Question about Coleman 5040-751 BackHome Open Flame Patio Heater
Patio heater tip switch doesn't let gas through
I can get the pilot to light by pushing in but as soon as I release the valve it shuts off. I took it apart and the valve routes gas where its supposed to with the tip switch coil removed. With it installed there is no gas to the main valve or pilot unless the valve is held in. The switch and weight itself appears to be fine and the coil is not frozen but the coil does not stay open.Looking at the wiring it looks like pressing the ignitor is supposed to supply current to open it but I can't figure out what is supposed to keep it open since it is spring loaded and there is no power to keep it energized in the heater.
  • Anonymous Nov 23, 2008
    I moved the heater and cannot get it to light now. I think I tipped it too much.
  • skiplawwill Feb 07, 2009
There is a thermocouple that protrudes up into the flame. If the thermocouple is bad or out of adjustment it will not produce enough electric current to lock the red knob down allowing the heater go into operating mode. This thermocouple is a safety device that senses weather there is a flame or not. If no flame no heat don't turn on. If heat then there must be flame OK turn on. The thermocouple should protrude into the flame about an inch to heat it sufficiently to trigger the valve if it doesn't adjust it into the flame more. If adjusting does no good replace it. Take the old thermocouple to the store you bought the heater at and get a replacement. If you cant get it there almost all hardware stores or heating stores will have generic replacements that will also work.
Posted on Oct 23, 2009
    New Friend:
  • 92 Answers
It sounds like what you are describing is a bad pilot saftey device there is a device called a thermacouple when heated it creates a small electric current which lets main valve know its ok to open we have a pilot flame.the thermacouple normally screws onto gas valve it is 2 spade connectors it is a powerpyle system
Posted on Apr 15, 2009
Schematic patio heater sunjoy g ph018pss
You will not be able to blow through a gas valve when it's disconnected. You may have air in the lines which would cause the pilot to go off when knob is released if not held in long enough. Try lighting again. Once the pilot lights - hold knob in for 5 minutes then release. Try twice, if pilot will not stay lit it's probably the thermal coupler. (metal prong right next to flame of pilot burner.)
Mar 13, 2014 | Heating & Cooling
On my patio heater the pilot light will light but goes out as soon as I release it, even after holding it down a long time. I can't get it to stay on to light the heater.
Check that the pilot light is directed at the thermocouple, a copper 'tube' that heats up when the pilot light is lit. You should be able to see a copper coloured small tube that the pilot light is directed at - if the pilot flame is not heating that tube then the main burner will not light.
If the thermocouple is being heated correctly, then it could be a fault with the thermocouple itself (can be replaced) or the gas valve.
If the pilot flame is not heating the end of the thermocouple you should be able to adjust its position so that the pilot flame is directed at it more accurately
Jan 18, 2011 | Rta International Patio Heater
I go thru the process of lighting the pilot light following the directions exactly, but as soon as I let the pilot light switch pop out so that I can turn it to the left to light the heater the flame goes...
The system works off of a thermocouple that is heated by the pilot. The thermocouple creates millivolts that magnetize a head behind the control knob. When you push in the knob the magnetized head behind the knob holds the gas valve open. So obviously the head is not being magnetized. First make sure that the pilot is not plugged and the flame is large enough to heat the thermocouple. Also sometimes you may need to hold the knob for several minutes before the pilot will stay on. Also patio heaters have a safety feature that will cut the millivolt circuit if the heater falls over. It is possible that this safety device is tripped or defective causing the pilot to not stay lit. Also check for any loose wires on the millivolt system.
Dec 21, 2009 | Endless Summer UniFlame (GWU501E) Open...
The pilot light will not stay lit to light the heater.
The power pile (pilot generator) is defective. It produces a milivolt signal to ensure to keep the gas valve open. If it goes bad, the valve thinks the pilot is out, even when you are holding the button down, so when you release the button, it shuts the gas off to prevent excess gas buildup and a possible explosion.
Sep 10, 2009 | Coleman (5040B750) Patio Heater
Patio comfort heater won't light
Sometimes you have to completely disassemble the pilot assembly to clear the blockage, the orifice for the pilot jet is very small and you can not get directly to it unless you take it apart. If this does not help, you may need a new valve.
Jul 12, 2009 | Stainless Patio Comfort Natural Gas Steel...
Charmglow Patio Heater
The yhernocoupler would snuff the pilot if bad. What ignites the overhead burners? and what regulates the overhead gas supply? Look into this. Too much gas will not light as easily as proper balance gas and air. Even more so in a tower type heater.. Turn the gas on low and the pilot should grab it. Good luck
Jun 05, 2009 | Coleman (5040B750) Patio Heater
Charmglow gas patio heater
Your thermocoupler seems at fault. The thermocoupler is that probe that sits in the pilot flame. It controls the main fuel valve. Make sure that probe is in the pilot flame, better at the tip of the flame and hold the button down for a minute or so after lighting the pilot. If pilot extinguishes, the coupler is faulty. If pilot stays on the heater should fire up when you let up on the pilot button.. Good luck
May 30, 2009 | Coleman (5040B750) Patio Heater
Propane patio heater ignition problem
I would change the thermocouple and here is why:
The thermocouple is the pilot's, well, co-pilot! It is the electronic device that senses if the pilot flame is hot enough to sustain burning the gas fuel from the burner. If the thermocouple thinks it's safe, then it keeps open the main gas valve located in the pilot assembly. If the thermocouple does not sense enough heat from the pilot flame (such as when the pilot is out), then the thermocouple shuts off the gas valve to the burners.
How the Thermocouple Works
So what is this thing and how does it work? Well the thermocouple (technically called a thermocouple junction) is a device that contains two metal wires welded at the ends and placed inside a protective metal case. The thermocouple sensor is found at the business end of the pilot flame and is designed to be placed in the hottest part of the flame. The other end is connected to the pilot valve body. As the thermocouple heats up, it produces a small amount of electricity and when it gets hot enough from the pilot, send a signal to open the gas valve by using a solenoid operated by a 24 volt transformer. The thermocouple calls the shots, and by converting heat to an electrical signal, it allows the gas valve to open or close. Once the gas valve is open, gas is then constantly supplied to the pilot and as required for the gas burners (as called for by the thermostat). If the pilot goes out, then the thermocouple gets cold and produces no electric signal to open the gas valve's solenoid and the gas valve shuts off the gas supply to the pilot and burners
May 27, 2009 | Endless Summer Blue Rhino 235000...
Charmglow patio heater
Looks like the knob or the contacts are faulty.
Nov 07, 2008 | Williams 2509612 Ceramic Mid-Size Heater
Patio Heater pilot lights won't stay lit
crappy pilot flame (not properly heating the thermocouple), bad thermocouple, thermocouple loose where it screws into the pilot safety valve, bad safety valve magnet.
One or more of those is the problem.
Oh...there is also a saftey switch...in case it tips over. It will also cause the pilot to not stay lit (if the switch or wires that go to i are faulty)
May 30, 2008 | Coleman (5040B750) Patio Heater
Coleman 5040-751 BackHome Open Flame Patio Heater Logo
645 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
