Last week my power locks went out, 2 days ago my cruise control stopped working, and yesterday leaving work i noticed none of the guages on my dash were working all the warning lights work fine just my speedometer, odometer, tachometer, and gas gauges stopped working. i dont know if any of these problems are related i dont know much about cars but i checked my fuses and those are fine. if anyone could help me resolve this issue it would be greatly appreciated.
Sounds like the body control module has gone bad. It has a relay that caries considerable current to all of these accesories and wears out.
It can also be a solder joint on the circuit board where this relay mounts.
Hope this helps, Robert
Notorious ignition switch failure sounds like. my dash was flashing and every thing was working and then not.
SOURCE: Gauges, Power Windows, Auto Lamps radio interior lights dont work
Sounds like an ignition switch problem, maybe even at the key.
SOURCE: speedometer, gas gauge, odometer, rpm gauge not working
My gas guage, speed odometer and tempiture does not work
The speed odometre is reading 9999999 what should i do
SOURCE: Speedometer/ Fuel Gauge & Tachometer not working
check for loose connection at the instrument cluster.
sounds like your missing a ground somewhere.
