I have an RCA Rear projection TV. After turning it off earlier today, it won't come back on, either by using the remote control, or by using the power button on the front of the set. The power cord is good, and I've checked the fuse inside. Any other ideas as to what's wrong?
  • FilthyCrab Nov 23, 2008
    P46732BA is the model. The only light on the front of the tv is in the centre of the power button, and it does not come on now.
    Genius:
  • 1,030 Answers
What model of rca do you have. does any lights on the front. any sounds
Posted on Nov 23, 2008
Have a proscan ps50700 that wont show the picture, will turn on but turns itself right back off. what could it be
TV Doesn't Turn On
  • Your RCA rear projection TV may not turn on from time to time for several reasons. First, check that the power cord is plugged into a working power outlet. Check that the outlet is receiving electricity by plugging a different device into the outlet. If the other device doesn't work, you may need to replace a fuse or reset a circuit breaker in your home.
    If you tried using the remote control to turn on the TV, press the "Power" button on the front of the TV. You may have a problem with the remote control if the TV turns on.
    If you tried using the front control panels and haven't tried the remote, press the "Power" button on the remote control. The television controls are blocked if the TV turns on with the remote. To unlock the controls, open the "Parental Control" menu and remove the check mark next to "Front Panel Block."
    Finally, your TV may be performing a diagnostic check. These checks are used to find any errors in your TV. Wait a few minutes before trying to turn on the TV again.
TV Turns Off By Itself
  • You may find that your RCA TV turns off by itself on occasion. This is often because the "Sleep Timer" feature was enabled. This feature allows you to place a timer on the television that will turn it off after a specific amount of time has passed. The feature allows you to save on your energy bill and extend the life of your television.
    If the "Sleep Timer" wasn't set, the television may have detected a power surge in your home and shut off automatically to protect the components of the television. Wait at least 30 seconds before turning the TV on again.
    Finally, if you suspect the television is turning off for a reason other than a power surge, unplug the television and let it sit for at least 10 minutes. This will clear any errors in the television. After 10 minutes, plug the television back into the outlet and resume normal use.
  • Blank Screen
  • A blank screen on an RCA rear projection television is usually caused by a loose connection or an incorrect setting. Check that the coaxial connection on the back of the television is secure or, if you're using an external device such as a DVD player, the video cables are secure. Press the "Ant/Cable" button to switch between tuners if you are watching television, or the "Input" button to switch between input channels if you're watching something from an external device.
Apr 21, 2012 | Proscan PS60690 60" Rear Projection...
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
RCA 52" rear projection tv
rscimeca,
This could literally be anything. I have a tip at http://www.fixya.com/support/r6396176-projection_tv_troubleshooting which will help you isolate the problem and tells you where to get the parts.
Thanks for using FixYa and for the great rating.
hardrocko
May 23, 2011 | RCA P52920BL 52" Rear Projection...
Antenna button not functioning on RCA300x universal remote
U have glitches in the reprograming back and forth.Take the battery out,about an hour.Reprograms the codes again,should work again.Don't reprograms the codes back and forth to many times or one times to many will kill the remote for good.U have 2 tvs,U should have 2 tvs remotes.
Jun 22, 2010 | RCA RCU300 Remote Control
I need to unlock the parental controls on the tv and i dont have a remote. i bought the tv used and i cant watch it
Try getting a universal remote that is compatible with that tv. Always look on the back of the remote packaging and it will tell whats compatible
Jan 10, 2010 | RCA Scenium D40W20 40" Rear Projection...
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
Help with tv
RCA controls everything from the remote control. Unfortunately you will need to purchase the original remote from the manufacturer or an authorized parts retail supplier. www.tritronicsinc.com
C-Dog
Jan 22, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Turns on and off
Best to call a service center to check it.
Sep 05, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Crazy menu, comes on periodically without using remote
believe it or noT: try replacing all of the switches on the control panel (((power button switch,menu button switch, etc...)))
Oct 27, 2006 | RCA HD52W56 52" Rear Projection HDTV
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
Electro Med Services...
