Question about TruTech PLV16320 Television
TV won't playback DVD-RW Disc recorded on another TV.
We have a 21" (I think-measured diagionally across TV) TruTech TV with a built in DVD player.  I am trying to play a DVD-RW Disc recorded on anther DVD player. I get a "wrong disc" message on my TruTech TV when I try this. Why won't the recorded disc play on the TV?
    President:
  • 814 Answers
You can try calling TruTech customer service for technical assistance at these telephone numbers. 1-888-252-6252 and 1-800-252-6123. They should be able to answer all your questions about the type of DVD's you can use with your television. I hope this helps you with your problem.
Posted on May 17, 2009
    Genius:
  • 1,199 Answers
THE PLAYER IN THIS MODEL DOES NOT READ DVD+ OR DVD- OR DVD RW DISKS ITS NOT GOING TO HAPPEN! CHEAP PLAYER INSIDE WILL ONLY PLAY STORE BOUGHT DVDS
Posted on Dec 07, 2008
SOURCE:
Model DMR-ES30VEB. I have had this recorder for a few years now but since I got a new Sony TV at christmas I am having problems recording. When I record a programme the DVD says it does not recognise the...
DVD-RW discs are ideal for temporary video recording and data backup, but they are not recommended for successful finalising, as there is no guarantee that the disc will work in another device.
Have you tried using DVD-R discs? these CAN be recorded in video mode AND finalised for compatible playback in other players. I assume the DMR-ES30V is a DVD/VCR combo unit - if so, the DVD recorder will not recognise RW discs; only DVD-RAM and DVD-R.
DVD-R discs are recommended for video recording and finalising in this model. (later model Panasonic DVD recorders allow RW disc recording).
Mar 26, 2011 | Panasonic DMR-ES30VEBS
Playback on recorded disk
The DVD has burned incorrectly and the data has likely corrupted somewhat to the point where the DVD player/writer can't read it. You may be able to watch it on your computer with a DVD drive. Try saving it to your computer, then erasing the disc and trying to record something short to it and play it back - if it plays back, it's likely to have been a recording problem, however, if you get the same problem, it may be a dodgy disc, a faulty DVD player/writer, or a format problem. Try this, in order left to right. Copy DVD to PC -> Erase DVD -> Record on DVD from TV -> Play back If plays back Erase DVD -> Continue as normal If not Buy DVD-RW (emphasis on the minus) -> Try using that If that works continue as normal, otherwise... Return the DVD player/writer under warranty for repair/replacement.
Sep 17, 2007 | iLO DVDR04
Can't delete recorded programmes from a DVD-RW disc. Also, the wording on the t.v. screen is not the same as shown in the Owners Manual when I use the remote controller.
U can't deleting the recording matrials in the DVD+RW disc.U only can recorded over it with new recording matrials over the old materials.What do u mean?Diffreence lanuages from the tv screen not in english or ur own country lanauge?
Oct 27, 2010 | Funai TruTech DVDVCR Dual Recorder
I transferred some pictures from my computer on a Maxell RW disc. When I played the disc on my Funai DVD/VHS Dual recorder model DRV-2737 no picture appeared on TV screen. What could be the problem? On the...
sorry...it seem like your dvd/vhs player is outdated...(do the rw disc plays in pc?) are you using Nero software? this will curve the problem...or try another DVD RW brand that funai is compatible with...dvd players, dvd recorder and pc dvd burners do roll back...all must be a year or less apart to work with each other....
May 26, 2010 | Funai PY90VG DVD Player/VCR
My JVC DVD recorder is refusing to playback one of my PHILIPS DVD-RW discs notwithstanding I have rec orded material on to it from the TV. The player is rejecting this particular disc coupled with a...
Did you record the disc on this DVR? Does it play in other DVD Players?.Try cleaning the disk with a soft cloth.Some DVR and Discs are not compatible.Good Luck.
Sep 05, 2009 | Televison & Video
Recorded movie on dvd-rw will not play on another player
the best format to buy is the DVD-R but make sure your disc has been finalised if you reinsert your disc on the functions screen you should see finalise this is essential for compatible playback hope this helps regards Jim
Mar 26, 2009 | Televison & Video
No disc
with these types of DVD RECORDER unit ,you have to purchase a specific DVD+RW brand so the system can accepted . I have this problem once , I ended returning the unit and getting a DVD RECORDER that will be compatible for all DVD players . Like the PANASONIC DMR-EZ27 ,hope this info helps you.
Apr 26, 2008 | TruTech TT1620 DVD Recorder
How to burn a dvd from a JVC Hard disk drive recorder
Make sure you plug your camcorder into the in on the dvd recorder. Make sure the dvd recorder is set to that input. you may need to hook it up to a tv and make sure you see your camera on the tv going through the dvd recorded to make sure you have it on the right setting. Make sure you camera has playback out turned on.
Jan 21, 2008 | TruTech T650-DR DVD Recorder
Can't record DVDs
OK. Finally "solved" this problem. You must use the brand name "Maxell" DVD disks, 2x or 4x (maybe 8x). Do not use variable speed disks (e.g. 1x--4x) or 16x. Walmart carries these!
The DVR -RW 2x finally got mine to record. I didn't think this would work, but it did. I am still experimenting with it. Had to download (free) VLC player to get it to play on my computer. Works fine in other DVD players.
Credits to the Sears' repairman, the guy at F., and my patience!
Oct 24, 2006 | Sylvania SREC427 27 in. TV/VCR/DVD Combo
TruTech PLV16320 Television Logo
134 people viewed this question
Top TruTech Televison & Video Experts
Steve Allison
Steve Allison
Joaquim Martins
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
