Question about Acer Computers & Internet
My acer laptop keys are sticking and to hard to push down. I need to replace them how do I do that?
  • P. Thomas
    P. Thomas May 11, 2010
    get a new keyboard from acer.com and then you can remove the small panel at top of keyboard, if you gently pry the cover off on one end(there should be a recessed tab on one end). be careful, cause that can snap easily.
    there should be some small phillips head screws holding down the keyboard. remove and keep them safe somewhere(like a plastic bag)
    then, gently lift up the keyboard. there will be a cable holding it to the motherboard, with a specific kind of clamp. carefully open that clamp
    lift..reverse the flow.
    by the way, careful about static. these areas are highly susceptible to static from your hands. usually a qualified tech would do this with a ******** one wrists.
    Hope that helps you.
  • Acer Master
  • 4,806 Answers
No they don't need replacing they just need cleaning, you can remove the panel that goes accross the top of the keyboard (above the F keys) if you remove this panel you can remove the keyboard too, it is connect to the laptop with a ribbon cable that you can remove. when the keyboard is free all you have to do is run it under warm water (not hot) and clean the keys gently with washing up liqiud that you use for the dishes, keep on running warm water on it until the keys are free (you may have to repeat this process if the sticking persists) Now for the important part, you have to leave the keyboard to dry for at least 24-48 hours in a warm dry room before you can put it back in, press on the keys periodically to make sure they are free
regards
Posted on Nov 23, 2008
Took acer 6733Z-4633 to tech. it wouldn't boot up. he said hard drive bad. he was able to save pictures and some files to USB. now I need to replace hard drive. sent for Acer recovery discs. if I cant...
when your laptop starts if it has F12 option push that and install your first disc and choose boot from cd player then follow instructions
if you dont have the F12 option when you puch the power button toggle the F2 key and go to boot menu and choose the cd player as first boot option and then hit F10 and save install boot disc and follow instructions
Aug 18, 2013 | Acer Computers & Internet
Can't logon to my acer laptop it says the following, the user profile service failed the logon user profile cannot be loaded
Shut down your computer. To do a hard shutdown hold the power button down until it turns off. You probably need it to go to last known good configuration. To to this 1. find the F8 key (keep finger on it(not pushed yet). 2. Turn Power button on and immediately start tapping F8 key. This will take you to a screen with many options; Last Known Good Configuration is one of them. It should start up. Hope this helps.
Apr 27, 2013 | Acer Computers & Internet
ACER ASPIRE laptop PgUbp key came off.
Unless I'm missing something, just put the key back where it belongs. Push down hard, and it'll snap back into its place. If this doesn't work, check the underside of the key. If you see broken plastic, you'll probably have to find a new key. Acer laptops seem to have a problem with keys coming out and breaking (just look at the number of times this question has been asked!)
hope this helps
Apr 06, 2011 | Acer 90.46907.001 Keyboard
Laptop key popped out!
Have you tried pushing the key back on the blank spot hard? Usually it will clip itself back on.
Mar 11, 2010 | Acer Aspire One PC Notebook
How to put a key back on my acer laptop that popped off
Provided the small plastic hinges are still in place just put the key back in position and gently press the key until the key clicks and locks onto the hinges.
Sep 21, 2009 | Acer TravelMate 2300 Notebook
Just need to know how to insert a new memory stick I bought for my dinosaur 3000. Fry's salesman said I could find a step-by-step instruction. THX!
Dinosaur, as in a old acer aspire 3000 or what?
Most likely two screws on the bottom of the laptop that hold the memory cover closed, inside you will find 1-2 memory modules, you may have to remove one of the old ones and then install the new one, or if one is free install the new one there.
Sep 11, 2009 | Acer Aspire 3000 Notebook
My Acer Aspire 1710 failed to boot and no Acer logo
use my acer aspire daily, went to put a memory stick in and it just died, no power at all but power light on charger still showing green
Feb 01, 2009 | Acer Aspire 1710 Notebook
Reattach Acer Aspire laptop Key?
they just clip on.put key back in place and push down firmly.you may have to wiggle it a bit back an forth.
Mar 02, 2008 | Acer Aspire 5500 5570-2609 Laptop
I spilt my drink on my laptop keyboard...
you can pull the keys out of their sockets and wipe the rubber and plastic holders with a wet cloth. but be very carefull to cloth should not leak, just be wet to dissolve and absorbe the sugar and other stuff that stick the keys. then just insert the keys in the sockets
Nov 25, 2007 | Acer NSK8458AN Keyboard
ACER 3680 KEYBOARD
there are many many different keyboard designs, it is hard to make a suggestion...usually if it looks like nothing is broken on the key or keyboard you push down firmly and it snaps back into place.
Oct 03, 2007 | Acer Aspire 3680 Laptop
Computers & Internet Logo
202 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
