Question about Cameras
Hi. I own a film Minolta X700 SLR and the frame advance lever will only go 30 degrees, but won't go the rest of the way to advance the frame. Also, when I push the button to take the picture, the picture won't take. What's wrong with my camera?
You have no battery
Posted on Jul 21, 2009
  • 10,319 Answers
Go to http://www.twid.de/x700/
He may help you out
Posted on May 23, 2009
Canon EOS Rebel T2 - film loaded, but then wouldn't take a picture, the frame count was flashing on screen. What is the problem?
Hi. Open the camera back and pull the film further over towards the pick up spool, close the back and try again to take a photo, i had the same problem with an eos 650 and it always worked.Good luck.
Apr 15, 2014 | Canon EOS Rebel T2 with 28-90 lens 35mm...
I just bought a nice used Mamiya twin lens C3 but the shutter is locked up. There is a small metal piece holding the shutter release from moving. Not sure how to un-lock, seams to be a safety device of...
The vertical shutter sliding lever gets locked if the film doesn't get advanced to the next frame, and the mode selector is set for single exposure. You can't trip the shutter unless you have film in the camera and you forward the film to the next frame. That should allow you to release the shutter with the sliding lever.
Mar 17, 2014 | Mamiya Cameras
Everything seems to function well, actually, I've never used this camera. Got if off of ebay, so maybe I was gypped. Anyways, the film advance lever seems to be stuck. It only goes half way. I can put...
If the lever won't advance even when there is no film in the camera, then I would say there is a problem. (p.s. You haven't told us the make and model)
May 29, 2011 | Cameras
I have a pentax 67 camera and the film advance lever is jammed. it will not advance without putting undo pressure on it which i am not willing to do. i have read many forums that have said this is not an...
Try pressing the film release button on the underside of the camera. This should unstick the advance roller.
If possible, replace the watch battery for your camera (inserted in the bottom, right by the teeny black button I mentioned above).
Change your exposure setting to Bulb exposure and back.
If all else fails, take your camera into the darkroom (or at least a completely light-insulated closet, bathroom, etc.), and pop open the back and recover your film. Hopefully you won't have too much wasted film on your hands.
Good on you, however, for not forcing the lever. Nothing good will come of that.
May 06, 2011 | Cameras
I have been offered a SiGMA 400mm F/5.6 manual lens for a minolta mount. Will it fit my camera? Cheers Pete
Minolta had two lens mounts. One for manual focus SLR film cameras and one for Auto Focus SLR Maxxum film and digital SLR cameras. Sony uses Minolta Maxxum lens mount.
If the Sigma 400 f5.6 lens was made for Minolta X-700 series, XG, series, XD series, SRT series, then it will not fit on your camera.
Jun 17, 2010 | Sony Alpha DSLR-A200K Digital Camera
Minolta x370 camera, the shutter appears to be stuck ? the film advance lever will not move ?
if you are up to repairing the camera yourself, you may want to remove the film first but cutting it from the lock then rewinding it to the tube (make sure you are in a dark room)...
then move to the small article below...
from PointBreak:
The BIG Minolta Shutter Problem Fix Secret EXPOSED!
The Minolta X-Series have been infamous for having their shutters "stuck" and without the film advancing. The LEDS will light up correctly but the film just wouldn't plain advance when you hit the shutter release button. Frustrating to say the least..but alas..alll is not lost. This has been a very common problem and I'll tell you why.
The X-Series, and other possible makers, contains a/an electrolytical capacitor with 1000 hrs of working voltage. When the capacitor reaches its limit it may fail (bulge/corrode). Whether this was an intentional design concept by Minolta is unknown..yeah right! Basically these capacitors hold a small magnetic charge and that when you hit the shutter release it reverses polarity and allows the film to expose, advance, blah, blah, blah..
OK! What I'm going to explain here will save you anywhere from $10 - $200 (meaning you could buy this info. on Ebay or take your X370 to get fixed at a shop). Vendors on Ebay are hocking this info. from $5 and on up..some are actually bidding on this stuff..DON'T DO IT! They will tell you that it's impossible to locate their "product" which consists of new capacitors and the service/repair manual. Well it took some time and research but I have located everything you need so..
Here it is and ENJOY!
1. Download the X370 manuals from http://www.geocities.com/eskoufos/fmm.html. Cost: FREE!
2. Go to http://www.digikey.com/digihome.html. The part number for the capacitor for the Minolta X370 is: P954-ND (Panasonic P/N is ECE-A0GKS221). The actual spec. on the capacitor is: 4v 220uF @ 85 deg. C(entigrade) (6.3X5X2.5 mm).Cost: $7.00 (includes S/H, min. order was 10 pieces @ $2.00 and they charge $5 for S/H)
3. Unscrew the bottom of the camera (4 little screws) and locate the bad capacitor. It's probablu bulging or leaking.
4. If you don't have one, you need a soldering pen and some standard electrical solder. (Go to Radio Shack or any Hardware store)
5. Remove the old capacitor and then solder on a new capacitor. That's it!
if you have other question just lemme know.
Sep 19, 2008 | Cameras
Nikon FM: Shutter release button will not allow me to take another photo and I'm only on frame 15 of a roll of 24. The film advance lever does not move the film, but it does open all the way to the right...
The FM is a mechanical camera, the batteries only power the metering system. Sometimes what happens is when you buy film say in 4 roll packages, they give you 3 24 exps and a 12 exp. I suggest that you rewind the roll and check this. You will only lose the last frames if the roll is indeed a 24 exp.
Jun 08, 2008 | Nikon Cameras
Minolta 7000 SLR
The Konica-Minolta 5d, and 7d, both discontinued but available used on ebay and other places will work with your AF lenses, as well as all the sony alpha camera bodies. KM sold their camera business to sony, and most of the whole maxuum/alpha/dynax group of engineers went with the sale to Sony. I had a 7000, and an 8000i, and all my lenses are quite happy on the 7D I picked up a few months ago on ebay.
Mar 27, 2008 | Konica Minolta Maxxum 7D / Dynax 7D...
What is the rate of continuous advance?
The speed is selectable from 3 types at the continuous advance. Continuous advance: Single shot AF: max. 1.8 fps (live view and anti-shake are activated for each frame. TIFF image cannot be taken), continuous AF: max. 1.9 fps (live view, AF, AE, anti-shake are activated for each frame. TIFF image cannot be taken.) Hi-Speed continuous advance: max. 2.7 fps (Anti-shake is activated for each frame. AF, AE, WB, and live view are fixed at the first frame. TIFF image cannot be taken.) UHS continuous advance: 7 fps. (Image size is fixed at 640x480. AF, AE, and WB are fixed at the first frame. TIFF and RAW image cannot be taken. Digital zoom disabled.) Actual speed may vary depending on the subjects and shooting conditions. * Three frames can be taken continuously in normal and Hi continuous mode. *In UHS mode, the images can be taken as much as possible to the limitation of the storage capacity. For reference, STD: 180 frames, FINE: 160 frames, X. FINE: 100 frames (approx.).
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
Cameras Logo
107 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
