Question about Whirlpool 24 in. GU2500 XTP Built-in Dishwasher
Cycle buttons work, option buttons dont, Cant deselect heated dry, Wont start
Dishwasher is 2 years old. When I select a cycle, normal,accusense,light,pots & pans etc. these buttons work as far as changing the light above the selection. However the heated dry button stays lit all the time(cannot deselect it) nor will start/resume or cancel drain do anything either. After the cycle selection is on for a couple minutes everything goes blank.I can select normal again and heated dry lights up but it will not start. I have cheched the door latch switch to be good. What next? Thanks.
  • Eddie private May 06, 2007
    Replaced main front control panel
  • Eddie private Aug 14, 2007
    vellay, I had to replace the whole main control panel . The piece at the top that has the selection buttons on it. U cannot get just the inside u have to get the whole thing in the right color. Its not hard to take out and replace. Thats what fixed mine. I think like $96 from Whirpool.
I had the same symptoms and the front panel was the fix
the part with the buttons on it
Posted on Oct 12, 2011
The part is covered by warranty. However, the labor is not and Whirlpool will not replace the part without having someone service the unit. Every place I checked wanted $100 just to come out and tell me what was wrong. Any service would be extra. Seems like Whirlpool figured out how not to stand behind its products. They should be held accountable.
Posted on Jun 11, 2008
SOURCE:
Model #DU1015XTXS2
With the dishwasher door closed and the unit in standby mode or with no cycle selected and all lights off, press - heated-dry, normal, heated-dry, normal buttons in that sequence. Then press cancel..... wait until 2 minute cycle is done. Open and close the door and make sure it is closed. Then run another cycle.
Apr 06, 2014 | Whirlpool Dishwashers
How to reset a Kenmore 668.1687582 dishwasher
Yes, depending on the model, and the buttons that your dishwasher has, try the following key sequences:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry). You will know that you have entered the diagnostic cycle when all the lights light up for a few seconds.
On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 03, 2012 | Kenmore 24 in. 15142 Built-in Dishwasher
What if my dishwasher will not start
push and hold the heated dry for 5 secs,,,, then try again
Nov 14, 2011 | Maytag MDB7100AWB Dishwasher
I am locked out of cycle with clean light blinking green and cannot find my manual, dishwasher is about 1 year old. Is there a sequence to break this cycle? I turned off power for 60 seconds to no avail.
Hi
I have not seen this model in Australia, but normally if you hold down "Start/Stop" button for 3 to 5 seconds, that should clear the cycle.
Otherwise if you have a Clear button press that for 3-5 seconds.
Ash
Sep 06, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Kenmore elite dishwasher - setting the default wash
Select the desired cycle. If you want to run the last cycle that
was completed, you can simply press START once to show which
options you used, then press START again to start that same cycle.
Jan 25, 2018 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore dishwasher ultra was quiet guard 3 model 56516012403 control panel will not activate red lights blinking on normal wash and cancel drain. did the hold the heat dry button then the normal wash...
that would be model # 66516012403 correct??
you may have inadvertently set the lock on function..
check this out from your manual...
Lock On
Use the Lock On to prevent unintended use of the dishwasher
between cycles. You can also use the lock feature to prevent
unintended cycle or option changes during a cycle.
When LOCK ON is lit, all buttons are disabled.
NOTE: The dishwasher door can be opened while the controls
are locked. However, the lock must be turned off and the Start/
Resume button pressed to resume the cycle.
To turn on the Lock
Press and hold HEATED DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light
flashes 3 times.
NOTE: If the Heated Dry option is selected, the light will
temporarily turn off until Lock On glows.
To turn off the Lock
Press and hold HEATED DRY for 4 seconds. The light turns off.
hope this helps,
best of luck,
ttfn
Oct 25, 2009 | Kenmore 15912 Built-in Dishwasher
Whirlpool Dishwasher won't drain during normal cycle
As you say a clogged line or valve does not make sense.
Try running it without the heated drying and see if it empties or if the cancel button will work then.
The dishes should air dry quickly if you empty it and open the door.
It could be a defective thermostat allowing it to get too hot during the heat cycle
May 18, 2009 | Dishwashers
Two Green Lights Flash Mid Cycle.
It's possible that there's a fault in the drying heater coil, but I couldn't tell you for sure without looking up your machine. If you could locate the model number tag on your machine and write down the exact model number and serial number, then I could likely give you a more informative answer. ;)
Aug 08, 2007 | Kenmore 24 in. 15252 / 15254 / 15259...
Whirlpool 24 in. GU2500 XTP Built-in Dishwasher Logo
392 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
