i conect direct to a 24vcd power supply,
i hope you have the same prblem
Posted on Mar 11, 2009
  • 2,992 Answers
The amplifier is going into protection. This may be caused by problems with speakers or wiring, or there may be internal problems in the amplifier. Start by connecting a known good speaker with a few feet of wire, and see if it runs without shutting down. If so, check the wiring and speakers. If the problem continues, the amp should be serviced.
Posted on Nov 23, 2008
My crown vid 4000 amplifier doesn't work.after switching power it goes off after maybe 2 speaker and input during powering. Same thing happen even there is speaker and input connected
Check speaker to power bank protection circuit. The circuit is faulty indicating to the power amp that speakers are disconnected that shuts down the amp to protect the unit
Mar 10, 2015 | Crown Audio Players & Recorders
When i have the stereo on radio my amp/subs work fine, but as soon as i switch the mode to USB ( built in ipod connector) it cuts out the power to the amp/subs. It only works on tuner mode (radio) why?
use the blue/white wire (amplifier remote turn on) instead of the blue wire (power antenna remote turn on) to turn your amp on. the power antenna wire shuts off when leaving tuner mode.
Mar 02, 2011 | Sony DSX-S100 Car CD/ MP3 Player
1992 ford crown vic working fine, next day no power to fuel pump or cut off switch
  1. Hi Domino, The fuel shut off is powered by the fuel pump relay (which is in the engine compartment fuse block) the fuel pump relay is powered by the EEC power relay(PCM relay) you will have to check for distribution and voltage. I hope this helps!
Aug 31, 2010 | 1992 Ford Crown Victoria
I have a crown k2 amp that I think Have have fed bad signal, a result of having a pet chew through some of the input and output cables. Immediately, it showed erratic warning light displays, and the audio...
Check the gain control in front panel. The material use inside them is pretty thin and weak, an could break loose when hurting during manipulation.
Spider Guy
Mar 13, 2010 | Crown CE2000 2-Channel Amplifier
Amp cuts off
sounds like you are overheating the amp, if the amp has a fan to cool it off, make sure it is turning on and working... if it is not then replace the fan to fix the problem...also turn the amp gain down a little bit and try running it again and see if it still shuts off...if it doesn't shut off then you have teh gain to high and are cutting out the amp with to much power going thru it...
Jun 13, 2009 | JBL BP300.1 PowerValve Series Car Audio...
Amp over heating and cutting off
sounds like the Impedance of the speakers does not match that of the amp, therefore the output stage of the amp is trying to compensate, driving the amps too hard and eventually causing the thermal cut out to activate. Check the ratings on everything are compatible before you start sending it off to be fixed.
Mar 22, 2009 | Pyramid PB736GX Car Audio Amplifier
Crown xti2000 cuts off
The protection circuit is most likely shutting down the amp because of heat. When the amp shuts down, does it feel hot? If not, then further investigation into the protection circuit will be necessary. This is not a problem that is likely to be diagnosed remotely as measurements will be required internally once the amp has stopped working. Check the sepaker wires for shorts that will cause the amp to work extra hard (generating extra heat). Other than that, you will need a servicer to diagnose further.
Nov 23, 2008 | Crown XTi 2000 2-Channel Amplifier
your amp may be overheating, or you have it up too loud and the surge protector is shutting it of in fear of damage to your amp.
Apr 24, 2008 | Kenwood KAC-7202 Car Audio Amplifier
Start removing wires from the amp, one by one (except for the +12V, Ground, and remote) until the amp seems to work fine. Usually, this type of issue is due to a speaker wire shorting to something it shouldn't be touching. Check the "non-amp" end of all the wiring to make sure they are solid and correct.
Apr 04, 2008 | Volfenhag ZX-8300 Car Audio Amplifier
Crown XTi 2000 2-Channel Amplifier Logo
392 people viewed this question
Top Crown Audio Players & Recorders Experts
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
