Question about Sharp AL-1642CS Copier
Dark lines on edges of copies
When I make a copy I get a dark line on the edges of the copy. I just changed the toner caritage
    Problem Solver:
  • 12 Answers
Make a copy when you here the paper getting picked up count 2 seconds and open front cover or side stopping the process open the copier and see if the dark line is on your drum or transfer is the problem
Posted on Nov 23, 2008
Mysterious fluctuation in quality of copies.
fuser drum is bad. photocopier use electricity to transfer the toner to the paper, then it is heat fused to paper. it appears that the problem is occurring around the time that the toner is attracted to the paper.
Mar 07, 2014 | Canon PC-940 Black and White Copier
My HP laserjet 3015 puts thick dark line down the copy
Put paper in the manual feed tray(tray 1). Print something. When the paper gets about 1/2 way into the printer, open the top cover. Pull out the toner. Look down at the paper in the printer. Do you see a thick dark line? Replace the toner. No thick dark line, check the fuser for damage.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
Broad dark line on right edge of copied papers
If you have the black line on copies and scans but printing from P.C is fine, then your scanner is broken.
Contact your printer manufacturer for a replacement or repair.
May 12, 2010 | Office Equipment & Supplies
Black line down the right hand side of prints
it may have had a dirt inside that may have been causing the lines. try cleaning with a soft dry cloth then try to print. reseat first the toner before you clean or wipe with a soft cloth
Sep 23, 2009 | Office Equipment & Supplies
I have a dark line across copies
Whats the make and model of the copier?
One culprit might be the drum.  If you can take a look at the drum from your copier and you see black lines on it.  It could be scratches on the drum or it may need a new cleaning blade to clean the toner off the drum.
Nov 11, 2008 | Office Equipment & Supplies
Dark edges
It depends... never use a Reman cart in these machines... only use sharp...especially if the machine is under warranty.
Does this happen when,
Using the Doc Feeder
When making copies from the Glass
Or when you print from a computer (assuming you print from a PC)
If you print something and this happens then it is inside the machine
Probably toner or developer dumping...
Take a few pieces of large white paper and cover the entire glass surface... make a copy is the line there? If so see the answer above... if not then close the top and make a copy with no paper on the glass... is that black line there.. If so then your top needs adjustment...
One more test
If you make a copy using the doc feeder, this black line only occurs when making copies with the doc feed, clean the **** glass, and try again...
Oct 25, 2008 | Sharp AL 1215 Black and White Copier
No matter how I clean it according to the manual I cannot get the dark line to disappear on our fax machine copies
the dark lines are caused by these things so check.
the thin strip of lamp dirty, or a light is bad
the drum has a dark toner ring around it, change
the fuser is dirty or is bad
Sep 17, 2008 | Sharp Office Equipment & Supplies
Copy Quality Problem for Thiashen
bit vague...Cq not good? What does that mean?
Light copies> could be related to toner or ROS unit (laser unit)
if prints OK but copies U/S clean mirrors and ccd lens
Dark copies , streaking? Cleaning blade /drum unit U/S
or could be streaking from fuser roll
Patchy copies , dark edges, light edges ???????
more detail please
Feb 02, 2008 | Office Equipment & Supplies
Copies here and recipients faxes: dark, lined
How long has the drum been in there?
try this:
1-take out toner, look and see if it is ok. do you see stripes on it?
2- look at the drum are there any black rings on it? ( you did not specify white or black lines)
3- where the glass is on the opposite side ( the part you lifted to clean the glass, look at it standing from the back. you will see a white metal plate with some springs in it if you touch it. this is the reference that the fax has if there is/are a black dot on it it will give you a black line clean carefully. if it is scratched use white out to cover and make white again.
For the darkness try making a copy in photo mode if it is still too dark change drum.
Dec 07, 2007 | Canon FAXPHONE B640 Plain Paper Bubblejet
275 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
