Question about Crown XTi 2000 2-Channel Amplifier
Crown xti2000 cuts off
When its first turned on it works great, then it cuts off, i have it running 2 jbl 115
  • 4,234 Answers
The protection circuit is most likely shutting down the amp because of heat. When the amp shuts down, does it feel hot? If not, then further investigation into the protection circuit will be necessary. This is not a problem that is likely to be diagnosed remotely as measurements will be required internally once the amp has stopped working. Check the sepaker wires for shorts that will cause the amp to work extra hard (generating extra heat). Other than that, you will need a servicer to diagnose further.
Posted on Nov 24, 2008
How to connect my JBL JRX 115 speaker to my Yamaha RX V673 receiver
You would use a standard banana plug to either a 1/4 phono or speakon plug. The JBL JRX 115 has both on the back. All the outputs on the Yamaha RX V673 have banana plugs. The channel you plug into would be up to you, there are many choices and they are listed on the back of the unit.
Dec 03, 2013 | JBL Audio Players & Recorders
Prx615m not turn on
Mosfet, FQP27P06/FQP30N60 got fried in the power output stage, this is a common issue with JBL powered by Crown speakers, let me know more to help a bit more also.
Apr 22, 2013 | JBL Bags PRX615M-CVR Cover Speaker
My bass cuts when playing but goes back on after a few seconds.
that because you have a loose ground to your amp or not the right size wire but check your ground on the amp it will overheat and turn off to protect itself .
Apr 13, 2012 | JBL PRX 518S PRX518S Powered Subwoofer PA...
Which amplifier that match 2 of JBL CM52 speaker and 2 of Bose 151
If you want to run both the speakers at a time you will have to buy a professional amplifier like CROWN XLS202.
Because together the total impedance will drop below 3 Ohms. An average domestic amplifier is designed to run speakers between 4 to 8 Ohms.
If you are running only one pair at a time you can buy any of the following Amplifiers.
Marantz - PM 7003
NAD C356
Mar 31, 2011 | JBL CM52 Speaker
JBL amp, worked fine untill 2 days ago. protection light on..
might have roasted your speakers voice coils a little which may be sending the amp into protect mode throw a speaker on it that you know works and if it doesnt trigger the protect circuit then you probably have a blown or almost sub.
Jan 02, 2010 | JBL BP1200.1 Car Audio Amplifier
Can this all be hooked up?
There was never anything mentioned about the 18 yamaha sub in the hook up process
Aug 17, 2009 | Crown CE1000 2-Channel Amplifier
Solo x 10 dual 2 ohm smells burnt and smoke
there is no such speaker as a solo-X L5.
The Solobaric L5 is 450Watts RMS and 900 Peak.
Check your documentation, and no warranty except Massive Audio covers Burned Voicecoils as it is deemed customer abuse.
If it is a typo, and not an L5, your combination (as long as each is level matched) should be ok to run on that sub. When wiring it as you describe, the two amplifiers need to be identically matched in order for both coils to play at the same level.
Seek professional installations so your warranty is intact.
Dec 21, 2008 | Kicker Solo-Baric L5 Car Subwoofer
Amp cuts off
The amplifier is going into protection. This may be caused by problems with speakers or wiring, or there may be internal problems in the amplifier. Start by connecting a known good speaker with a few feet of wire, and see if it runs without shutting down. If so, check the wiring and speakers. If the problem continues, the amp should be serviced.
Nov 23, 2008 | Crown XTi 2000 2-Channel Amplifier
Crown XTi 2000 2-Channel Amplifier Logo
282 people viewed this question
Top Crown Audio Players & Recorders Experts
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
