Question about RCA RT2500 System
No Connection to Some of the Speakers...
Hello: I have had this system for five years and this is my first problem with it. Help! :) The front left & right speakers seem to be working but the back left, right, center speaker and sub woofer will not come on-line. It shows them on the front panel of the receiver (glowing red) but they do not have a white outline around then like the front left & right speakers do. When I put in a DVD it picks it up as 5.1 but it will only come through the front speakers. I've checked the speaker wires and everything looks connected. Any ideas? Thanks for the help! Bria :)
Solved Problem! Hold down test/setup for 2 seconds, then cycle through and add each speaker back into the setup. Happened to me, it must have reset somehow. That's how you fix it!
Posted on Jun 10, 2007
Please tell me all the connections on movie star 60+
Each of the five satellite speakers connect directly to an AV Receiver that you buy a separate device.
Here's the back of the sub. The sub either connects to the LFE Sub Out from the receiver to the white RCA/Phono Left Input. Or you can use speaker connection cables, AV Receiver front L & R to Speaker Level Inputs, and then Speaker Level Outputs to the front satellite speakers.
Aug 16, 2014 | Wharfedale Audio Players & Recorders
Tip
How to set up a seven-speaker home theater system
Set up a home theater
How to connect your speakers
In order to deliver surround sound, home theater systems require 5, 6, or even 7 speakers--and that's not even counting the subwoofer. Connecting all those speakers together can be quite a challenge, so here's a quick overview of the basics.
If you don't have an all-in-one, home-theater-in-a-box system, you'll probably need to supply your own speaker cables. There are several different types available--they vary in terms of wire size (or gauges) and termination types. Make sure you pick cable that's a good match for your speakers and receiver. And make sure they're long enough; the rear-channel cables in particular will be stretching all the way around the room.
Once you've selected your system and have all your speakers ready to set up, begin by placing each speaker at or near its intended location. Then, attach the cables to them one by one. After securely fastening one end of the cable to the speaker, connect the other end to the appropriate speaker output on the back of the A/V receiver. Be sure to connect the cable to the correctly labeled output.
For instance, the front-right speaker wire needs to go to the terminal labeled front-right. Also, make sure that each speaker connection is in phase, meaning negative to negative and positive to positive. Otherwise, your system's sound will sound out of whack. Repeat the process for every speaker in your system. Note that the subwoofer uses a coaxial-style RCA cable instead of standard speaker wire.
Once all the wires are connected, you should test the system with several DVDs and CDs, to ensure that everything is in working order.
For our first example, we used an elaborate 7.1-channel system, so it may have 1, 2, or several more speakers than your system. Some systems even employ wireless rear speakers, or virtual surround-surround modes that simulate multichannel experience from 3, 2, or even 1 speaker. And some listeners still prefer good old stereo sound from 2 speakers. No matter what type of speaker setup you prefer, however, the wiring basics remain the same.
How to position surround-sound speakers and a subwoofer
To get the best performance from a surround-sound speaker system, you must install each speaker in the correct location. There are three basic types of surround-sound speaker systems.
  • The 5.1-channel system has five satellite speakers and a subwoofer.
  • 6.1-channel systems have six satellites and a subwoofer.
  • And 7.1-channel systems have seven satellites and a subwoofer.
Start by placing the center speaker either directly above or directly below your TV. The center speaker can be perched atop a direct-view TV or mounted on the wall. Aim the center speaker at ear level.
In most cases, the front-left and front-right speakers can be wall mounted or placed on stands. However, if your speakers have rear-panel bass ports, they should not be wall mounted. Space your front-left and front-right speakers the same distance apart as the distance between your center speaker and your listening position. Position the front-left and front-right speakers no more than two feet above or below the front-center speaker. The tweeters in the front-left and front-right speakers should be roughly at ear level relative to your seating position.
Ideally, the surround-left and surround-right speakers should be mounted on the side walls of your room, slightly behind or parallel to your listening position. If your speakers have rear-panel bass ports, place them on stands instead. If installing the speakers on the side walls isn't practical, you can mount them on the room's rear wall or place them on stands behind your listening position. The surround speakers can be installed up to two feet above the front speakers.
Also, 6.1 surround systems have a back-center speaker. You'll typically mount this on the rear wall of your room, centered behind your seating position. Position the back-center speaker no more than six feet behind the surround-left and surround-right speakers. If your speaker has a rear-panel bass port or if the rear wall is too far behind your seating position, place the back center speaker on a stand instead. The back-center speaker should be installed at the same height as the surround-left and surround-right speakers.
Instead of a single back speaker, 7.1 surround systems use a back-left and a back-right speaker. These, too, are typically mounted on the rear wall of your room. Position the back-left and back-right speakers so that each is approximately aligned with the left and right edges of your listening position. Place the back-left and back-right speakers no more than six feet behind the surround-left and surround-right speakers. If your speakers have rear-panel bass ports,or if the rear wall is too far behind your seating position, place the speakers on stands instead. Install the back-left and back-right speakers at the same height as the surround-left and surround-right speakers.
A subwoofer is the last component of a 5, 6, or 7.1 system. Because bass frequencies are nondirectional, you can place the subwoofer in various locations. You may get the best performance by installing the subwoofer in the front of the room, approximately six inches from the wall. If you want more bass, try placing the sub near a corner in the front of the room.
Connect your DVD player to your A/V receiver--digitally
To hear a movie's soundtrack in surround sound, you must first connect your DVD player to an A/V surround-sound receiver. You'll need to make what is called a multi-channel-compatible connection.
