I have a honeywell mercury switch thermostat when turned down to 60 degrees still calls for heat? The current temperature is 72 degrees even when turned down. Do the older style thermostats have a way to trouble shoot them?
  • 833 Answers
Are you sure it is calling for heat?  Disconnect the stat and see if you still have system operation (Be careful if this is a line voltage unit).  If so, the stat is not bad, there is a problem with the relay or with the wiring to it.  If not, there is probably a short in the anticipator within the stat.  This is a heating coil which helps the unit figure out how much heat 'will' be coming when the contacts close. This cannot be repaired.
If you have a line voltage system, you can still obtain thermostats which run on them.  The better option is to put in a 24v relay system.  You can get advice on how to do that at any home store....about 30-40 dollars and then get one of the new programmable stats.  This will save energy and be more accurate. An energy star unit is a better bet anyway, it will save its cost in about a year.
Posted on Nov 23, 2008
Round honeywell thermostat
Sounds like you have a T86 thermostat...take the round front cover off to view the Mercury switch. Watch the bulb when you change the temperature to a higher setpoint. If the bulb makes contact when rotating it up, and the furnace doesn't go into a call for heat, then it could be the thermostat, wiring, or furnace problem.
Dec 13, 2013 | Honeywell Heating & Cooling
Have installed a new Honeywell thermostat. The fan does not turn off even when the room has reached the desired temperature. I originally replaced th ethermostat because the old one the fan ran forever and...
Most T-Stats have a On / Auto on a forced air system. On means the fan will run all the time even if it is not calling for heat. Auto only runs when calling for heat. Does the fan turn off in the auto mode at all? To test it...BE SURE THE FAN IS IN THE AUTO MODE ON THE T-STAT... Turn the thermostat all the way down and keep it there for appox 15 mins. If it is wired properly and the fan limit is set properly the fan should turn off. If it doesn't it is not the thermostat were the problem lies.
Most forced air units have a fan / high limit switch. There is a setting on the switch for the fan to turn on and a setting for the fan to turn off or it has a setting and a differental switch for it to turn off/on. Example - the fan comes on when the temp in the heat exchanger reaches 110 degrees F and will shut down at 95 degrees F after the thermostat is satified...this would hav a differental of 15 degrees F. It may be set to low and the fan continues to run long after all of the heat has been removed from the heat exchanger. This in turn will cause cool air to be coming out of the registers.
Mar 09, 2011 | Honeywell CT87B ROUND HEATING&COOLING...
My Honeywell Pro TH4110D Thermostat calls for heat before the temperature even drops 1 degree. This makes it cycle about every 5 minutes.
remove the front cover of thermostat and adjust the heat anticipator. increase one notch and test system. do this until system operates at a 2-3 degree temp drop or rise.
Nov 28, 2010 | Honeywell Programmable Thermostat Heater
My round Honeywell T-87 on the main floor(middle) of the house has no ON/OFF switch. It controls the temp of that level of the house and even though it is set at 60, the temp is way too high and reads 74....
What you are describing is the Heat Anticipator. It is a small resistor that helps the thermostat from overshooting the set temperature by heating up and shutting off the thermostat just before your set temperature. I don't think that is related to your over heat. 14 degrees is a lot and the Heat Anticipator will only effect it 4 or 5 degrees. I would remove the thermostat and check if there is a call for heat. If so, you have a shorted wire. If not, replace the thermostat.
Dec 30, 2009 | Honeywell Programmable Thermostat Heater
When this thermostat is in the HOLD position, which cancels the programmed feature, I set the temperature to 72 degrees and the furnace runs until that 72 degree temperature is obtained. Now the thermostat...
If you still have the instructions for the thermostat, then it will show you how to get into the menu and set the swing on the temps. I would try to explain off the top of my head, but its actually quite a bit off numbers to remember. Hope it helps somehow.
Dec 29, 2009 | Honeywell Focus 6300B 5-2 Days...
Honeywell TH8320u Vision Pro 8000 Digital keeps calling for heat
If the thermostat is not over shooting the temperature than don't worry about it.
These thermostats are very sensitive and will turn the heat back on even before the degrees drop on the display. Often they will shut down before the display changes also. You can change the sensitivity of the thermpstat if you read the directions and change the cycles per hour to a less number. There is an installers program in there that you need to push a combiunation of buttons to get too. The instructions tell you how to do that also.
Hopefully you did not throw away the instruction manual for your t-stat.. :-)
Dec 28, 2009 | Honeywell Programmable Thermostat Heater
The thermostats current setting does not match the current temperature and the heat will not turn on. the temperature is at 65 degrees, but the setting is at 72 degrees. the switch is set to heat and it...
Sounds like you have a problem with the furnace try turning the power off to the furnace and then turn it back on to see if this will get it to run. If it has a sight hole in the bottom door look to see if there is a flash code. then take off door and see what the flash code represents as the problem.
Dec 17, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
111 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
