Question about Creative Labs Zen Neeon MP3 Player
Zen Neon 6 gb
The screen comes on with the flash of colors but no software loads. I can connect it the computer and load songs on. I have formatted the hard drive and updated the firmware.
I have reset it, but it stays on the green screen .
Please help.
Did chkds no errors
Am I suppose to load additional software on to it.
Thanks karen
  • 3 Answers
SOURCE: Middle of a firmware updated bricked my Zen TOuch
This solution is from another post, and it was how I recovered from the same problem. "I had the same problem and the solution is documented on the Creative labs message boards. This happens if you upgrade the firmware with a computer that has media player 11, Which KILLS your Zentouch. (Thanks Creative!!) The solution, as partially noted by the other poster, is to rollback Media Player to version 10 AND to eliminate all traces of Creative software on your PC. Reboot, then plug in the Zen, it will be regognized by MP10, and then run the firmware upgrade software. I found it easier to do this by using a different computer rather than uninstalling software from mine. After this WMP 11 does work."
Posted on Oct 08, 2007
SOURCE: Reloading Firmware on Zen Sleek Photo
This is what I found. Windows Media Player 11 messes it up. All you have to do is uninstall anything Windows Media Player 11 and then run the firmware upgrader. It's some sort of but. You can reinstall WMP when your done installing the firmware. I found it on the creative forum.
Posted on Jan 16, 2008
SOURCE: firmware error on creative zen
Check your LAN settings by going to Internet Options, select "connections" then LAN settings, then check the box that says "automatically detect settings". Click okay, and that should fix your problem. You have that have those options enabled to let some common programs detect your internet connectivity.
waseem E-mail- joy_munna11@yahoo.co.in
Posted on Jun 23, 2008
SOURCE: Creative Zen:M 30gb. In recovery mode and HD only shows 50MB!
I have the same problem and I don't know anything :(
Posted on Nov 19, 2008
  • 4 Answers
SOURCE: firmware problem for zen vision M
I had the same issue with my zen vision m. It was not recognized on any computer (although it would charge) and I noticed that when I turned it on after having it off for any amount of time, the zen would rebuild half way before turning on.
If this is what is happening with you, then this one solution I found to fix it:
Download the MP3 Recovery Tool from Creative Support website. Make sure that your Zen is charged at least half.   Turn on your Zen, Holding the power switch in the on position (Very Important!). While holding the Power switch on, Reset the Zen by inserting a small object in the Reset hole on the bottom of the Zen (small objects can include thumbtack, wire, earring, etc...). You will see a menu: Clean Up, Format, Reload OS/Firmware, Reboot. (It is now safe to stop holding the Power switch) I decided to go down the list until something worked.  I ran Clean Up first and that didn't work for me, so I tried Format.  It will remove all of your data. Once Format runs, Reboot the MP3 player and plug it up to the computer. Run MP3 Recovery Tool. The firmware should should install itself on your MP3. Once installed, your computer should recognize the Zen.
I hope this helps!
Posted on Nov 29, 2008
I bought a 1 gb ipopd but cannot load more than 10
1gb of memory is not a lot when it comes to videos. 1 gigabyte is roughly 1000 megabytes and a movie can take up 850 megabytes! Make the videos are a format it can play and that they're the right size to play on that screen. You can download free video resizers.
Sep 20, 2009 | SanDisk Audio Players & Recorders
Need a manual or instructions how to operate it
experimental status
ZEN mozaic player 2 GB
firmware 1.03
ZEN attached to USB 2.0
Windows XP SP2
Message "do not disconnect"
ZEN is not being recognized
Check ZEN memory setting
Memory ZEN is set to 0 in MENU>Etras>removable disk
Memory ZEN should be changed to maximum 1.5 GB
ZEN is recognized now
ZEN is ready to do the format command
ZEN can be written to for a maximum of 0.5 GB [internal memory !]
ALERT ! This 0.5 GB is the internal memory
The files written to the internal memory will be erased after
disconnecting !
access status
NO ACCES TO MY ZEN ?
1) Get access to ZEN by setting disk memory to maximum
2) ZEN should be recognized now
format status
1) FORMAT the disk
After formatting !
SET BACK YOUR disk memory capacity to zero [ 0 ]
for fully recovering the disk capacity
files presence status
FILES NOT PRESENT AFTER DISCONNECTING ?
- When set to zero you can use the full memory for
writing files to the player !
- When keeping the memory set to maximum you're using
the internal memory and written files are not saved
after disconnecting
updating + files presence status
UPDATING FIRMWARE ZEN MOZAIC = MAKING STANDARD MAPS
1) download the firmware that is suited for your computer
Operating System and your type of player from "CREATIVE"
2) Connect player to USB 2.0
and update with the firmware-update
3) Wait until the update is fully completed
4) After the update disconnect the player
5) Connect to USB 2.0 again
6) Check for the presence of the STANDARD MAPS for Music,
Pictures and Video
7) Files can be written into the STANDARD MAPS
8) Written files should be present after disconnecting
9) Files ready for mobile playing on ZEN mozaic now
CREATIVE support site for fimware / software / userguide
SUPPORT FOR ZEN MOZAIC ON THE INTERNET
http://support.creative.com/Products/ProductDetails.aspx?catID=213&CatName=MP3+Players&subCatID=214&subCatName=ZEN&prodID=17897&prodName=ZEN+Mozaic
May 10, 2009 | Creative Labs Creative Technology Zen MP3...
