Monitor only stays on for 3 second when powered on
I have checked the cables and drivers and still need help.
  • 1 more comment
  • lucky1bdc Nov 23, 2008
    the power button stays lit, so i am not entirely sure at this point.
  • pskkhh Nov 23, 2008
    checked everythng but the problem persists. need help.......
  • P. Thomas
    P. Thomas May 11, 2010
    hmmm...is this a power issue or a signal issue?
Could be bad monitor.. try hooking it up to VGA port on laptop to test
Posted on Jan 05, 2010
Firstrestart the pc
press F8
enable vga mode
Posted on Nov 28, 2008
AOC 2036S won't connect to laptop
Is the cable working? try reducing your laptop screen resolution and connect to your monitor. Your monitor may not support full hd resolutions....
Jan 09, 2014 | AOC 2036S 20 INCH BLK LCD MONITOR
Monitor cutting out
Follow steps in sequence:
1. Turn Off Monitor by pressing power button on LCD
2. Shut down computer
3. Unplug power cable from LCD, Once power cable is unplugged from LCD, press and hold down the power button on LCD for 15 seconds
4. Unplug the power cable from the back of Desktop Computer and Hold down the power button on desktop computer for 15 seconds
5. Plug the power cables back into the LCD and Desktop Computer
6. Power on computer and then power on LCD, it should work
Oct 06, 2008 | Samtron Computers & Internet
Screen only works for 3 seconds then goes dark.
Capcitors in the power supply will be the first thing to check, see examples of what goes out in monitors: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you further.
Mar 25, 2010 | Westinghouse Electric L1916HW 19" Monitor
Proview Monitor Blank display after 3 seconds issue
First place to look will be the power supply section, look for bad caps (bulging tops or bottom seals), the post back what you see so we can guide you further for direction such as voltage checking, see example of failed monitors due to bead caps: http://s807.photobucket.com/home/budm/allalbums
Jan 28, 2010 | Xerox XG-91D 19" LCD Monitor
Monitor stays on only 3 seconds screen goes blank
resolution out of range, cable damage or input board defective. 1st check monitor resolution parameters.
2nd check for damaged cable or connectors pc/monitor or there is a defective monitor input board
Dec 22, 2009 | Computers & Internet
I need to unlock my monitor
Here is a link to the manual for your AOC 22" monitor.
When the window opens you will see "pdf downloads" on the right side of the page. Click on your manual and download it.
Hope this helps to unlock it.
http://us.aoc.com/support/manuals_drivers
Nov 13, 2009 | Computers & Internet
Same problem- SyncMaster goes on/off, bad TV image, needs reset
try to update the monitor driver tehn check the same with the cables from cpu detached if no signal comes for long then the monitor is fine also try to check the monitor on bios screen
Sep 15, 2009 | Samsung SyncMaster 910MP 19" LCD Monitor
Computer in safe mode and monitor will go to sleep mode....help what can I do...my husband tried everything....
First, Shotdown your computer from start ,
then remove your computer power, remove VGA cable, remove VGA power cable. then
1- connect vga cable to computer.
2- connect VGA power but do not power on.
3- connect computer power on but do not turn on
4- turn on computer first and 3 second turn on your lcd.
if NOT try powering on computer then Monitor then power the computer then monitor.
IF NONE worked, YOU may have LCD that need drivers from manufacturing, some newer models required that, Specially for vista.You may use older Monitor to get drivers to computer and extracted, then you may connected, you will have solved the problem.
Goodluck
JMC
Aug 12, 2009 | Dell Dimension 4600 PC Desktop
X2 gen 17" lcd monitor, no display
This indicates either a problem with the monitor cable(ie shorted) or the display adapter. Try plugging the monitor into a different computer and if it works you will need to install a new display adapter in your computer. If it doewn't work on the new one either you can try a different monitor cable if yours isn't permanently connected. Hope this helps
Mar 29, 2009 | X2 MG17R 17" LCD Monitor
Monitor will not stay on
Same boat 1.5 years old and the screeen will shut down in about 1-3 seconds as long as i turn it on.
Mar 31, 2008 | Gateway FPD1975W 19" LCD Monitor
Computers & Internet Logo
135 people viewed this question
Alun Cox
David Payne
David Payne
