Question about Wintergreen CMV CT-723A 17" LCD Monitor
Device not installed properly message
Although the monitor seems to work fine, every time the computer is booted up a message is displayed that the monitor(device) has not been installed properly. I attempted to install a driver, but I cannot not find one on the internet and the CD that game with the monitor does not seem to work Thanks
  • wehj74 Oct 01, 2008
    nesesito ,os drivers`para elste monitor con sistema operativo Wiundows xp
    Dedicated:
    Visited the website for 20 consecutive days.
  • 344 Answers
Try this:
Go to Device Manager, right click on the monitor, choose uninstall, reboot the computer. When Windows starts up again, it will look for a driver(s), and might find the right one. If it doesn't, choose Cancel (this will set the monitor driver to Plug & Play Monitor or something like that which should be fine). Now, when you boot up you should not see that message again because the correct driver loaded or you chose Cancel.
Good luck.
Posted on Jan 12, 2018
When I turn it on it says Realtek PCIe FE Family
i think the realtek PCIe controler is your video display controler
Oct 21, 2013 | Toshiba PSAY1U-012005 Satellite P755-S5260...
My sansui pc/tv monitor isn't working properly when I connect it to my desktop.
Windows is likely crashing while loading recently upgraded device drivers. The most common culprits for this scenario are video drivers.
The next time you boot, as soon as you see the Dell splash screen, start tapping the F8-key about once every second until you see a white on black menu. If you see the Windows logo, you missed it (try again, this time start tapping the F8-key a little before the Dell splash screen).
This menu will allow you to boot Windows in "Safe Mode", which will bypass any non-essential drivers and applications that could be causing the crashing. Select "Safe Mode with networking".
Assuming the computer booted fine in Safe Mode, you will be able to remove the troublesome drivers. You will see an informational message about Safe Mode, which you may close at any time. Right-click "My Computer" and select "Manage". Wait a moment for the Computer Management window to appear. Then, click on "Device Manager". If Windows was able to identify the faulty driver, it will appear in the list with a bright-yellow triangle. If this is the case, right-click and "uninstall" it. If it did not show up, first click the tiny white triangle next to "Display Adapters" and "Monitors" to open those categories. Then, right-click and "uninstall" everything listed within the two categories. Your computer will probably boot normally after doing this. But, try and find the proper driver for you video adapter before rebooting if possible. I recommend also re-installing the chipset drivers which may be related to the problem.
To attain drivers for your specific Dimension B110, visit the following link and enter the service tag code on the back or side of your machine: Dell Drivers
Oct 28, 2012 | Sansui HDLCD1912 19in LCD HDTV 720p
Monitor light is green but display is black
your power supply board, probably has some bad caps in it
Jun 12, 2010 | AOC LM729 17" LCD Monitor
Blank computer screen 3 times out of 4 when booting computer
there must be the problem of your lcd backlight chek that properly by open it or tack it to the engg.near you.
Jan 27, 2010 | Samsung 226BW Monitor
Computor doesn't pickup the monitor nothing on the screen
If the monitor displays POST messages as it boots, then your monitor is still working. It would appear that either your video card or your monitor settings need fixing. Try booting Windows in SAFE MODE and go to Control Panel. Select Display Settings and uninstall the existing driver for your video card.
Reboot your machine. Windows should detect your video card and install its proper drivers. If you've gotten this far, your monitor is working.
Failing the above, reboot in SAFE MODE again and this time uninstall your monitor. Try rebooting again and Windows should again detect, configure and install your monitor appropriately.
Aug 16, 2009 | Computers & Internet
Screen will not display
Have you ensured that your display card driver AND correct monitor driver is installed. This is to make sure that your display card only generates signals that your Acer monitor is capable of handling. If you do not have the driver CD for your monitor you can download the software from www.acer.com. The problem is most likely that your display card is generating a refresh rate which your monitor cant handle. Go to your display properties and lower the refresh rate of your display card and see if this solves the problem.
Best wishes,
Graemevm
Jun 29, 2009 | Acer H233H bmid Monitor
"Input Not Supported" message on monitor at boot
Sounds to me like the input has gone out of the boundaries the monitor supports. IE the refresh rate is too high frequency (normally 60 to 72 Hertz for LCD's) or the screen resolution has been set too high.
Go into safe mode and set it back to 1024 X 768 at a frequency of 60 Hz, once back into windows proper you can try higher resolutions and change your refresh, if the screen goes black or displays a message "Out of Bounds" or similar it should revert after 15 seconds if left alone.
Have fun
Apr 27, 2009 | Envision EN-9250 19" Flat Panel LCD...
I have an hp a706n desktop with 3 vga ports. Until yesterday I have been able to use two monitors. Now only one of the vga ports work. The port will work with ether monitor. However when I connect my...
Getting dual monitors to work correctly seems to be a hit or miss affair. In many cases, it's just a matter adding a second video card and monitor and rebooting the computer. In other cases, you need to do some cyber gymnastics to get things working correctly.
The process is the same no matter which version of Windows you are using. First, be sure that your system is working correctly. Boot into safe mode and verify that you have only one video adapter and monitor showing in the Device Manager. If there are more, but you only have one adapter and monitor, you'll need to remove the extras.
Once you're sure that your video setup is working fine, turn off the system and look inside. Remember that you'll need a video card for each monitor that you plan to run under Windows. That means that your system must have a free expansion slot for each one. You may find that you have problems with IRQ sharing or DMA channels, depending on your motherboard and video card, although many video cards seem relatively intolerant of IRQ and DMA conflicts. Install your video card in the appropriate slot, and then connect the monitor.
Restart your system. If all goes well, your computer will boot the same way that it always has…the second monitor will still be dark. If your system prompts you to login, do it. You may need to install drivers for your second video card, depending upon whether or not Windows has built in drivers or not. Just follow the on-screen instructions.
Once the drivers are installed, check the Device Manager to make sure that the display adapter is properly detected:
e14df7f.gif Once the drivers are installed, open the Display Properties window. In the settings screen, you should see something like this:
838d51e.gif You'll see that a second display is shown. Click on the grayed out display marked as "2". The window will change slightly to look like this:
d3c979a.gif You can then change the desktop resolution and color depth. Once you've done that, click your mouse on the "Extend my Windows desktop onto this monitor" to enable it. Remember that the resolution, color depth and refresh rates of each monitor adapter combination don't have to be the same. The window should look something like this now:
ad5a047.gif Click on OK and your second monitor should activate itself as an extension of the first:
You'll find that you can change the relative geometries of the two monitors by moving their respective boxes around in the Settings window.
Please reply to me if that doesnt help!!!
Mar 27, 2009 | HP Televison & Video
Monitor cause blasting sound !
as it is not always sometimes only. this might be due to over oscillation in horz. stage.means more eht. it might be due to 1 power supply seems to be more then normal. 2 horizontal frequrncy not tunned properly if any preset is there. 3 loose contact in hor. section 4 some times it is due to connecting cable from monitor to computer.
Sep 28, 2007 | Computers & Internet
Wintergreen CMV CT-723A 17" LCD Monitor Logo
52 people viewed this question
Top Wintergreen Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Wintergreen Computer and Internet Expert? Answer questions, earn points and help others
