Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Lamp reset I am tryijng to reset my lamp for our PT-45LC12 Panasonic TV. I try the Vol - and click on the PIP and Split button but nothing is happening?
  • Anonymous Nov 27, 2008
    the tv keeps turning off
    i can turn back on
Pushing the - volume button on the tv and split above the play button at the same time for ten seconds or - volume on the tv and the split control button at the same time. The lamp reset message should come on.
Posted on Nov 24, 2008
Where is the lamp reset button on my panasonic PT-50LC13
To reset the lamp on the Tv you need to Hold down vol - on tv and hit either PIP or SPLIT on remote Good Luck
Nov 12, 2010 | Panasonic PT-50LC13 50" Rear Projection...
How do i reset lamp hour meter
Turn On tv.
While pressing the VOL- button on the projection display, hold down the PIP or SPLIT button on the remote control simultaneously for more than 5 seconds.
This will reset lamp timer in Panasonic PT-43LC14
When the lamp time reset procedure is complete, the Lamp Time is Reset screen will appear.
Thanks.
Feb 05, 2010 | Panasonic PT-43LC14 43" Rear Projection...
Resetting lamp hour meter on panasonic tv
press volume down on tv and pip or split on remote
Nov 19, 2009 | Panasonic PT-56DLX25 56" HDTV
Need to reset hour lamp meter and held soen vol.-
Try holding down vol down on the TV and PIP/ play botton on the remote for 7 seconds. Their customer support should be able to help you too.
Oct 08, 2009 | Panasonic PT-43LC14 43" Rear Projection...
How do i reser the lamp meter after i replace the
Panasonic TY-LA1000 TV Lamp Reset Procedure/instructions:
Per numerous members, it looks like this method works quite well:
  • Hold the Vol down button on the TV and the Split button on the REMOTE for five seconds, -or- Press the Volume button on the TV while pressing hte SPLIT button on the Remote Control for five seconds
  • It will NOT work if you try to do it both from your remote!
Sep 16, 2009 | Panasonic PT-60LC14 60" Rear Projection...
How to reset the lamp for pt-45lc12
With power on, hold down VOL minus button on projection display and hold down the PIP or SPLIT button (try both) on the remote simultaneously for more than 5 seconds.
Jul 25, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Panasonic PT-52LCX66 Television lamp reset time
With tv 0n press vol- (minus) on tv and hold. then hold 0 on remote hold both for about 5 sec.
Feb 22, 2009 | Panasonic PT-52LCX66 Projection Television
How to reset the meter of lamp
You need to have your Panasonic remote.
1. Make sure the power cord is plugged into a properly grounded outlet and turn on the set with the power button on the projection unit or the remote control.
2. While holding down the (VOL -) key on the projection unit press the PIP or SPLIT key at the same time. Hold it for longer than 5 Seconds. The PIP or SPLIT key is model specific:
PIP for Models:
PT-50LC13/PT-60LC13/PT-50LCX63/
PT-60LCX63/PT-43LCX64/
PT-50LCX64/PT-60LCX64
SPLIT for Models:
PT-43LC14/PT-50LC14/PT-60LC14
3. When the unit resets the lamp timer it will display a screen on the TV indicating it was reset to zero. You press recall on the remote to exit.
You will find a PDF of the instructions at this site:
http://fixyourdlp.com/blog/wp-content/uploads/2007/09/panasonic-tyla1000-lamp-instructions.pdf
Aug 23, 2008 | Panasonic PT-50LC13 50" Rear Projection...
Resetting lamp replacement warning
Turn the TV on and press recall to clear the warning. Then hold down the volume " - " button on the tv and the PIP (Play) button on the remote for ~ 5 sec
Apr 03, 2008 | Panasonic PT-45LC12 45" Rear Projection...
Lamp meter on Panasonic PT-40LC12 ?
I just had my picture go out two weeks ago. I took it to a local tv repair shop. They replaced the thermal fuse. I also had a spare lamp so they also replaced that. I'm not sure if they reset the lamp meter but this is what I found surfing around...try at your own risk. I'm going to try this when I go home tonight.
Good Luck...
Press the power button to turn the unit on.
While pressing the Vol-(volume down) button on the projection display,
hold down the PIP button on the remote control at the same time for more
than 5 seconds. When the reset procedure is complete the following message
will appear on the screen. "Lamp time was reset to 0".
Mar 16, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
99 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