The easiest way to do this is to use a cable that carries a digital signal. There are two digital options: optical and coaxial.
An optical digital connection, also called TosLink, uses pulses of light to deliver a digital signal. According to some experts, one advantage of optical digital connections is that optical cables don't pick up noise, while lower-quality coaxial cables can. Many, but not all, DVD players have an optical output. Most A/V receivers have at least one and usually multiple optical inputs. Plug one end of the optical cable into the DVDs player's optical-out jack. Plug the other end into the receiver's optical input.
Finally, you need to tell your receiver to use the optical connection whenever you switch to the DVD input. This is called assigning the input. Information about this simple process can be found in your A/V receiver's manual.
A second option is a coaxial digital connection. This type of connection is also used for cable TV, but the connectors are different. This type of coaxial cable has an RCA connector. Coaxial cables are less expensive than optical ones. In fact, you can use any old RCA cable to make a coaxial digital connection, and you won't lose any audio quality.
Most, but not all, DVD players, have a coaxial output. Some have coaxial and optical outputs, so you get a choice. Audiophiles argue over which connection is better, but it's very hard to hear the difference. Most A/V receivers have at least one and usually multiple coaxial inputs. Plug one end of the coaxial cable into the DVD player's coaxial-out jack. Plug the other end into the receiver's coaxial input.
Finally, tell your receiver to use the coaxial connection whenever you switch to the DVD input. Again, your A/V receiver's manual will have instructions for assigning an input.
on Aug 13, 2010 | Audio Players & Recorders
My door speakers wont play but my box does
Hello
Check the speakers first. Then check the wiring. There are Front Right, Front Left, Rear Right, Rear left speakers and supply, antenna, etc are connected by one pin to a socket. Check this pin&socket for rigid connection. Unplug and replug it two or more times, so that if there is any loose contacts with this socket and pin connections will be rectified. If this does not help you, check the internal connection of this socket, This is actually a skilled work, you have to open your player. The fault is surely with this socket and pin connections itself. Work out with concentration. Check the door speakers first before doint anything further. If you fail to detect the fault, let it retified by any auto-electrician. No internal circuit fault to this set is there. OK.
Sep 03, 2011 | Kenwood KDC-519 CD Player
WHAT SHOULD I DO THREE OF MY SPEAKERS DOES NOT ON TWO REAR L-R AND THE CENTER I PLUG IN THE BLURAY PLAYER AND FROM THERE USE MY HDMI FROM THE BLURAY PLAYER TO THE HDMI ON THE SAMSUNG FLATSCREEN TV ANYONE ...
Hello there,
It sounds like everything is working correctly to me. Voices / spoken dialogue should mostly be from the front speakers and surround audio (music, effects, etc) from all speakers.
The TV screen is in front of you so the people on the TV screen are also (technically) in front of you. Naturally, I would expect the spoken dialogue to come from the front speakers only - except in some instances, where dialogue in the movie is from a character not currently on screen. If you had voices from both in front of and behind you when the characters are only in front of you, it would be totally disorientating.
If you have audio from all five speakers during a movie then all of your connections and settings are correct. The problem you are describing is really just a description of how surround sound works.
I hope this helps. If I misunderstood the question or the problem, please let me know.
Regards,
BElectric.
Mar 08, 2011 | Samsung Audio Players & Recorders
How to plug speakers up to amp
Depending on what system you have the answer could be different. I see a theatre system on screen so I will address that. You should have five speakers and an amplified woofer. Two speakers get connecte to the front left and right connections. This used to be standard stereo. Two speakers get hooked up to rear left and right. Keep in mind that they are talking about left and right from the listeners perspective. The final speaker gets hooked up to the center connection and should be placed on top of the viewing unit. The subwoofer should be connected to the subwoofer port and placed to the right of the screen from the viewers perspective. Hope this helps. Let me know.
hardrocko
Thanks for using FixYa
Feb 12, 2010 | Sony DAV-S300 System
Subwoofer outputs not functioning
Have a good look at your set up in regards to volume output to each channels .
you may have only one channel working due to volume turn down or a faulty connection from the console head unit .
After going through all these , i would suggest to get your sub amp checked as you may have a faulty amp .
Sep 28, 2009 | Bose Acoustimass 15 System
Volume dial not working
i would recommend you ask logitech if they can fix it, if the cost is too high i would go look for other stores that fix speakers, if it still cant be fixed, your better off buying new ones because having speakers like those for 5 years is a long time, it may just be time to change
Feb 08, 2009 | Audio Players & Recorders
Connect DVD Player to logitech X 540 Surround System
Bad connection on that one speaker, if you have tested the system with other equipment and it works thn you MUST have a bad connection INSIDE you DVD player. If your DVD had a whole channel out on your output amplifier I beleive then 2 speakers would not work so more than likely you have a bad solder joint inside system for DVD output
Feb 11, 2008 | Logitech X-540 Computer Speakers
One speaker is lower volume than others - right front
I think that maybe you setted the distance of the speakers wrong. Check your users manual and try to adjust the distance.
Nov 17, 2007 | Sony STR-DE597 Receiver
Fornt speakers does not have any sound.
remove the front speakers cables from the rear-remove surround speaker cables from the rear and put them in the place of front speaker-run a music if you get good sound the problem in your front speakers(speaker or its cable)-if you got nothing you will have a problem in your system itself and need to fix in service center.
Aug 29, 2007 | Panasonic SC-HT930 System
RCA RT2500 System Logo
161 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
