Question about Desa International ALL-PRO® SPC-85 Utility Heater
Misfiring Master Heater
I have A Master heater B99 deluxe. after it run for a fe minutes it misfires. i have changed the plug.it only misfires for a second.I also have checked the fuel line and pump. it seems to be an ignition problem
  • 232 Answers
Check:
  1. water droplets in the fuel tank
  2. transformer not grounded good
  3. restricted fuel filter- causing starvation
  4. air pump pressure not correct
Posted on Nov 23, 2008
  • Dewey Newbury Jan 09, 2012
    I had the same trouble it was the high-tension (voltage) line was shorting to ground. Once I insulated the line, it stopped misfiring.
ENGINE LIGHT ON CODES P0141 & P0144
code p 0141 refers to heated oxygen sensor (HO2S) 2 bank 1--heater control--circuit malfunction===causes --wiring---HO2S--- ECM
code p 0144 refers to heated oxygen sensor(HO2S) 3 bank 1--high voltage ===causes wiring short to positive ---HO2S---ECM
also refers to oxygen sensor(O2S) 3 bank 1--high voltage ===causes wiring short to positive---O2S-- ECM
HO2S sensors are the units in the exhaust manifolds or before the cat converters
O2 sensors are after the cat converter
two completely different operations
use the special tool for sensors as the wires are easily damaged from the wrong tool use
as for misfiring you will get a P0300 (0300,0301,0302,0303 etc) depending on which cylinders are misfiring
when checking for misfiring the injectors , (blocked or not firing) are as important as plugs and wires
If the misfiring continues after sensor replacement , replace the ECM with a known good one as it is common to all fault codes and misfiring
Jun 06, 2016 | 2005 Hummer H2 SUV
I HAVE A 170 REDDY HEATER THAT RUNS FOR APP.10 MINUTES AND QUITS BLOWING OUT BLACK SMOKE I HAVE CHANGED FILTERS AND CHECKED PRESSURE WAS AT6. PSI CAN YOU GIVE ME ANY HINTS
sounds like you have dirt in your fuel tank, as the heater runas it picks up the dirt in the filter plugging it up. When the heater shuts off, the dirt falls out of the filter. You start the heater back up and it does it all over again. Empty your tank and change the fuel filter. Should be fine then.
Feb 21, 2013 | Reddy Heater-170,000 BTU Kerosene Deluxe
Obd 2 scan reading said engine misfire, bad plug. I changed all the plugs, and the position 1 O2 sensor. check engine light is still flashing........What else could it be? Confused in Teeterville
the spark plugs that you changed, evidently 1 of them was misfiring , according to the computer, and the engine since it was misfiring, made the engine run rich, there fore you said that you changed the o2 sensor, so just make sure that you have the o2 sensor connection is connected good, then take your ob 2 tester, and remove the light, it should go out and stay out, if your tester is not equipped to remove the light, then disconnect the positive battery cable for about 1 minute, then reconnect it, but you will most likely have to reset your vehicles clock, and maybe some radio functions, also if the light comes back on again, check the plug wire that goes to the cylinder of the one that was misfiring, hope that is has helped you.
Apr 18, 2011 | Oldsmobile Intrigue Cars & Trucks
Ferguson tractor misfiring
fe 35 23c engine,the diesel feed pipe to the heater plug still drips fuel in the inlet manifold when runnig causing it to splutter is this normal.
Jan 16, 2011 | RTO Massey-Ferguson Tractor TE20, TO20,...
My Santa Fe runs rough to
do a compression check, its possible this is a mechanical failure.
Sep 17, 2009 | 2004 Hyundai Santa Fe
Misfiring after replaceing starter
check clamps where heater hoses go to firewall there was an issue with coolant leaking onto ignition components causing misfiring
Jul 23, 2009 | Ford F-150 Cars & Trucks
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Desa International ALL-PRO® SPC-85 Utility Heater Logo
153 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
