Question about Refrigerators
Leaky fridge I noticed the bottom of my frige filling up with water. Along the back side smack dab in the middle is a stream of water-not a lot but over time it collects and I have to use towels to get the water out. I have a top mount freezer with an auto ice make attached. It's a frigidare 20.5 c feet
  • 1 more comment
  • dethrasher Dec 30, 2008
    I have the same problem but no ice maker - where is the hose & how do I get to it?
  • doctor g Jan 16, 2009
    i have a leak in my fridge that collects inside, the condensation either drips or when i turn up the temp. it freezes in upper back of the inside. it drips all through the fridge and then collects on the floor. this is an old model whirlpool with no icemaker, what can i do?
  • Anonymous Feb 21, 2009
    same problem. how do i get to the hose?
I have a frigidair with ice maker. the plastic line that goes in ice maker came out and ran water on floor. I cut the line back and reinserted it but it leaks and rund down line to floor. shoul i use a sealer of some kind. Bill
Posted on Mar 08, 2009
  • 833 Answers
This is defrost condensate.  You have a hose going to a tray below the box that is blocked.  Rod it out with soft wire or similar.  Clean the condenser while you're in there!
Posted on Nov 23, 2008
Frige part bottom shelves get frozen water and ice dosent work
This is a known problem. Samsung knows about this and if you call them they may come out and fix it for free. Otherwise, the water tanks are frozen along with everything else. Unplug the machine. Take the vegetable/salad draws out and you will see the water tank. You need to unscrew this and lay it against the inside of the fridge. Now remove the lower half inside back panel by the six screws, two will be behind the vent like plastic covers. Unplug the two juction boxes and remove the back cover. You will find that everthing is frozen, take a hairdryer to the lot of it including the drain away hole at the bottom of the lower half. re asemble and all should be ok......until the next time. Ensure you completely unfreeze the drain away or you will get water leaks.
Jan 26, 2014 | Samsung Refrigerators
Water is frozen in fill cup inside the ice maker
Put your frozen food in a cold place.Unplug the fridge, leave the freezer door open for 12 hours. Dont mess with hair dryers
Jan 30, 2013 | GE GSS25LGM Side by Side Refrigerator
Frige/freezer side by side water leaking at bottom freezer door.
your freezer is in defrost for sone reason,how old is it/has it being giving trouble latly.replace or call an engineer,it might be cheaper to replace.adrian,,,,
Jul 13, 2010 | GE Refrigerators
Water is streaming out the bottom of my fridge on freezer side
the water should evaporate when hitting the coils,maybe coils s/b cleaned (dusty)
Mar 17, 2010 | Refrigerators
Water collects under bottom draws of frige
At the back of the fridge, inside, there should be a drip tray / channel which slopes towards the middle from both sides. At the middle you will find an outlet hole to the rear probably blocked. Clear with match or cocktail stick and the water drains away to an evaporation pad or container [often over the compressor]
Mar 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water dispenser in door front is leaking.
The water inlet solenoid is bad. Unplug frige. Follow inlet line to back of frige to part. Replace part.
Nov 04, 2009 | Kenmore Refrigerators
Ge fridge, water and ice on the door ,, all of a sudden the waterstopped working on the door ,, but it still makes ice
There is a double water valve in the back of your frige that your water supply connects to at the bottom. You will need to replace this valve. It will have your water supply connect on one end and two lines connected to the other. You can test it to be sure by doing this. Disconnect the two lines that are on one side. Using a towel to catch the water, have someone push the leaver in the front of your frige that you push when you want water. If the valve is good water will come out at the pressure you normally have when you are filling a glass from the front. If it does not come out, you will need to replace the valve.
Aug 15, 2009 | GE Refrigerators
Defrosts/refreezes
IF YOU TAKE THE BACK PANEL OFF INSIDE THE FREEZER YOU WILL FIND A PIECE OF METAL UNDER THE EVAPORATOR COILS IN MIDDLE OF THIS METAL PAN IS A HOLE THAT LEADS THE WATER TO THE BOTTOM OF THE REF FOR EVAPORATION THE HOLE IN THE PAN IS PROBABLY PLUGGED TAKE THE ICE OUT AND CLEAR THER HOLE
Aug 11, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
I opened the door on this frig this morning and water poured out like a small river! It filled the frig, and leaked below into the basement. Horrible! I noticed the water streaming out of the built-in...
obviously a filter leak. the water shuts off when the filter is removed. either it wasn't installed properly or it has a bad gasket. as for the fridge getting warm, the water probably collected and froze to the evaporator coils and now resrticts the cold air flow. you need to turn off the fridge, empty it out, leave the freezer door open, and let the coils defrost on their own. or remove the back panel in the freezer and defrost the coils with a hair dryer. you will need to soak up some water, but not nearly as much. once it's defrosted, dry it out, close the doors and turn it on while it's empty. when it's cold enough, replace the food.
Jul 31, 2009 | GE Profile PSC23MGTBB Counter Depth Side...
Leaking water inside from top back of frige ?
if your fridge has a cold wall system then on the bottom is a v shaped gulley with a hole in middle check this drian hole is not blocked.
Jun 06, 2009 | Whirlpool GR9SHMXLB / GR9SHMXLL Top...
Refrigerators Logo
212 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
