SOURCE: put a 10k pot on
goto the the rx rf amplifier. not the pll.. dual 914 diode or 4148s inline with rx will drop it down to that dB range. are you doing direction finding?? to need the decrease?
SOURCE: how to turn down power on magnum s9
Vortash is talking trash mate..
There are two controls towards the rear of the PCB, very close together. They set the upper and lower limit of the variable power. take a look on cbtricks.com for more info.
SOURCE: My rf gain is out where do I find one, Mic gain/
They can be ordered just google cb shop temple, tx on highway 95 they have parts and will ship to you. give em a call with part desciptions.
SOURCE: I turn on my cobra
firstly check your antenna feed (coax) for short with multimetre if this is ok problem might be your audio stage in the radio might need to be replaced hope this helps
SOURCE: I have to keep my rf=gain turned all the way down
The RF limits the signal strength you radio receives. After setting the RF to limit excessive signals, then set your squelch up until the noise is gone. There are some areas which have high RF background noise so adjustments are made often while driving around. Use the ANL (automatic noise limiter) and other features also to control the noise.
