Question about Compaq Presario M2000 Notebook
Alot of vertical lines on laptop screen
I have an older ibm laptop computer and when i turn it on all these different colored lines come on the screen, but when it is almost closed all the way everything looks as it should be what is the problem?
  • P. Thomas
    P. Thomas May 11, 2010
    inside the laptop cover, is a board and cable. one of them, or perhaps the screen itself is not working...happens when an older machine starts to shift..you may need to run an ext monitor from the connector in back
    President:
  • 2,992 Answers
This is due to the cable from the main board to the display. It comes up from the main board through one of the hinge covers, and the repeated flexing from many times opening and closing the lid causes the wires to break. As you say you've found out, in certain positions the wires make contact and the display works normally.
It might be possible to find a replacement cable, but the chances aren't great. For portable use you're out of luck, but you can connect an external monitor when you're at home.
Wish I could give more hope, but this cable problem was a always a pain when I was doing computer repairs for a living. You'd think manufacturers would have seen it coming and made a better design, or at least make replacement cables easy to come by.
Posted on Nov 23, 2008
My compaq presario m2000 lcd screen have vertical lines in different colors, how can i remove this vertical lines?
Take out battery from laptop and disconnect power cable. Keep the power button pressed for 30 seconds and then plug the power cable. This will remove static charge from laptop and should resolve the display issue,
Nov 20, 2011 | Compaq Presario M2000 Notebook
I HAVE VERTICAL LINES ON MY SCREEN
What is happening to your laptop is the power line connecting a row of pixels is failing so only partial colors are showing up causing the vertical lines. Usually screen replacement is the only answer to fix it. You can usually find replacement LCD on Ebay.
Feb 01, 2011 | IBM ThinkPad R52 Notebook
Thin vertical yellow line and a white vertical line appeared on ibm thinkcenter r52
Jan 10, 2011 | IBM ThinkPad R52 Notebook
Vertical lines on screen
What is happening to your laptop is the power line connecting a few rows of pixels are failing so only partial colors are showing up causing the vertical lines. Usually screen replacement is the only answer to fix it. You can usually find replacement LCD on Ebay.
Jan 05, 2011 | IBM ThinkPad R52 Notebook
The screen is full of thin lines of different colors and couple of white vertical bands where no characters are visible
you may need to resolder the chipset at service. or just reinstall the driver if works in "safe mode".
Aug 08, 2010 | IBM ThinkPad R51 Notebook
My Ibm Laptop r51 has a vertical lines on the screen
The lines appearing on your LCD means it has a defect on the screen.
There are 3 types of pixel defect
1) dead pixel - pixel is always off
2) stuck pixel - pixel is always on
3) hot pixel - pixel is on but in red, green, blue or yellow, can also be a light black color
You can try to fix stuck or hot pixels but dead is dead.
1st method, flashing different colors rapidly:
JSScreenfix.com has a great tool. This is their free java applet or you can download it below.
2nd method, applying pressure to pixel:
Damp paper towel, Small stylus or dull pencil.
3rd method, tapping the pixel:
Pen with cover on or another small, blunt object.
If your laptop is still under warranty, get it replaced. If not you are looking at the most expensive part in a laptop to get replaced. (LCD screens on laptop is roughly equivalent to 40-60% of the total laptop cost
Please rate this if it this helps.
Jun 02, 2009 | IBM ThinkPad R51 Notebook
IBM A31 2652 Video garbled video at boot
This is very possibly a hardware problem, namely a crack in the motherboard. Sorry, no easy or cheap fix for it if that's the case.
Feb 18, 2009 | IBM ThinkPad T42 Notebook
update monitor driver
your screen may be going
how old is the system
Jan 26, 2009 | IBM ThinkPad A31 Notebook
IBM T30 Screen Problems
More likely than a cracked screen was a bad connector. Having a band (vertical or horizontal) of random lines and colrs is typical of a bad connector. Odd as it may sound, you can try to diagnose whether this is really the case by squeezing carefully (not too hard) around the edges of the screen. On many different models you will find that when you get to a certain spot and squeeze lightly the problem will change or even disappear temporarily. For the more adventruous you can also try lightly twisting the casing. I've had this work on dozens of machines with similar symptoms.
Sep 25, 2007 | IBM ThinkPad T30 2366 Notebook
Compaq Presario M2000 Notebook Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
