Question about Samsung RS2556 Side by Side Refrigerator
Possible noisy compressor?
I have a 1 year and 4 month old refrigerator that makes alot of noise when the compressor starts or stops. It sounds like something is very loose. It sounds like a vibration type of noise, but extremely loud. I can hear this when I am at the other end of my house. I explained to customer service the problem I was having and was told that I was past the 1 year warranty..any ideas?
  • 3 more comments
  • mp1991 Nov 16, 2007
    The compressor is making quite a bit of noise when the electrical connection clicks on and stops when the connection clicks off. I've checked that the fan isn't a cause and that the rubber mounts are firmly seated. This happens every three to four minutes and makes the noise for about 15 seconds or so. Any suggestions?
  • Anonymous Nov 25, 2007
    We have a Whirlpool Side by Side refrigerator. When the compressor comes on it makes a vibrating sound like something is loose. When the compressor goes off the sound does as well.
  • owlhouse Dec 10, 2007
    Just before the warranty ran out, the unit started making an awful rattling noise, very loud, and would sometimes shudder and shake too. The noise came and went during the day (happened when the compressor was on, but didn't happen all the time), which continued for about two weeks, and then stopped all together just before the service people were finally scheduled to arrive. I canceled the appointment. Then about two months later, it started again, lasted a couple weeks, and went away. Now it's back again. The noise is coming not from the fan, but from the area in the back of the refrigerator, down by the compressor. The unit is level, I've moved all food away from the back of the fridge, and I've turned the temp down to 1 (because LG suggested that condensation might be causing the problem). LG also made the rather strange comment that my freezer might be too full. What good is a refrigerator that you can't fill? At any rate, it is not "full." There's plenty of empty space left in it.
  • Anonymous Apr 07, 2008
    We have a Whirlpool Side by Side refrigerator GS6SHEXNL almost 3 years old and started making vibrating noises when the compressor comes on . When the compressor goes off the sound stop.
  • aspian Aug 31, 2008
    The compressor stops with a very very loud noise as if it is going to break up.
    this is since one year. the cooling otherwise is OK.
    It is out of warranty and no solution is offered.
It could be 1 or more springs are broken in the compressor
Posted on May 18, 2008
It can also mean that compressor is wearing out and that is the loose rattle you hear when it shuts off.
Posted on Mar 26, 2008
Re: the problem posted by GUEST on 11/25/2007, I have been having a similar problem with a Jenn-Air French Door model. It would wake me up at night. I found that correct leveling of the refrig made the problem go away. Check you users manual and it should have instructions. I think these appliance guys just toss the stuff in and don't do the proper alignment or leveling. It took me an hour to do and no service call required. Made a huge difference
Posted on Dec 03, 2007
If you're sure it is a compressor problem it has a five years warranty replacement. Don't let customer service fool you.
Posted on Oct 01, 2007
Samsung usually have 2 years guarantee contact samsung to check if it is still under guarantee have serial no and model no handy with date of p urchase samsunguser
Posted on Feb 13, 2007
If compressor is the problem check your warranty some manufacturers have extended coverage for the compressor & sealed system it's usually 5 years
Posted on Jan 18, 2007
  • 237 Answers
The compressor and condensor fan all run at the same time. Make sure the fan isn't hitting something or the drip pan isn't rattling, etc. If you are positive the compressor is making the noise check the rubber isolation mounts to see if they are loose or damaged, etc. http://www.partselect.com/Schematics/Maytag/SS10-1.gif
Posted on Dec 27, 2006
  • Marc Wilson
    Marc Wilson Feb 04, 2007
    Why a poor rating?
Noisy compressor
Is the compressor running when you hear this noise or is it noisy when it is trying to start. If the noise you are talking about is the click it may just have a bad relay on the compressor. If it is a loud humming noise when the compressor is trying to start then the compressor is locked up and needs to be replaced. Compressor comes with a 5 yr warranty and relay has a 1 yr warranty.
Nov 16, 2007 | Maytag MFD2560HES Bottom Freezer French...
Noisy compressor on fridge freezer
does it always make that hum noise or just when adjusting temp
Aug 18, 2012 | Kenmore Refrigerators
Noisy Compressor
either the compressor is under charged or it is near breakdown. compressor cost is almost the 1/3 of the freezer cost.
May 08, 2009 | Haier HTE16WAA Top Freezer Refrigerator
A three loud consecutive popping sounds at various
You probably have a bad compressor. It's internal parts are held up with 4 springs and one of them has probably broken and causes the compressor piston to hit the side of the comp. housing. This will happen when the ref. shuts off. To be sure, if you turn the ref off at the controls then you should hear the noise in the back. If it is less than 5 years old you can get it replaced under warranty. if more than 5 years old it will just be noisy. it will most likely last several more years like it is. Let me know if I'm right.
Apr 01, 2009 | Frigidaire FRT21H8 Top Freezer...
98 grandam grinding / ac compressor??
You are correct about replacement it will fix it and be cheaper in the long run. The bearing thats bad is pressed on, witch will be a bear to get off, if you can get it off. Every one i have ever known that had this problem just put another compressor on and recharged the system, its the best and cheapest fix. As far as compressor its up to you, but i would go with remanufactured at least you get a warrenty, if you buy used thats what you get is used or maybe someone elses problem. You will have to recharge the system, but you can do that yourself with a recharge kit from Wal-Mart around $20.00. Besides if it still has the old R12 refrigerant you can upgrade it to the new 134. One thing you should do is have the old refrigerant sucked out someplace that can capture it because of environmental issues.
Feb 06, 2009 | 1987 Pontiac Grand Am
Refrigerator noisy after compressor replacement.
There may be too much refrigerant in the system. If he did not use a vacuum pump before adding freon, then air is in the system but does not cause a gurgling sound, it just won't cool properly.
Apr 16, 2017 | Refrigerators
Electrical noise
If the noise from the compressor sounds like a humming followed by a click, the compressor is "short cycling". Could be either the compressor relay or the compressor itself is bad. Not sure on the hissing noise. Could be just a loose panel that needs to be tightened or adjusted.
Apr 07, 2008 | Samsung RB1955 Bottom Freezer Refrigerator
Noisy compressor
Is a Hotpoint refrig?? Ge (who makes hotpoint) is having trouble with the freezer fan howling. Check out posts on Ge SxS PSS models. Some say its the main board, i disagree.
Dec 02, 2007 | Hotpoint HSM25GFRSA
Noisy compressor
If it's a buzzing for a few seconds followed by a click, your probably going to need a compressor. This sounds like that problem. Check your warranty. Many manufacturers went to 1 year on this in '06.
Samsung RS2556 Side by Side Refrigerator Logo
1,619 people viewed this question
Top Samsung Refrigerators Experts
Paul
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
