Question about Maytag Neptune MDG5500AW Gas Dryer
Ringer at end of drying session
When the clothes are dry the ringer will not stop ringing unless you open the door. How do you turn off the ringer so it does not ring at all?
  • elizabethspa Nov 25, 2008
    could not find the diagram on the back of the computer
    I could not find the diagram on the back of the dryer...
  • 833 Answers
Find the diagram on the back of the unit.  Trace the wire.  Cut and tape it.
Posted on Nov 23, 2008
  • Robert Hirst Nov 26, 2008
    I don't have the specific schematic required.  What you can do is locate the buzzer...likely in the timer/dial area on top of the unit.  It will have two wires coming into it.  If you set it up as such, you can make the buzzer buzz at the end of a load and observe it.  Break one of the wires after cutting the power.  You may install a switch if you wish or simply cut and tape the wire.  You will do no damage to the dryer by cutting that wire.
I have a Meridian 9316 phone in my office and it continuously rings with no pause how to I stop the ringing besides from turning the volume off
Setting the ring tone and ringer volume You can choose one of the four different ring tones and set the ringer volume. To set the ring tone and volume: 1. Make sure that the ringer is turned ON. 2. Press the Set Options key. 3. Press the down arrow three times or press [3] to go directly to the item. 4. Press [3] and follow the instructions on the display. When picking the ring tone, press the volume bar to adjust the volume. 5. Press [Save] to end when you are satisfied with the ring tone and ringer volume.
Apr 30, 2015 | Nortel Meridian 9316CW - 1 Line...
How to take off silent mode? I never programmed it to do this...
See if this helps
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high)
separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or
VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume
louder. Use on the handset or VOLUME on the base to make it softer or
turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Oct 17, 2014 | Uniden DECT 6.0 Cordless Telephone...
My phone stopped ringing
You may have turned your volume very low or you may have muted your phone (turned off the ringer). Check your volume and ringer settings.
Jun 24, 2014 | Kyocera Cell Phones
Need ringer on uniden ex14246
With the phone in standby mode (not talking, not doing something in the menu, etc), press vol-up or vol-down. The phone will sound the different ring tones at different volumes. To turn the ringer off,
select "Ringer Off". When the phone sounds the ring tone and volume you wish to use, press the end key.
Oct 14, 2011 | Uniden 2.4 GHz Cordless Phone System
Somehow the ringer got turned off. Can't figure
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
Sep 12, 2011 | Uniden Lands Phones
Uniden Model EX 14560 Ringer off How to put ringer on
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume
Your phone has five different ringer tone/volume combinations you can choose from.
To select the ringer:
1) With the phone in standby, press [vol/ / ] or [vol/ / ].
2) The phone will sound the different ring tones at different volumes. To turn the ringer
off, select RINGER OFF.
3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer
If the handset is off the base while an incoming call is ringing, simply press [end] to mute
the incoming ring. The ringer will sound with the next incoming call.
Note: You can only mute the handset ringer if the handset is off the base when the phone starts
ringing.
Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
May 18, 2011 | Uniden Cordless Phone
CAN THIS PHONE RINGER BE CUT OFF
To cutoff ringer volume in Vtech cordless phones,you have to turn off the base ringer.
Handset:
program button->up/down" key to cycle until you see the Ringer selection->up/down" key(s) to cycle until the OFF selection
Base Ringer:
Menu->press menu until you hear "Base Ringer, to change base ringer press change"->PLAY/STOP button to save
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Jul 25, 2010 | Vtech IA5854 5.8 GHz Cordless Phone
Can't hear phone ringing
Adjusting the Ringer Volume (From the Uniden manual)
  1. With the phone in standby, press ArrowUp or Arrow Down on the handset or VOLUME + or VOLUME - on the base. The handset or base sounds the ringer at that level.
  2. Use Arrow Up on the handset or VOLUME + on the base to make the ringer volume louder.
  3. Use Arrow Down on the handset or VOLUME - on the base to make it softer or turn it completely off.
  4. When you hear the ringer volume level you want to use, stop pressing keys.
  5. The handset or base will use the new ringer volume starting with the next incoming call.
  6. If you set the ringer volume to Off, the handset or base won’t ring.
  7. Other handsets or base will ring according to their individual settings.
Jan 03, 2010 | Uniden DECT 6.0 Cordless Telephone...
The ringer is turned off on my Cirrus 100 (onetel) telephone
I have the OT100 & to turn ringer off & on you press & hold down the * key until the phone beeps
Sep 02, 2009 | Lands Phones
How to inactivate melody ringer
Base unit ringer tone
(use either the handset or the base unit)
Make sure the base unit is not being used.
Setting the base unit ringer tone by using the
4 Select the desired ringer tone by pressing [d]
or [B].
• The handset will ring and the ringer tone will
change. If the ringer volume has been turned off,
the handset will not ring
• You can also select the ringer tone by pressing [1]
to [7].
5 Press Save, then press [OFF].
Press VOLUME [<] or [>], then select the desired ringer tone by pressing
[1] to [7].
[1] to [3] : Bell ringer patterns [4] to [7] : Melody patterns
• After pressing VOLUME [<] or [>], the base unit will ring using the current ringer
tone.
• The base unit will ring and the ringer tone will change.
• To stop ringing, press [STOP].
1 Press [MENU].
2 Scroll to “Initial setting” by pressing [d] or [B], then press
Select.
3 Scroll to “Set base unit” by pressing [d] or [B], then press Select.
4 Press Select at “Ringer tone”.
5 Select the desired ringer tone by pressing [d] or [B].
• The base unit will ring and the ringer tone will change. If the base unit ringer
volume has been turned off, the base unit will not ring
• You can also select the ringer tone by pressing [1] to [7].
6 Press Save, then press [OFF].
This Can Be Found On Page 17 And 18 Of The User Guide.
If You Do Not Have The User Guide It Can Be Downloaded Here
http://support.radioshack.com/support_phones/doc73/73355.pdf
Thank You For Choosing Fixya.com
Dec 21, 2008 | Panasonic KX-TG2357 Cordless Phone
Maytag Neptune MDG5500AW Gas Dryer Logo
78 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
