Question about Protron PLTV-37 37 in. LCD Television
V-chip setting of pin on protron 37''
Bringing up menu to pin setting and setting #'s in and it always says invailid pin no matter what #'s I enter...do not have manual
Worked again with the v-chip control setting...my mistake was when I would respond to "enter PIN" I would enter and then then press "Enter" and the Invalid signal would come up. I entered the PIN and then got out of the setting area by pressing menu again and all was well
Posted on Nov 23, 2008
CANNOT CONTROL WITH REMOTE,NEW BATTERIES INSTALLED, NO CHANGE.ON OFF ONLY AT TV. CAN GET MENU ON TV, CANNOT DO ANYTHING WITH IT.
The remote control it is dead by the remote main CPU IC chip.Try website like Remotes.com to buy an original remote for the replacement.
Jun 19, 2011 | Protron PLTV-37 37 in. LCD Television
T.V. COMES ON WITH A BLUE SCREEN ONLY WILL ONLY PLAY DVD'S
CHECK TO SEE IF YOU TV IS SET TO AV OR EXT 1 OR 2 ETC
IN SET UP MENU OF YOUR TV
CHECK SCART PLUGS ARE PROPERLY INSERTED
Aug 25, 2010 | Protron PLTV-37 37 in. LCD Television
I forgot the pin to the v-chip code on my protron tv. What can i do to override it?
Try to reset it to the factory default setting by
With user’s Remote Control
1. Power TV On
2. Press Menu button and call up User OSD Menu
3. Select Audio-> Balance
4. Enter 0->5->3 ->2 in sequence.
Note: If necessary, re-do number keys.
5. Factory OSD appears.
Select the item “Clean All”and Press ENTER
6. Press Menu again and leave factory OSD.
May 06, 2010 | Protron PLTV-37 37 in. LCD Television
Picture in high def does not fill screen
That is normal. Most HDTV's have a format or picture size option on the remote or menu. It will give you options like full, stretch ot zoom to fill in the blank spots. The problem is those settings can also distort the picture size so people look funny.
Feb 28, 2009 | Protron PLTV-37 37 in. LCD Television
Protron 37
The power supply is the circuit board that helps the LCD to turn on and provides different voltages to make it work properly. If the voltages are not working properly due to defective parts, it will fail to turn on.
I hope the technician will be able to fix it for you or find a replacement for you.
Good Luck.
Aug 14, 2008 | Protron PLTV-37 37 in. LCD Television
No sound on protron lcd tv
Go to the set up menu and select audio. check that the speakers are ON.. Then make sure that stereo is selected. If the set is set to alt sound there wont be any sound.
Jun 13, 2008 | Protron PLTV-37 37 in. LCD Television
Protron 37" LCD, PLTV-37C
You can look it up under the Spectroniq PLTV-3750 TV. Protron changed their name but kept the set up the same. Hope this helps...
Jan 18, 2008 | Protron PLTV-37 37 in. LCD Television
Protron 37'' lcd v-chip reset
I would look thoroughly through the manual.  There must be a way for an adult to re-set the passwords etc.  If you can't find the manual, check the website.  www.proton,com?
Good luck.
Dec 06, 2007 | Protron PLTV-37 37 in. LCD Television
Protron PLTV-37 37 in. LCD Television Logo
99 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
