Question about Maytag MGR5750 Gas Kitchen Range
Oven won't light
When you turn on the oven it won't light for several minutes. Gus fumes accumulate and then it lights with a "Bang". We have not tried to sovle this ourselves.
You most likely need to replace the filament that heats up to ignite the gas. My oven did the same thing and that solved the problem.
Posted on Jul 14, 2008
Whirlpool Talent Microwave The microwave starts off ok, then during cooking its still turning & the light is on but its not cooking. It can go on like this for 8 or 9 minutes and then you hear a small...
That is the magnetron faulty. The oven stops cooking, as the magnetron lose contact, when the magnetron restart working you hear that loud bang, and it restart radiating.
Replace the magnetron.
You find parts here or here.
Oct 08, 2008 | Whirlpool Microwave Ovens
What causes a loud bang from oven?
If you hear a loud bang the SECOND time you try to light an oven, it means you've just had a small explosion when the gas from the FIRST try ignited outside the heating tube. I would have a professional check your oven before using it again.
Jul 18, 2014 | GE Spectra JGBP35 Gas Kitchen Range
Gas fumes from maytag range
"The professional gas installer has been here several times to check the. Gas lines." Ask the professional gas installer to do a leakage test and inspect for a cracked gas line.
Jul 29, 2017 | Maytag 30" Self-Cleaning Slide-In Gas...
Car won't start then exhaust fumes smell like varnish
Drop the tank remove all fuel replace the filter and fill with fresh gas
Sep 02, 2012 | 2003 Jeep Liberty
Oven cuts out with a bang when i turn it on ???
if you hear a big bang, and it wont light right away, it is normaly the ignitor thats going bad in oven. the ignitor has to get very hot to ignite the gas. orange in color. if this is the problem be very carefull not to bump the new ignitor on any thing, if you replace it yourself.I had the same problem last year,when trying to light oven it blew the door part way open because the ignitor was bad and the build up of gas caused this.
Feb 01, 2012 | Fagor Ovens
Is there any kind of pilot light that I need to light? I just had the gas turned and none of the burners will light and the oven won't get hot.
There may be a gas shutoff on the range gas supply. If so,turn it on.
If it is already on,turn on a surface burner and use a match ti light it.
It will take several minutes for the air to purge from a system once gas supply has been restored.
Aug 03, 2011 | Whirlpool Accubake RF362LXTB (Dual Fuel)...
Whirlpool oven door won't open after self cleaning.
I had the same problem. Hold down any button for 1 minute. That should reset the memory.
Mar 30, 2009 | Whirlpool SB160PEE Gas Single Oven
The pilot light for the oven went out.
Relighting Your Furnace's Pilot Light
furnace1.jpg - Turn off the gas at the main valve at your utility box - Wait five to ten minutes for gas fumes to waft away - Get a long match—yes, a fireplace match, not a standard match - Set the gas valve on your furnace to "pilot" - Press the red button as you hold the match to the pilot valve - Keep pressing the red button for 30-60 seconds so the pilot can heat the thermocouple. Release the button and see if the pilot remains lit - If pilot goes out, wait five to ten minutes and repeat the process - Once the pilot stays lit, turn the main gas valve back on - If the pilot light continues to go out, call a technician, who may need to adjust or replace your thermocouple or adjust your pilot
Jul 28, 2008 | Tappan 30IN ELEC IGNa Oven
Maytag MGR5750 Gas Kitchen Range Logo
78 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
