Question about Thermos Grill2Go Gas Grill 4656110
Not Hot! Hello! We have a Thermos Grill 2 Go gas BBQ given to us as a promo item without warranty info and its been in the cupboard four a couple of years as when we tried to use it it didnt get hot enough to cook a sausage! The flames stayed really small - we'd like to get it going properly,any tips? thanks Alison
  • bobmarti Jan 21, 2009
    My grill to go also doesn't get hot enough to cook on. I have discovered that the thermostat dial needs to be pushed down to get a better flow of gas to come through. Try lighting it without the plate on top when it is dark. You should be able to distinguish when the flames are highest and where the dial is. Mine doesn't line up with the marks but when I push down the top of the plastic dial it lets more gas out and the flame would be sufficient to better heat up the plate. I am trying to purchase another thermostat dial but am having trouble locating a Victorian distributor. Maybe someone may be able to help me with an address to buy spare parts.
  • MONKEYT Jan 28, 2009
    Not much more I can say - my problem is the same as the other two people above. I've tried modifying the regulator, but it seems to be down to the amount of gas flowing through the (tyre tube) type of valve within the regulator?
I am in New Zealand and have the same problem however my gas repair shop advised that these machines are designed for HIGH PRESSURE gas bottles and not the ones used in Australia & NZ - we have been well & truly conned into buying these as they will not work down here & the firms selling them need reporting..
Posted on Oct 20, 2009
We have had two grills that developed similar problems after sitting for a length of time and found that an insect had built a nest in the tubing leading from the regulator. A piece of pipe cleaner up the tube fixed the problem. Can't say if your's is the same problem but it is worth checking.
Posted on May 04, 2009
Please tell me I can still find a regulator for a Thermos grill2go grill
gas regulators can be obtained from any gas shop or BBQ shops
the regulator for the unit will be made by a regulator maker and will not need to be genuine
Sep 27, 2015 | Thermos Grilling
How do I replace ignitor switch in thermos gas grill, if this is what is what I saw?
If that white is ceramic, I think it is the actual ignitor, not the switch.
Apr 29, 2017 | Thermos Stainless Steel Gas Grill
We have permasteel gas BBQ grill. grill can be lighted up, but gradually died off. It seems that no enough gas pressure and flows. The regulator gets iceing and cold.
too much gas passing from reg causing freezing of gas reg or line or check for gas leak on reg , reg could be stuck open again too much gas pasing .
Jul 04, 2012 | Thermos Stainless Steel Gas Grill
Not enough flame and when i change the settings
it sounds like the reg off the gas bottle or blocked burner
May 15, 2010 | Thermos Grill2Go Gas Grill 4656110
Need a catcher for the fat off of the bbq grill
Go on line to Thermos grills and you should be able to order one there.
Apr 12, 2010 | Thermos Grill2Go Gas Grill 4656110
BBQ gas leaking from regulator vent
tou will have to cut off the hose at the crimp point a drimel wors real well then buy a new regulator and hose and automotive hose clamps 3/16 is best
Aug 02, 2009 | Thermos Stainless Steel Gas Grill
Need some parts
Hello. Most hardware stores will have replacement parts which work on all grills. good luck .
Feb 04, 2009 | Thermos Grill2Go Gas Grill 4656110
Thermos Grill2Go Gas Grill 4656110 Logo
316 people viewed this question
Top Thermos Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
kc5133
Level 1 Expert
Are you a Thermos Grilling Expert? Answer questions, earn points and help others
