Question about Porter Cable 2" Flooring Cleat Nailer FCN200
The nails aren't going in far enough using a air cleat nailer
The nails aren't going into the hardwood flooring far enough. are we not using enough psi to drive them in ? or do we have to hit the hammer harder?
I just finished 800 square feet of oak flooring with this nailer. You might have to increase the psi at the gun and make sure it gets a good square firm hit to set the nail. You can swing and hit the thing pretty hard, I hit it hard to set warped boards in place. I used 120 psi for best results, I tried 90 psi but had more misfires. The nail head only needs to set in far enough so the head is touching the tongue and so the next board will fit. The nail won't be buried into the tongue like you might think. If the occasional nail protrudes from the board you can use a nail set to drive the nail the rest of the way in, but I found that most of the nails didn't want to set by hand. I either clipped off the head with side cutters and folded over the remaining tab or did my best to set the nail if it wasn't long enough to clip. If it bends over really ugly, just carve a little wood from the groove lands on the next board to clear the nail stub. Removing the nails is difficult, it's best to let them be rather than risk damaging the flooring. Also, don't let the gun get down to the last nail. Sometimes if you try to fire the last nail on a strip it will twist and damage the flooring. Always keep a few nails in the gun just to be safe. Hope this helps.
Posted on Nov 25, 2008
I've installed several thousand square feet of flooring with this nailer, including a lot of hickory, which is pretty hard stuff. I run the nailer between 90-100 lbs, and it sets 2" nails perfectly every time. Perfectly means the top of the nail head is flush with the inside corner of the tongue... not below nad not sticking out. If it gets to 80 lbs or lower, it'll fire, but the nail may not set all the way. I don't recommend running the pressure much higher than 100 lbs, and it shouldn't be necessary. I also don't recommend hitting the rubber cap too hard... the thing is air powered so you don't have to beat on it. You do have to hit it firmly and squarely so as not to move the nailer while it's firing, and the nailer has to be positioned properly against the board when you start. When I first purchased this nailer, I took a board a couple of feet long and did a half-dozen test fires to get the proper striking force figured out, starting lighter and working towards a harder strike. You can vary the striking force a fair amount and it'll work fine, so it's not critical... but too little and the thing won't set the nail properly, and too much and you'll prematurely wear the nailer. The nails really hold, but it's not too hard to pry up a short board nailed along only one side. Also make sure you're using Porter Cable nails. Others can be slightly thicker or thinner or be shaped a little differently, none of which are good things.
Posted on May 30, 2009
Nail cleats are not exiting when the mallet hits on my Bostitch MFN-201. The spring mechanism appears quite loose; you can push it down or in very easily by hand.
That is most likely what needs to be replaced as that is the return spring. If it is weak it may not be allowing the driver to go back up far enough to let the next cleat load into the nose. Here is the parts diagram. Bostitch (Stanley Tool Works) just merged with DeWalt so you can get the part from either company now or a dealer of either company.
http://servicenet.dewalt.com/Products/Detail/MFN-201
Jul 23, 2011 | Stanley Bostitch Mfn201 Manual Hardwood...
The nails will not drive into the oak flooring! the compressor is at 100psi and the nail gun mis fires or when it does fire it only drives the nail 1/4 inch into the flooring. It is a Akuzuki x-799
I am not familiar with that name of nailer but when I have run into that problem it was because of too much oil used in the gun. If so this will have to be cleaned out. You do not have to oil a gun every time it is used if not used consistantly for long periods of time. Also are you using the proper guage nails? Something to consider hope this helps.
Apr 25, 2011 | ProSeries Akuzuki Contractor Pro Series...
My MFN-201 cleat driver will not drive the cleats deep enough into the 3/4 inch prefinished bruce flooring. It postitions the cleats fine. It is on the Rachet setting.
There is a piece of rubber under the head called the bumper. This rubber piece is what stops the driver from forward travel. If you remove this rubber or replace with thinner, you can drive nail deeper. Most likely your driver blade may be worn or where driver blade attaches to shaft may be worn. Tool would need to be disassembled to check. Parts are not expensive and available at www.bostitch.com Good luck
Apr 06, 2011 | Stanley Bostitch Mfn201 Manual Hardwood...
Staples wont penetrate wood and keep foldin up
are the nails proper for nailer? the gauge of the nail is important
Oct 02, 2010 | Stanley Bostitch MIIIFN Flooring Nailers
Using the BOstitch flooring nailer, good air pressure and using cleats. but when i tap with hammer noting happens. the nailer goes off as if it had gone off but no nail was driven.
1. check to make sure the magazine does not contain a jam.
2. check to make sure the driver retracts fully to allow the cleat to advance
3. Be sure to have at least 90psi and to hit the head hard enough to fully fire the nailer.
Sep 25, 2009 | Stanley Bostitch MIIIFN Flooring Nailers
I am using a Bostitch MFN200 Manual Flooring Nailer and we are having some trouble with it. The cleats go almost all the way into the floor board but are still sticking up about an inch out of the board....
2 things come to mind. I've installed Wood Floors for the last 5 years.
Make sure you have enough Air pressure running to the stapler,
and Second, Whack the hell out of it. You can be rough with it. Their designed to take a beating
When u hit it with the mallet, youre opening a valve which shoots the piston and drives the staple into the boards. hit it not hard enough, not enough air is being sent to the piston to drive it fully.
Aug 02, 2009 | Stanley Bostitch Industrial Manual...
SENCO SHF 50 floor nailer won't consistently sink cleats
Some Senco tools reqire oil.  there is oil specially designed for tools.
Aug 01, 2009 | Senco SHF50 2" Hardwood Flooring Nailer...
Floor nailer, 2" nail not going into harwood
sounds like a bent shaft has the driver had any nail stuck or came out the side? whats the presser on?Are you nailing over exiting floor such as v.c.t or other hardwood floor try a couple drops oil in the nailer i' ve been doing floors for over 30 years these are some of the problems i came across hope its helps some what
Dec 23, 2008 | Farberware Manual Hardwood Flooring Nailer...
Porter Cable 2" Flooring Cleat Nailer FCN200 Logo
781 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
elunsford
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
