Question about Protron PLTV-4250 42 in. LCD Television
No sound on some channels
We cannot get sound on the following channels 9, 10, 19, 24, 26, 37, 46, 48, 51, 52 56, 72. We will get sound for about 1/2 a second and then it is mute. Bought the TV about a year ago at Sams.?
  • Anonymous Dec 28, 2008
    Both the sound and the picture keeps cutting out, this TV is only 2 years old. What's the problem???
    Sergeant:
    Champion:
  • 267 Answers
CHECK YOUR SAP. tHE SECOND AUDIO PROGRAM IS PROBABLY TURNED ON.
Posted on Jan 16, 2009
How do I get the BBC channels back
Sounds like you need to check if the tv is set to the right region.as BBC is region orientated.
Dec 08, 2014 | Televison & Video
Sansui aux-410r amp crackling when switched on followed by high pitched sound and other sound like vinyl played at high volume and stylus being dragged across it .can anyone help please.
This is some kind of componant fault. To find out where determine if the sound is in one channel or both. If in both it could be in the power supply or in something that has both channels common to it. If in just one channel than at least you have the good channel to work with. You can test the bad channel by poking it with an insulated tool. It should make buzzing noises. If it makes buzzing noises in the good channel and is differerent in the bad in anyway you have found something. If the sound also comes and go suspect bad soldering.
Oct 27, 2014 | Audio Players & Recorders
Teac A R300 right speaker has s badly distorted sound after 20 minutes. When I turn it off nad turn it on again, Same problem after 20 minutes. Left channel working perfect.
Have you changed the speakers to see if it is a driver, or amplifier, issue? If it follows the speaker, get it reconed. If it follows the channel, look into that channel.
Aug 19, 2014 | Audio Players & Recorders
I have no sound on two channels only
If you are in Australia and have no sound on GEM and 7-Mate, follow the instructions here, to update the TV's (LG 50PB4D-AA) firmware. Once done you will receive sound on these channels.
Sep 01, 2010 | LG 50PB4D 50 in. Plasma HDTV
I have retuned my parents tv but now the digital (freeview) channels do not have the correct channel numbers and I cannot find anything in the manual as to how to change them. For example, freeview channel...
It sounds like the TV has re-mapped the channels incorrectly. You possibly can contact Toshiba to see if there is a firmware/software upgrade that will fix this issue. If there is you may be able to download the software off of their website and install yourself. Just make sure if that is the case follow the directions carefully. Please take a few moments to rate my answer. Thanks..
Nov 19, 2009 | Toshiba 32WLT58 32 in. LCD Television
With my starview 3 all of sudden my sound is distorted
To get back sound channels ect just select the channel in question press menu,
select installation, select manual scan, click ok on down frequency.
It'll now scan for channels when its finished exit back to normal
tv viewing screen go to the end of your channel listing and the desired channel will be there with sound.
This can be done on any channel with no sound by just selecting that channel following the instructions above.
Hope this helps
Feb 25, 2009 | StarTech.com StarView SV211K 2-port KVM...
No sound on analog channels
Grab your sharp remote and press MENU, arrow over to SETUP, arrow down to RESET and press enter and follow that prompt to reset the unit. Once that is complete turn the tv off and unplug ONLY the tv for one minute then plug it back in. Then turn the tv on and see if you have channels, if you do, your audio should work on you analog stations, if you have no channels and all you see is a snowy picture do the following press MENU, arrow over to SETUP...arrow down to CH SETUP and press ENTER...you will then be at a screen that says AIR/CABLE, press ENTER, select CABLE or CABLE(STD) if that option is available to you. after then, arrow down to CH SEARCH, press ENTER, then you should be highlighted on ANALOG AND DIGITAL SEARCH...press ENTER and wait for 15-30 minutes ( or until you get a picture back) and make sure you DO NOT press any buttons or turn the tv off and you should be good. good luck 2 u
Feb 10, 2009 | Sharp LC-32SB24U 32 in. LCD TV
Mitsubishi HS-412UR - Audio - Right Channel Not Working Properly
One of the strangest things that has happened to both the consumer and the technical field has been the use of a flexible adhesive on many of these machines' circuit boards. The glue in question is vanilla-colored, and has a tendency to react to electricity by inducing capacitance, resistance, and in some cases, even causing inductance issues. The fix, of course, is to remove as much of this material as possible, and following right behind with a nylon-based retainer. Then, if the problem persists, a followup with tried and true technical procedures...accordianman
Feb 12, 2008 | Televison & Video
Speaker problems
Hi, since the speakers themselves are ok, try checking the BABY PHONE PLUG that goes to the music/sound source. It is normally three (3) in 1 stud. The metal topmost would go to one channel, followed by a blak plastic ring then another metal band which goes to the other channel, followed by another black plastic ring and the final metal part which is the ground. With power on to the Z-5300, try touching the ends of the baby phone plug. Touching the top and 2nd metal part should produce a sound on either of the left or right. No sound (but spkrs good) it is possible that the left channel (front and rear) of the amplifier is dead. Hope this helps.Regrads.
Apr 20, 2007 | Logitech Z-5300 Computer Speakers
Protron PLTV-4250 42 in. LCD Television Logo
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
