Question about Frigidaire FRS23KF7AB Side by Side Refrigerator
Freezer not keeping ice cream cold
I have a frigidaire refrigerator and my freezer is not freezing. the ice cream has turned to soup
  • Frigidaire Master
  • 8,220 Answers
One thing you can do is clean out the area under the ice box where the condenser coils are located. Make sure the fan motor is blowing under there. Clean the kickplate. Get the air restrictions out of the fins and that may bring the freezer temp back up to par.
Posted on Jan 08, 2009
We get ice cream, but it is not firm . . more of a soup how to adjust
There are two types of machine. Cheap ones where you have to pre-freeze an insert and chill to mix to almost frozen. Then the more expensive ones that have a compressor in them and are actually an electric freezer with a paddle.
If you have the cheap sort, then nothing you can do apart from following the instructions and chilling and freezing everything well.
With the freezer type, you need a refrigeration engineer as it probably needs more refrigerant gas.
Apr 24, 2016 | Ice Cream Makers
Ice cream is not freezing on FFUS2613L Frigidaire Refrigerator
Thanks for your post, friend!
I understand that your ice cream inside of your Frigidaire refrigerator, FFUS2613L. I would turn down your thermostat to see if that would help correct the issue of your ice cream not freezing. I hope this helps. -Matt
Sep 30, 2014 | Frigidaire FFUS2613L Side by Side...
Freezer too cold. Ice cream freezes hard like a rock. Freezer does not respond to temp control which is turned to maximum warm.
Have you checked for an ice buildup on the evaporator coils. One cause could be that the thermostat is getting a false reading because of ice build up.
Aug 02, 2011 | Frigidaire 14.7 Cu. Ft. Top-Mount...
Frigidaire side by side freezer - LOUD noise...
It sounds like the evaporator fan is hitting ice that is built up on the evaporator coil. When it's making the noise, open the freezer door and see if it stops.
(Most models are wired so that the evaporator fan cuts off when the freezer door is open.)
Check the inside back, lower panel of the freezer for ice built up or frost on it. If there is, you have a defrost problem that is most likley a bad heater. It's located around the coil inside the freezer behind the panel you will be looking at. The defrost problem would explain the freezer not freezing ice cream.
Nov 12, 2009 | Frigidaire FRS26R4A Side by Side...
Frigidaire twin freezer not working
Check the freezer back wall for snow or frost.If it's there you have a defrost problem.
May 25, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Refrigerator and Freezer are not cold enough
sounds like your fridge is iced up.To cheak this you will need to remove rear panel in freezer compartment and cheak if there is ice buld up.If so you may need a defrost timer or your drain tube may be plugged..If those are fine cheak if your defrost thermostat is ok and not split.Hope this helped:)
May 20, 2009 | Refrigerators
Frigidaire freezer not freezing ice cream
The freezer temp settings are not low enough or you are getting ready to have a poblem with the defrost circuit.
May 05, 2009 | KitchenAid Superba Architect KSCS25INSS...
Freezer not freezing like it should
Yes that is hte panel in which "skeeter 140 " was refering
Jan 14, 2009 | Frigidaire FRT18FS6C Top Freezer...
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Frigidaire FRS23KF7AB Side by Side Refrigerator Logo
329 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
