Question about Akai DVDRW120 DVD Recorder
DVDRW120 My player has switched modes halfway through a show, and now I cannot see the screen. Can somone please send me/post what the first page looks lik when you hit the setup menu? I have to try and rectify it without a screen... Thanks
  • Dave Smuts Dec 27, 2006
    Does anyone know where I can find a copy of the User Manual online?
    Thanks
I have no remote control akai dvdrw120, someone I could provide a model to be able to locate.
Posted on Jan 26, 2008
Sandisk mp3 freezes
Try and reset the player. Reset the player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. Then try this Connect the player to your computer. The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is available. Make sure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the players screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. <<<<< BUT TRY THIS ALSO >>>>> Check the Device Manager 1. Right-click My Computer, and select -- > Manage. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. *** See This Tip Posted here **** --> http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem <-- Copy this address into a new window. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. >>>> BUT TRY THIS <<<<<<< Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Verifying and changing the USB mode of the device to MSC or MTP From the Main Menu, select Settings > USB Mode.
Mar 04, 2010 | SanDisk Sansa e200 MP3 Player
Computer does not show entire contents of mp3 player.
Albums that have been put on the player in Windows Media Player in MTP (Media Transfer Protocol) mode can be viewed in the Microsoft Media Player.
Hidden music can be viewed in MSC mode when switching the player into this mode, viewing the player as a removable disk. Warning: when switching the player into MSC mode be sure to go through safely remove hardware, the icon in the right corner of the computer's screen.
How to switch to MSC mode, have a view in the manual. Select your version player online from the support page:
http://kb.sandisk.com/app/answers/detail/a_id/4487/session/L3NpZC9zc25DSURWag%3D%3D/sno/0#c200
More information about hidden files in the operating system on the computer, see next link:
http://kb.sandisk.com/app/answers/detail/a_id/447/kw/hidden%20files/r_id/101834
When needing more help, just add a comment in this thread.
Feb 27, 2010 | SanDisk Sansa c250 (2 GB) MP3 Player...
When turned on the screen displayed FAT is
First try to reset the player 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. Next try to switch USB modes 1. Turn the player OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the player to the PC. If none of these things work try and format the player - You will lose all your music - sorry -- For your Clip: 1. From the Main Menu, select Settings > Format. 2. Select Yes. You can also format using Media Player -> start Media Player **** If you have Media Player 10 --- Connect the Sansa player to the PC in MTP mode (Previous step USB mode). Click on the Sync tab.( be sure your player shows in the pull down menu) Click the pencil icon on the upper right corner of the window. Click OK to start formatting. ***** Now if you have Media Player 11--- Click the Sync tab. On the left panel, look for the player. It is usually the last device listed. Right-click on the player and select Format Click OK to format.
Jan 23, 2010 | SanDisk Sansa Clip MP3 Player
I cannot access the music on my Samsa M230 via USB to PC. I would like to copy the music off the sansa and add new music, but windows media player doest show any music files on the m230 drive
There are 2 modes the player can connect to a computer:
1. MSC mode: the operating system, seeing the player as a removable disk on "My Computer"
2. MTP mode: added software, when an extra program is started the player is detected in this application software: e.g. Windows Media Player
When songs show up on the player but not on My Computer:
1. The player is in MSC mode and music has been put on the player with a program in MTP mode
or
2. The player is in MTP mode and music has been put on the player
using Windows Explorer in My Computer in MSC mode
In your case the solution should be:
Switch the player into MSC mode and look in Windows Explorer for
a driver letter with a capacity of about 512MB memory.
How to get the player in MSC mode:
Using the menu on the player:
From the main menu go to Settings Menu > USB and select MSC mode.
Using the hold switch on the player:
1. Turn device OFF.
2. Facing the hold switch slide it to the right so an orange color would show putting the device on Hold.
3. Connect the device to the PC.
Explore "My Computer", looking for the players content showing up as a drive letter (about 512 MB sized for the m230)
Click the drive letter, select your files and "copy + save" or "drag and drop" them to a location on the computer.
When needing more help, just post a comment.
Dec 30, 2009 | SanDisk Sansa m230 MP3 Player
My sansa clip has maxed out space and won't turn on
Sandisk has an Answers support site for the Sandisk players.
Searching for answers on the item space, links to next page:
http://kb.sandisk.com/app/answers/list/kw/space/r_id/101834/search
The first answer on not enough space for musicDB will give 2 options for deleting files, see next page:
http://kb.sandisk.com/app/answers/detail/a_id/848
Option 1 for normally erasing files.
Deleting selected files:
http://kb.sandisk.com/app/answers/detail/a_id/41
Method 1: deleting files on the player itself .
Method 2: deleting files when connected to a computer
when using method 2, switching USB mode from MTP to MSC or vice versa may be needed to see the files in the folders.
Information about the problem "hidden files", see:
How to change the USB mode of the player, see:
http://kb.sandisk.com/app/answers/detail/a_id/207
Option 2, erasing all files on purpose or when memory is corrupted .
Formatting the device, deleting all files:
http://kb.sandisk.com/app/answers/detail/a_id/107
This help page shows how to perform a format of the player using
disk management. The player has to be in MSC mode when performing
this action.
How to switch to MSC mode is mentioned before, see link:
Manual for the Sansa Clip in pdf format:
http://mp3support.sandisk.com/sansa/UserManual/CLIP/CLIP_UM_English.pdf
When more help is needed, just post a comment.
Nov 20, 2009 | SanDisk Sansa e250 MP3 Player
No sound
HEY CAN ANYONE HELP A LADY IN DISTRESS
Apr 21, 2008 | Computers & Internet
Shuts off & on over & over again
noavatar_s.png socker
Rank:expert_s.gif Guide
Rating: 91%, 79 votes
Add to Buddies atbqm.gif mine too i was mad :\ just got it fixed like 2 min. ago im1.gif soooooooooooo happy
thank GOd
___________________________
I have the EXACT same problem and my device is stuck in MSD. Which two files are you talking about? My sandisk support rep did not send me any attachment.
Thank you for contacting SanDisk Technical Support.
We should be able to fix your player. Disconnect the player from the computer4.gif if it is connected.
Please copy and paste the following link into your web browser address bar, and then click Go or hit your Enter key. When prompted, choose the option to Save the file to your Desktop1.gif.
http://www.sandisk.com/Assets/File/Downl...
Once you have downloaded the file, please follow these instructions.
1) Double click on My Computer so that you can see it on your screen.
2) Turn the player off.
3) On the top of the player is a Hold switch, move it to the right (toward the headphone jack) so you see Orange.
4) On the left hand side of the player is a Record button, press and hold it while connecting the player to the computer. Continue holding the Record button until you see a new icon under My Computer called 16MB FORMAT. Once you see that icon you may release the Record button.
5) Double click the file you downloaded earlier and run it. Follow all of the on-screen instructions, and when you get to the prompt where it asks you whether you would like to Format it, choose Yes. Once it is done, click Finish.
6) Disconnect the player and look at the screen. Several things will be displayed, and when you see Key Lock, System1.gif Shutdown, move the Hold switch on the top back to the left.
7) Turn the player on and watch the screen. If you see a Refresh Database1.gif Fail error, you will need to follow steps 1-7 again until you do not get the error. If it does not work the first time, it could take up to 3 times for it to work.
Was this solution helpful? Show your Appreciation by rating it:
Jan 11, 2008 | SanDisk Sansa e260 MP3 Player
Akai DVDRW120 DVD Recorder Logo
104 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
