Question about Inland (08304) 4-Port USB Hub
What is this small round hole for???
I just bought an "Inland USB 2.0 Mini 4 Port Hub" today. The model # is MC702639.
It is silver and has the obvious 4 USB plug receptacles on the side. On one end of the rectangle unit, the wire is attached that I am to connect (plug into) my computer..., also obvious.
At the other end of the rectangle unit there is small hole that appears to be  for some sort of other plug. Since I didn't get any instructions for this unit and there is no mention of this "whole" My questions is, am I missing something?? What is this socket used for.
Thank you
  • dark_knig810 Nov 23, 2008
    Mr. Guru,
    YOU ARE THE MAN!!!!!
    Thank you so VERY much for responding to an "END user" like me. I didn't really expect to get any response and yet..., here you are.
    Though I am the Dark_Knight....., YOU sir, are a Knight in good standing...., and I salute you.
    Holidays too you Sir.
    PS: The Hub unit works fine..., I was just wondering
  • 928 Answers
Although i have not seen your device specifically i looked it up and that unit if I am not mistaken has an option to plug a switching power adapter on it IF and only IF in case you might need it to power on additional devices. Some USB devices need more power than normal hence the adapter but any device that runs on its own power and small USB devices dont need such power then you do not need the external adapter ( Sold separately and not by the same company) Basically you are not missing anything dont worry if the unit works as it should then you are ok.
If you need further assistance just message me.
Posted on Nov 23, 2008
  • 78 Answers
AC power adapter plug. Not normally needed.
Regester my product for warranty
I'm guessing here : http://inlandus.com/warranty.html
Sep 10, 2014 | Inland Computer Accessories Inland 08818...
Inland 7 port usb 2 hub, inconsistent connection
Delete all the Usb Root hubs from the device manager and restart the computer
Sep 05, 2008 | Inland (08304) 4-Port USB Hub
Why my siyoteam 4 port usb 2.0 high speed hub not working in windows 8 hp laptop. i plug the port into the laptop but it cannot been seen in my pc, is there any thing can i do inorder this usb hub to work...
Perhaps the laptop port is designed for a usb 3.0 insert instead of a usb 2.0? Also try using compressed air to clean both connections. The hub male end and the laptop female end.
Oct 31, 2013 | Universal Genuine SIYOTEAM 4-Port USB 2.0...
Just bought an Ativa 7 port USB 2.0 Hub and don't know how to connect it to my computer. No manual came with it.
The ones that I have seen have 7 ports 5 in back 2 on top these are called Type A USB ports, to the left of the back ports the power port is there. To the right, there is a smaller port usually a USB Mini B or Micro A port that is where the small end plugs into and the Type A on the cable goes to your computer.
Jan 12, 2013 | Computers & Internet
Install 4 port USB hub
plug the cable that came with the hub into the computer, plug the other end into the hub (probably a usb mini port). Now plug in any devices into the hub.
Nov 17, 2012 | Star Logic 4Port USB Hub
I purchased a DYNEX USB 2.0 Port Hub last week. I have 2 computers and want to have both of them hooked up to the same printer. I purchased 2 A >A USB cables and the printer is still not working. I...
in either computer have you set the printer to default so that each computer knows where to send the data
you may also have to have the computers on a home network for it to work
the hub by itself is not the answer
Jun 03, 2017 | Dynex 4-Port USB 2.0 Hub
Where can I find a power supply for the Encore ENU-4USB 4-port external mimi USB hub?
The power supply is a 5 VDC, 500 mA (outer negative, inner positive) commonly used for mp3 players, but probably you must cut the mini usb plug and adapt a compatible jack with the hub.
Jan 14, 2011 | Encore ENU-4USB 4-Port External Mini USB...
I have several computers at home, and none og them can recognize this portable device. Hitachi 250 GB Mod: SDM/250RW
1) Power:
It may be the problem that occurs with a lot of USB powered devices jrherrer. Not enough power provided.
The USB cable plugged into the computer, provides signal wires for transferring information back, and forth, and also provides 5 Volts DC for power. (Two D cell flashlight batteries produce 3 Volts DC)
http://en.wikipedia.org/wiki/USB
[ Below shows the Signal pins, and the Voltage pins of the USB B Mini style connector, (Male), used to connect to the SimpleDrive Mini external harddrive,
Pin 1 is for the 5 Volts DC Positive (Wire color - Red)
Pin 2 is for the D- Signal (Wire color - White)
Pin 3 is for the D+ Signal (Wire color - Green)
Pin 4 is not connected. (Or sometimes joined to Pin 5 with a Resistor)
Pin 5 is for the Ground (Wire color - Black)
Just added info in case you wanted to know ]
From what I see the SDM/250RW has a USB port on the side, and a DC Power Jack, used for an AC adapter, also.
(Round port with a pin in the center)
http://www.hitachigst.com/tech/techlib.nsf/techdocs/0C876B7AB91B23988825773F006BEA02/$file/SD_Mini_DS_final.pdf
From what I see stated from Hitachi, and sellers on the 'net, the AC adapter may not be provided.
Many of those who provide a review state that both the USB cable, and the AC adapter is needed to provide enough power. Seems to be a power hungry external harddrive
It's a 2.5 Hitachi SATA laptop harddrive inside that external case. (The Harddrive is 2 and a half inches across in Width. Common size used for laptops)
When using an external device powered by a USB cable there are general guidelines to follow,
A) The USB cable should not be more than 2 feet in length
B) Connect the device directly to your computer, instead of through a hub, or other device, unless the USB hub has it's own power.
2) USB cable:
Could be a faulty USB cable, although I imagine you have tried different ones by now.
3) Interface Circuit Board:
The Hitachi SATA 2.5 harddrive inside the SImpleDrive Mini SDM/250RW, plugs into a small circuit board located inside that external case.
Components on the circuit board may be fried, or the Harddrive may have come loose from the interface.
Loose from the interface
To explain;
The back of the harddrive has connector pins sticking out.
The interface has socket holes which the pins insert into.
Faulty circuit board
The external case of the SimpleDrive Mini SDM/250RW can be carefully opened up, and the Hitachi SATA 2.5 harddrive extracted out.
Another inexpensive external case for a 2.5 SATA harddrive can be procured, and the Hitachi harddrive put in it.
Example of a 2.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3743049&CatId=2781
Nov 22, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
Inland (08304) 4-Port USB Hub Logo
340 people viewed this question
Top Inland Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
David Payne
David Payne
richie46
Are you an Inland Computer and Internet Expert? Answer questions, earn points and help others
