Question about Whirlpool 24 in. ADP5966 Free-standing Dishwasher
Dishwasher has stopped partway through cycle, not pumped out
Whirlpool Dishwasher has stopped pumping the water out. It has done this years ago, and the repairmen advised that there is a moisture sensor underneath the machine which stops when it senses moisture under the machine. It is a very sensitive sensor and we had to change brand of washing poweder and rinse as the other one triggered this sensor, even though the machine was not leaking. There is a re-set button under the machine which the tradesman re-sets, and then the machine operates.
This time, as previously the machine is not leaking, and it will take several days to get a tradesman. If it is the pump that is okay, I will wait the distance. But I would like to find the button and reset it to see if I need to wait the 5 - 10 days for the repairman.
the machine is a Whirlpool ADP 5550, free standing (not on your list) with a knob on the left side. No computer programme options for cycles, just the knob.
In the meantime I will start bucketing the water out of the machine. :-)
Thanks for your help
  • 833 Answers
Not a moisture sensor, a water depth sensor to gauge fill level.  Not the problem here.  There is a solenoid valve under the machine.  It routes the water either to the wash arms or to the drain.  It is likely  jammed so that it will not open to drain the water.  Often, these items can be disassembled and cleaned.  Just shut the power before going in there.  If the valve can't be cleaned or the coil is bad, it will need replacement.
Posted on Nov 23, 2008
DWF 415 Ikea Whirlpool Dishwasher has constant green blinking light. Drain pump works ok (as it will pump out a jug of water if I tip it into it!) but no water comes in. Cycle stops about 30 seconds after...
Anyone got an answer to this, as I have exactly the same fault.
Dishwasher appears to switch on OK, then after a short time (20 secs?) the pump noise stops and the green light flashes - it seems to e a sequence of 7 flashes, then stop... 7 flashed then stop.
The sequence could indicate a fault detected?
Anyone know anything about these units from IKEA, made by Whirlpool?
Thanks!
S
Feb 12, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher has food particles baked on.
Heating element may fail. This will lead to the machine stopping part way through its cycle
Pumps. There are 2 pumps in most dishwashers. The drain pump,( which describes itself -it pumps the water out of the machine.)
The recirculating pump which forces the water at high pressure through the spray nozzles and arms. (This is how the cleaning action is performed)
These pump may either leak, or burn out. Either way, the only solution is replacement.
Mar 09, 2010 | Dishwashers
My dishwasher doesn't clean my dishes anymore and sometimes it doesnt dry them. it is a quiet partner 1 and it is about 2 years old.
It sounds like the water pump on the dish washer has gone out. A dish washer works (much like a clothes washer) by filling up the washer with a set amount of water, then through circulation, pumps the water up through the various spray nozzels. If the water pump is worn and not making enough pressure, the spray won't get the job done. Depending upon make/model, it may be cheaper to replace the water pump.
Run an empty dishwasher load with a bowl of white vinegar on the bottom shelf. As the dishwasher runs the cycle, the vinegar is slowly disbursed and cleans the dishwasher.
Mar 02, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Maytag DWU6602AAE. My Maytag dishwasher (14 years
SOUNDS LIKE A TIMER PROBLEM. YOU MAY WANT TO PRICE A REPLACEMENT TIMER. AND PRICE OUT NEW DISHWASHERS. GOOD LUCK!
Feb 25, 2010 | Dishwashers
Dishwasher not working. Two weeks ago the heating cycle didn't switch itself off but appeared to correct itself. Now there is no water in the cycle... pump and heater working, just no water reaching the...
Sounds like a bad pump. If it drains the water and doesn't deliver at arms the pump is more than likely bad. First of all pull the water supply line off and see if there is build up from hard water on the in-line screen (if present), then If you are mechanically inclined you should pull the pump/motor and remove housing to check for any obstructions and or build-up if you have hard water.
Dec 01, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
DWF 415 Ikea Whirlpool Dishwasher as constant
DWF 415 Ikea Whirlpool Dishwasher has constant green blinking light. Drain pump works ok (as it will pump out a jug of water if I tip it into it!) but no water comes in. Cycle stops about 30 seconds after thre is no more water to pump. Any ideas on how to fix?
Oct 09, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool gu2200 dishwasher, the detergent
Either:
1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Aug 27, 2009 | Whirlpool GU2200XTSS Built-in Dishwasher
Dishwasher won't wash
pump is likely gone ......without pressure from the pump .the arms will not turn and no water will shoot from the arm jets .....it's kinda like a whirlpool tub that way .....no pump no bubbles ..good luck
Jul 25, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Dishwasher starts running for 2 minutes then stops
The first 2 minutes of the cycle is a pump out cycle followed by a brief pause then a water fill cycle.Make sure the water is getting to the water valve underneath. Check the water valve for power with a volt meter just after the pump out cycle. No power= bad timer or bad wire. Power = a bad water valve or no water present.
Jul 05, 2009 | Whirlpool Dishwashers
I bought this dishwasher 5 years ago and was kept in the box until last month. I installed it, turned on the water and no water is being pumped into the unit from the water release valve in the dishwasher....
You will have to check all the connections visually. Since you know how to use a meter, see where the current stops. See if there is current coming from the control board to the pump. the water inlet solenoid valve should "free flow" water into the machine. the pump recirculates the water for the wash and rinse cycles and pumps the water out of the machine to the drain. It is more likely that that water inlet solenoid valve is where the problem is.
Mar 17, 2009 | GE 24 in. Profile PDW7800 Built-in...
Whirlpool 24 in. ADP5966 Free-standing Dishwasher Logo
581 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