Can u help me with my creative zen mp3 2 gb ?
It depends sometimes some songs may be copyrighted and cannot be played on the Mp3............ But as u say ur able to play 67 songs............ Just format your Mp3 player...... Formatting the Mp3 Player: Connect the Mp3 player to the Computer.......... Go to My Computer> Right click on the Removable Disk and click on Format and click on Start..... Know reload all the songs back to the Mp3 player..... Good Luck............
Dec 29, 2008 | Creative Labs Zen V MP3 Player
Creative Zen 4 gig doesn't start when I click on its icon
Have you tried removing the software or reinstalling it? Don't worry about the 3GB of music, you won't lose it UNLESS you reformat your Zen.
Oct 10, 2008 | Creative Labs Zen Digital Media Player
I just buy creative zen stone 1gb
OPEN AN EXPLORER WINDOW LIKE MY COMPUTER, UNDER THE TOOLS TAB CHOSE THE FOLDER OPTION, CLICK ON VIEW GO DOWN AND U WILL SEE THE SETTING SHOW HIDDEN FILES CLICK THAT OPTION CLOSED THE EXPLORER WINDOW AND THEN REOPEN TO SEE IF U CAN ACCESS THE FILES
Aug 05, 2008 | Electronics - Others
HELP! Zen Creative Sleek Photo 20 gb
What you have to do is flash the firmware. And this is another huge problem. If you have WMP 11 you have to downgrade/uninstall it from you computer or use a computer that doesn't have it on.
Next connect your MP3 player after you have:
1. cleaned it
2. formated it
(you get to the recovery menu by holding play/pause sign and inserting a paper clip into the reset orifice.
Once it is recognized a menu will pop up asking you if you want to do various things, one of them is to sync or add files to your player using WMP 9 or 10, depending on the machine you have. CLICK that option.
Next you have to run the firmware application provided on the Creative website and that will flash your player with the firmware. It should work fine afterwards.
Make a backup of of the files if you care about them before you start this adventure.
Jul 06, 2008 | Creative Labs ZEN SLEEK MP3 Player
Creative Zen V Plus Frozen on the product title screen
this helped me as after it rebuilds the libary then it always froze on a song let the battery run out!
this worked for me straight away and i had tried loads of other ideas this actually came from the tech guys !!!
  1. Detach the player from the PC if it is connected, and turn off the player.
  2. Press and hold the Play button while powering on the player.
  3. When the player displays the Creative logo, release the Play button
  4. Select Format (All) and select Yes to format the player.
  5. After the player has finished formatting, select Reboot.
  6. Re-transfer the tracks to the player.
Feb 16, 2008 | Creative Labs ZEN V Plus MP3 Player
Cant load songs
the best way for that is to read your manual.
MINIMUM SYSTEM REQUIREMENTS
Windows XP SP1
Windows Media Player 10
Intel Pentium class PC or higher
CD-ROM drive
USB 2.0 port required for hi-speed transfer
CONNECTING AND TRANSFERRING
Connect to your Computer
1. Connect the small USB Cable Connector to the USB port on your computer, and then plug the larger
Cable Dock Connector in to your Sansa c200 port.
2. Once connected to computer, it should be detected by the operating system automatically and is
shown as an additional drive called “Sansa c200”.
SANSA MEDIA CONVERTER
You will need to use Sansa Media Converter to transfer photos to your Sansa c200. Insert your SanDisk
CD and select Sansa Media Converter to install it to your PC. Then you can load your personal photos
onto your Sansa c200 by using Sansa Media Converter.
TRANSFER MUSIC
To transfer music to your Sansa c200:
1. Connect Sansa c200 to the computer.
2. Drag and drop files from your computer to Sansa c200 by using a variety of music software
programs to transfer/synchronize your files.
3. In MTP mode as long as the files are WMA or MP3, they can be dragged into the Media folder.
Otherwise, they can be dragged into the Data folder (these files will not appear on the player).
4. In MSC mode, files/folders can be dragged/copied to the device.
Jan 27, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
My computer won't recognize my creative zen 60 gb mp3 player
you have to format it only
this can through connect device
right click overtheir
and format it
Nov 15, 2007 | Audio Players & Recorders
RCA Lyra RD2317
Remember when you format memory like a hard drive you erase everything. Move music to your internal mp3 memory and do a profile - folders should appear. If you have flashed your player with the firmware update you can get 520 songs on the player for both internal and external combined but be warned that if you exceed this count your player will start to forget the earlier loaded songs - listed but not addressable (playable). The same is for the folder count eg. add album = artist + ablum title (min 2 folders). Plus always profile your songs after loading new music or deleting as this is an index build process to play song 152 = title x. This includes accidental radio recordings to MP3s. RD2312 , RD2315, RD2317 Lyra™ mp3 flash player Firmware/Application Upgrade Version 3.11 fixes:
  • Supports a total of 520 songs, in up to 50 folders, with up to 8 levels of subfolders.
Aug 06, 2007 | RCA Lyra RD2317 (1 GB) MP3 Player
Creative Labs Zen Neeon MP3 Player Logo
63 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
