I left it running and closed my laptop cover when i went to sleep for a few hours,now its not "Resuming Windows",which it usually did. Now its stuck in "Hibernate Mode". I tried to shut it down and reboot,I tried gently tapping on the keys and cursor panel,I checked my battery power and that is fine. I'm stuck on the Blue screen in Hibernate Mode and I cannot access anything! Not even my control panel,I am not real computer savvy either,so please help!
You may find this helpful try it soon and let me know if it works
click here
SOURCE: Screen stays black after laptop comes back up from hibernation
Its software,, format and reinstall windows
SOURCE: Toshiba Satellite A135-S2276... went in sleep mode.
Try pressing power button once. Does Windows logon screen come up?
SOURCE: Laptop stuck in sleep / hibernate mode??
Try holding the power button down for at least 10 seconds, that should turn off the laptop completely. Then press the power button again to turn it on. Hopefully it will boot up.
SOURCE: enable standby and hibernation in my laptop again
You can manually re-enable the Hibernate option via command prompt using these instructions:
"powercfg -h ON"
SOURCE: Shut down of laptop after blue screen appears
When you hit F12 or whatever F key to go to the boot drive menu, make sure the cd is in and that you select CD/DVD Drive and the dvd should prompt you to hit any key or will automatically start loading for the recovery. Just tell me if you need further assistance.
