Question about Pelonis Heating & Cooling
My Pelonis oil filled heater wouldn't come on. I discovered that it has a bad fuse(SF129E, U9870, Tf 133 degree, 10A, 250V). Can you supply a replacement or recommend a substitute ? Thanks, Keith
  • 833 Answers
Go to the nearest hardware store or to Radio Shack.  Bring the old one with you.  The main things are the physical size of the fuse and the voltage/amperage ratings.  The other numbers are not important.
Posted on Nov 23, 2008
Need KSD-301-V thermo switch for a Pelonis HO-O218 oil filled heater
Amazon has lots of these thermostats available from 3 to 5 dollars. This is the most common thermostatic switch failure for the Pelonis heater . Go to Amazon and type in KSD 301 in the search area. The temperature rating of the sensor is approximately 305 degrees
Jan 31, 2015 | Pelonis Heating & Cooling
Pelonis oiled filled heater ho-0218 won't heat up
burnt thermo fuse or element. be sure to connect any wires tightly if you replace thermo fuse. test it with a mulimeter should show less than 1 ohm. no you do not need to add oil, if the unit leaks throw it out.
Mar 24, 2014 | Pelonis Heating & Cooling
My pelonis oil heater has a diode? on the blue power wire behind the end cover. i think this is why mine does not work. can you help me find a replacement?
It looks like a diode, but it's actually a thermal fuse. 128 degree Celcius, marked d125 with a blue stripe. I just replaced mine with a 15amp, 128C, d125.
Sep 21, 2010 | Pelonis Oil Heater HO 157
I need a switch for my heater,how do i order the on and off switch for my oil heater pelonis-model#Ho-157c0109
http://www.pelonis.com/service_first.htm go to this link and about the second paragraph down are the instructtions for ordering parts, getting ready to do the same thing myself.
Feb 09, 2010 | Pelonis WM-HO202C Oil Filled Radiator...
DURING A RECENT MOVE THE BOX CONTAINER MY PELONIS
The oil does not circulate or lubricat anything. It just holds heat. No harm done.
Eric
Dec 01, 2009 | Pelonis WM-HO202C Oil Filled Radiator...
Delonghi Solaris Heater Model No. TRN0812T NOT WORKING
In the past I have nothing but problems with DeLonghi heaters. I replaced them with Pelonis heaters and have had no problems since. Pelonis heaters are availible from Home Depot at a very reasonable price. This is based on my experience only. Hope it helps.
Ray
Dec 08, 2008 | DeLonghi TRN1015T Solaris Oil-Filled...
Heating & Cooling Logo
167 people viewed this question
Top Pelonis Heating & Cooling Experts
Paul Carew
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
