Question about Kenmore Elite 45986 Front Load Washer
Knocking noise My Kenmore Washer Elite HE3, front loaded, makes a very loud knocking noise when it spins ?
Your problem may not be a broken spider assembly. My Kenmore Elite (model # 110-42822-203) had a kocking problem as well. After taking the back off, I discovered that the nut holding the pulley to the drum shaft (on the outside of the outer basket) was slightly loose. I simply re-tightened this an the knock went away. The pulley was shifting on the shaft ever so slightly, leading to the knock. Cost of fix: $0. :-).
Posted on Apr 05, 2009
    Problem Solver:
  • 5 Answers
I had the same problem with our Frigidaire front loader. Had to take the washer completely apart and traced the problem to broken two out of three arms that attach the basket to the shaft in the back that turns it. I had to purchase new basket for $200.00 and replace it by myself. If I had it replaced by service man, it would probably cost $400.00 or almost half of new machine.
There could be other, less expensive causes. There are springs and cables that counterweigh the weight of the basket. These springs sometime un-attach themselves due to the vibration of the machine. Simple re-attachment of these may correct the problem.
Any of these solutions require the washer to be opened and the exact cause diagnosed. Try not to use the washer untill it is repaired as continuing vibrations and banging will do more and more damage to the machine.
If you decide to do further investigation on your own, make sure the machine is unplugged before attempting to open the back covers!
Alex
Posted on Nov 23, 2008
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: My Kenmore Washer Elite HE3,
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Posted on Nov 09, 2010
Kenmore he3 dryer front load knocking noise
Check the tensioner pulley that keeps the belt tight. It is next to the motor and the bearing may be shot.
Mar 08, 2014 | Kenmore Dryers
My Kenmore Elite HE3 Mod 11044832 202 started making LOUD knocking noises during final spin cycle, then started to smell like something burning. Whit placis shreds in the washer.
the plastic is the drum has dropped so its eating a way the plastic on the back of the drum so no not worth fixing the mould is an easy fix just soke a cloth with neat bleach and leave over night make sure you do a rines after woulds as you don't want bleach on your cloths ok
Oct 21, 2012 | Kenmore 44832 Front Load Washer
heatman101
Nov 09, 2010 | Washing Machines
Kenmore Elite HE3 110.4586 makes a very loud, rapid knocking noise during the rinse cycle. The unit is balanced because it is not moving around.
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.(*&^%
Feb 13, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 front loader F-11 and FDL codes
yes!! the F/11 is triggered under high voltage conditions like high speed spinning. The part is called the MCU motor control unit. if it goes into failure while using your machine and locks the door, just wait 3 minutes and the door will unlock after the MCU resets. Try using you machine with a low speed spin for awhile.
Oct 29, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he3.on spin cycle makes lots of noise like a motor mount broke.
It could be that you are not setting the water level high enough when you do large loads.also the strap that holds the cement block could have come undone and now the block is unsecure.
Jul 18, 2009 | Kenmore Elite 45986 Front Load Washer
Check Pump on front loader kenmore HE3 elite
Remove the lower front panel 3 screws across the bottom. Pump will be behind this panel.
May 26, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore front loading HE3 makes knocking sounds during spin cycle
Ours started knocking several months ago and then progressed to a high pitched sound when in the spin cycle. I manually turned the drum and heard and felt a bearing roughness. I lifted the drum assembly and felt a fair amount of play, which I think the initial knocking noise came from. On the sears web site a new rear drum mount cost 293.00. Today we went and bought a LG model wm2455hw at Home depot, on sale until 2/20/08. I couldn't see paying to repair a machine that only lasted four years.
Feb 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
1,364 people viewed this question
Sal De
fordexpert
Robert Rankin
