Door on washer does not unlock when wash is completed.Child lock is unlocked. Just purchased it yesterday
Left unplugged over night. This is supposed to take care of the problem.
Posted on Nov 24, 2008
The code cl keeps coming up and the washer will not shut off
CL is child lock. Press and hold the child lock button(maybe a key icon) for three seconds to unlock
Mar 23, 2015 | LG WM2455 Front Load Washer
Tip
My Miele washing machine is locked.
Recently I received many requests from users in troubles because they could not unlock their washing machine.
I decided to publish a tip illustrating the unlock procedure.
These instructions apply to most Miele front loading washing machines. They will work on all the W4800 series washers.
Instructions on how to set on and off your Miele’s child lock function are also contained in the user manual.
If you attempt to open the door while the Child Lock function is activated you will get the message "Machine locked" and the picture below on display:
If the door lock is locked during the wash cycle, press the pause button, and the door will open.
In order to deactivate the Child Lock:
  • Press and hold the "Heavy Soil" button until the display shows an unlocked pad lock picture and says Ready to Use (hold up to ten seconds, it should be less).
If you want to re-activate the Child Lock:
  • Press and hold the "Heavy Soil" again, until the display shows a locked pad lock picture and says Ready to Use .
The drum door cannot be opened, and the machine may stay locked if one of conditions below is occurring:
  1. The water temperature is more than 55°C (130°F).
  2. The water level is too high.
  3. The Child Lock function is activated.
  4. There is a fault.
If the washer is in one of the above conditions, you will get the machine locking even if child lock is off.
If the door is locked because of a fault, and there is water in the drum, the machine will also lock up.
In that case the door will open only after accessing the drain pump.
The pump service door is opened using a tool stored behind the dispenser drawer.
The tool must be used only after disconnecting power.
I think I will post a detailed procedure on how to fix a blocked drain pump on the next tip.
I hope this tip has helped you to fix your problem.
Goodbye.
on Dec 10, 2009 | Miele W4840 Front Load Washer
Whirlpool duet washer door will not unlock or complete the cycle
Wait at least three minutes after the end of the cycle before attempting to unlock your Whirlpool washer. The door will not unlock until the motor speed equals 0 and 180 seconds have elapsed since the motor control unit received the "Stop" command. If the water in the washer is warmer than 122 degrees Fahrenheit or the water level is set higher than Wool, Delicate or Hand Wash, the washer must drain before the door latch will unlock 2 Hold down the "Control Lock" button on your Whirlpool washer for three seconds at the end of the washing cycle. Listen, and when you hear the unlatching sound, the door should open.3 If your Whirlpool washer did not unlock at the end of Step 1, press and hold the "End of Cycle" button for five seconds to manually reset your washing machine.4 Unplug your Whirlpool washer and leave it unplugged for 45 minutes. After 45 minutes, plug your washer back in. The washer's programming should be reset and the door should open.5 Manually unlock the door of your Whirlpool washing machine. Make sure to unplug the appliance before completing the manual unlock. Use a screwdriver to remove the metal strip, called the toe panel, at the bottom of the washing machine. Once you've removed the toe panel, reach up inside the front panel of the washer and feel around for the door latch. Locate the tear-drop shaped tab at the bottom of the door latch and pull it gently. When you hear a click, the door should open.
  • Oct 13, 2011 | Whirlpool Washing Machines
    How do I manually unlock my samsung smart B12455 washing machine. I think the door lock is broken
    Child lock on n all the lights are on n it keeps beppen n door will not open can u help me please
    Mar 12, 2011 | Samsung B1245 Front Load Washer
    It would appear door has been locked via child
    press and hold the minimum iron button on the front panel until the child lock light goes out then you should be able to use the machine as normal
    Jun 01, 2010 | Dyson CRO1 Front Load Washer
    Duet GHW9150P Front Load Washer: HOW DO I UNLOCK MY WASHER...
    Depress the "end of cycle" button on your panel for 3 seconds, wait for 2 minutes, try the door. This is the child lock feature, do it again and it locks.
    Pl vote me nice, for the free help, thnks.
    May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Duet GHW9150P Front Load Washer: how do you unlock the control when it is locked...
    While the machine is on press "end of cycle" for 3 seconds, then wait for 2 minutes to try the door. Try this again if it does not open, this is the child lock program - to lock and unlock; it is the same procedure.
    Check your washer plug to see if the connections are tightly screwed.
    How abt a nice rating for the free help? Thnks
    May 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    Duet GHW9150P Front Load Washer: my door lock how rto unlock it...
    Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
    If helped, pl rate me good!!
    Washing Machines Logo
    65 people viewed this question
    Top Washing Machines Experts
    Marvin
    Marvin
