Question about HP Office Equipment & Supplies
My HP7580 all in one has a paper jam. One sheet went through and misfed and a corner of the paper ripped off and did not eject with the main sheet. I can't find the scrap of paper that tore off and no other sheets will feed through. I have opened the top half of the copier and do not see the scrap of paper. It appears to be stuck in the paper tray feeder.
I finally found the door on the back of the printer and opened it. The paper was easy to remove at this point. However I would like to say that nowhere in your manual that came with the printer does it show this door nor does the trouble shooting info tell about it. It should think this is something that you would consider adding to the manual!
Posted on Nov 24, 2008
How to clear a paper jam in the document feeder
Open the covers and remove the jammed sheet. ALL the pieces have to come out if you rip it while removing it. A little corner of paper left behind can trigger a sensor to show a jam.
Aug 13, 2014 | Office Equipment & Supplies
The paper keeps jamming, I cant see anything in the way. any help is appreciated.
If paper doesn't feed correctly when printing, remove it and fan the edges of the paper to separate the sheets. Reload the paper against the right side and slide the edge guide against it. Do not load too many sheets at once.
If paper has jammed: 1. Press x Start to eject the jammed paper. 2. If paper is still jammed, gently pull it out from the output tray or sheet feeder. If paper is stuck inside, press the P On button to turn off the printer. Then lift the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the printer back on.
If documents don't feed correctly in the Automatic Document Feeder, make sure the corners of the paper are not bent, folded, or curled up. Do not load more than 10 sheets of legal-size paper at a time. If documents have jammed: 1. Open the ADF cover and pull any paper out to the left. Caution: Do not try to remove the paper without opening the ADF cover first, or you could damage the mechanism. 2. Select Yes or press OK to clear any messages on the display screen. 3. Reload the paper.
Feb 28, 2011 | Epson WorkForce 600 All-In-One InkJet...
Have Kyocero 2050. Error - Misfeed paper - Open Left Cover and remove misfed sheet. Jam 00. I opened left-side cover and found no sheets stuck anywhere in sight. I can't find Jam 00 definition in...
I was having the same problem with the same model and same error. Then I discovered there's an extra panel you can pull out of the side - it's not the one the display is indicating, it's the one all the way on the side. When you pull on the grey level and it comes down, keep pul;ling on the grey level because ANOTHER panel comes down under that and I found some paper jammed in there. Once I removed it it worked fine.
Dec 13, 2010 | Kyocera Mita KM-2050 Printer
Showing misfed paper @ U1 U2, paper jam out, but still showing misfed.Checked and all paper is out. How can this be reset? Thanks
in the machine can be a little fragment from a sheet of paper so watch careful it can be right on the sensor for registration please open all doors and close them again.
But for i to be able to help you more you will need to tell me what brand is the machine and which is the model
Jul 15, 2009 | Office Equipment & Supplies
I am getting an error on my Samsung SCX 6320 saying that there is a paper jam when there is no visible paper in the machine. It had jammed, I removed the paper with no tears or rips, but it still has the...
its may be the problem related to Two causes....
pls. check the Main Frame paper feeding gear was brokned or not ?
check the paper exit Pully in the exit area....
Jul 09, 2009 | Samsung SCX-6320F All-In-One Laser Printer
Jamms paper when copying
hi,make it clear where is the location paper jam?how to know follow this steps:-
1.make one copy & where the paper is stoped?
2.clean the area or clear misfed sheets.
May 14, 2009 | Canon Office Equipment & Supplies
MISFED INDICATOR LIGHT FLASHING
There is no code to run.
Did the paper come out as an entire sheet? Or was it torn? There is either a small piece of paper that remains in the machine, or you dislodged a paper switch in removing the jam.
Apr 23, 2009 | Sharp AL 1631 Copier
HP 1320 will not power up
There actually was a misfed sheet, hidden at the very bottom of the lower hinged back panel. The reason it was misfed was that this panel had somehow gone off one of its hinges. Ironically I did not discover the misfed sheet until I had taken the printer down from its shelf and turned it over to read the serial number to the extended warranty tech support guy.
Moral: Open every panel carefully, check for misalignment. These printers have flimsy plastic parts.
Dec 13, 2008 | HP LaserJet 1320 Printer
Misfeed error
1. Check that absolutely no paper is jammed within the infeed paper sensors. Sometimes a tiny piece of paper will get stuck in the sensor after a jammed sheet has been forcibly removed.
2. Use a can of Dust-Off or similar compressed air product to blow the paper path out. Paper lint can block a sensor.
Feb 23, 2008 | Ricoh 6513 Copier
Paper Jam Error Message
I would try to clean the tires with alcohol, it's probably trying to pick up the other sheet but is slipping.
take out the tray and look inside for the pick-up and seperation tires.
Oct 06, 2007 | HP OfficeJet 6110 All-In-One InkJet...
145 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
