Question about Microsoft Xbox 360 Console
X box got wet light red on power box
  • 63 Answers
That means your power brick is not receiving enough power. It should be green on the power brick.
Posted on Nov 23, 2008
  • lucaskiddy Aug 13, 2011
    how do i give it more power to give it a green light
What to I do if my TV got wet on the power cord but I am getting picture and sound before it cuts off?
If the liquid got into the TV and onto the printed circuit board, there could be damage to the circuit board. The fact that the TV had a reaction to the liquid is not a good thing. If the TV is still wet inside the problem will remain. If you continue to turn the TV on if it is still wet you might cause more damage. I would wait until the liquid is gone or dry and try the TV again. If the TV was in the normal position to watch, the liquid should run off and dry in a few days.
Aug 20, 2015 | Samsung Televison & Video
Just bought last week have an oil leak in driveway the oil is light brown in color what could it be..
oil cooler lines, transmission pan, power steering leaking or axle seals. All are pretty common.
IF you open up the access cover for the oil filter you will see the cooler lines. If they are wet with oil you found the first leak.
The trans pan will be wet if the gasket is leaking
the front axle seal will be wet right where the axles go in the front end.
The power steering pump, lines, gear box will be wet if they are leaking.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Feb 25, 2011 | 2001 GMC Jimmy
Installing fan & light control (27182) - in the box, there are red, white and black wires. On the control, there are red, blue and black. So, black to black; red to red; right?....does blue go to...
Under normal circumstances, NO! Black is normally power in to a box and to a switch. The switch controls the power out to the red line and most likely the blue line. White is always circuit neutral (ground). Your power will most likely come in via black and then go to the lights on either red or blue and to the fan on the other wire, either red or blue, the color you did NOT use for the lights. Some place you should also have a bare or green wire that would act as equipment ground, connecting to the metal of the box.
Sep 06, 2010 | Hunter Ceiling Fan Light Switch Control
1997 GMC Jimmy. A/C fan blowing intermittantly, then not at all. Hazzard lights working sometimes, power locks and windows working most of the times, turning on the windshield wiper shuts off the radio.
Check that the power fuse and relay boxes are not wet now, or have evidence of minerals left behind from being wet at one time (like a flood).
Jul 14, 2010 | 1997 GMC Jimmy
Power light red ,internet light red no other
Most of the time a red internet light means that the box can't find the internet / can't find it ISP / can't get on the DSL what ever.
Might be the modem, might be the power adapter.
Nov 25, 2009 | NetGear DG834 Router
3 red lights box under 3 years old
RED LIGHT OF DEATH!
The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 motherboard or power supply.You can test power supply with a voltmeter from power supply wires to the connections on the motherboard. If no power or low power, the supply is bad. If there is plenty of power, then motherboard could have bad capacitor or chipset on it causing the problems. You can test those with an ohmmeter to see which component is not the same.
Nov 23, 2009 | Microsoft Xbox 360 Console
No Coffee dispenses
That is exactly what I would've suggested, the brew unit is clogged. remove brew unit and try to blow through the top, if you get through then check the bottom. One of the chambers must be clogged. Another question is the coffee extract wet or dry grounds?
If wet then the block is on the top, if dry it ids on the bottom.
Feb 28, 2009 | Saeco Vienna De Luxe Espresso Machine
X-box 360 wont turn on
Is your power box light orange or green. It should be orange if turned off and go green when turned on if it is red your power supply box is no good you can unplug it leave off for 10 minutes or so then try again if light doesn't go orange you won't be able to turn it on. I had the same problem and it was power supply box with red light got new one works great.
Jul 17, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
124 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
