Question about Whirlpool GS470LEM Gas Kitchen Range
Whirlpool Gas Range E2 F3
We were using the oven on our Whirlpool Gas Range, Model GS470LEMQ when it shut down and the food burned. The error code on the display showed E2 -F3- . I figured the oven over temped but I'm not sure why. Any suggestions?
  • 1 more comment
  • Timothy Stone Nov 23, 2008
    Makes sense to me. Thank you
  • Timothy Stone Nov 26, 2008
    There was no solution but I got my answer from the first solution
  • Anonymous Dec 31, 2008
    Whirlpool oven range error code on display screen E2 F3, totally burned food at 300 deg. within 10 minutes, and an electrical burning smell. Maintenance replaced the oven sensor... hope it works!!!
I HAVE A WHIRLPOOL GAS RANGE MODEL NUMBER SF379LEMS.OVEN WILL LIGHT UP BUT AFTER TEN MINUTES IT WILL KICK OFF ANF ON ON ,THEN AFTER AWHILE I WILL JUST SHUT OFF.ANY SUGGSTIONS. ADAM
Posted on Nov 24, 2008
    President:
  • Whirlpool Master
  • 2,651 Answers
Bake range over temperature, replacing the oven sensor is the easiest and most common solution for this problem.(w10181986) heres the part number
Posted on Nov 23, 2008
E2 f3 error code on whirlpool range
Here is the listing for this error code.
F3 - E2 Oven too hot Replace oven temperature sensor.
Here is the part to order.
Dec 01, 2012 | Whirlpool GS460 Gas Kitchen Range
I had the E2 F3 code while I was baking something. Is it safe to eat the food that was in the oven at the time the error occurred?
F3
- E2 Oven temperature is too high (Cook
mode)
Replace
Oven temperature sensor (RTD)
Note: Applies to all
F3-E... codes.
Dec 21, 2010 | Whirlpool GR460 Electric Kitchen Range
Whirlpool electric range timer constantly beeps and displays E2-F3 I don't even use the oven I just want beeping to stop I press STOP which changes display back to clock, but soon it returns to E2-F3...
Hi
Thanks for using FixYa.
Error F3-E2 in your Whirlpool oven means oven too hot and to resolve this issue you'll have to replace the oven temp. sensor (probe). Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 06, 2010 | Whirlpool GS475LEKS Gas Kitchen Range
Whirlpool SF36 Gas Oven - F3 F2 ERROR above 350 degrees
Unplug the range.
The oven temperature sensor has failed and must be replaced.
Remove the racks. Remove the temperature sensor located up high on the back wall of the oven.
It is a short thin round piece of metal.
Feb 13, 2010 | Whirlpool SF369 Gas Kitchen Range
oven senor not working right . it may have carbon that need removing or it may just need changing due to breakage
Feb 13, 2010 | Whirlpool SF367 Gas Kitchen Range
My whirlpool gas range has the letters E2-F3
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&^%
Oct 19, 2009 | Whirlpool Gold GW399LXU Gas Range
Whirlpool Electric Oven RBS305 overheats while baking, locks door
The technical manual for your range doesn't show an error code of E2 F2 but all of the F2 codes pertain to the touchpad of the range.
Can you clear the E2 F3 by pressing the cancel button? If not, shut off the power to the range for a few minutes and see if the error code goes away. If the error code remains You should unplug the range from the wall and remove the back panel for the control area. Disconnect the ribbon between the touchpad and the electronic control, clean the end of it and reconnect it.
If this doesn't repair the problem you will need to replace the touchpad on the range. The parts diagram lists two touchpads, they are part numbers 8273575- bisque, and 8272702- white.
Good luck
Dec 18, 2008 | Kitchen Ranges
Whirlpool gas range model gw395leps00 error code e2 f3
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question####
Dec 10, 2008 | Whirlpool GY396 Electric Kitchen Range
Whirlpool GS470LEM Gas Kitchen Range Logo
1,393 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
