Question about Magic Prosong Microphone
BROKEN CONNECTION We let the kids play one night and when they were finished they couldn't figure out how to disconnect the mic from the wiring harness. They twisted the cable which twisted the wiring inside the mic breaking the connection (must of learned it through their father). I attempted to reconnect the connections but was unsuccessful. I'm looking for a new female 6 pin connector to reattach and the wiring instructions so I get the connections right or any other suggestions for reconnecting the wiring. I've searched the internet for a wiring diagram (no luck) and went to Radio Shack to see if I could find a female connector (again no luck). Suggestions? P.S. it would probably be easier to get it fixed right!
  • Anonymous Feb 25, 2008
    I got the same problem, need a diagram of 6 pin connectors to attempt to replace wires myself, what would it cost to have it repaired from someone that knows more about how to repair
5 Suggested Answers
  • 1138 Answers
SOURCE: I did not use my mic for about 6 months. It was
If it is an adapter type power supply, you may need a new adapter. If this type of supply is left plugged into the wall over time it can burn out from overheating or transients in the power etc. Also it appears that these have rechargeable batteries in them. Have you tried putting double A batteries in the battery compartment if there is one? The website is :http://www.magicsing.com.ph/faq.html#5
Posted on Aug 11, 2009
SOURCE: magic (karaoke) mic sound delay problem when connected to HDTV
Ok..I found a workable solution. Essentially using my HDTV only for the lyrics(video output) and using a RCA to stereo mini plug cable to send the sound output to my amplifier that has a analog stereo input. Works like magic. No delay. It went from being unusable to WOW!
Posted on Aug 28, 2009
SOURCE: Can't power ON...
See if the microphone connector wiggles. It shouldn't move, but if it does, the legs on the connector can snap inside.
Posted on Nov 19, 2009
  • 10 Answers
SOURCE: Have an ET9000 that had
Contact Enter Tech at http://eng.enter-tech.com/support/inquiry.php and ask about a replacement cable. It sounds like it's wired wrong and I couldn't find any details on the correct wiring on their web site. So, just replacing the cable is the best way out.
Posted on Dec 14, 2010
I have a cx-366ce cb cannot hear talking what is wrong
Is squelch turned too high that it is blocking too many signals?
Otherwise, it could be a faulty cable on the mic as the PTT button disconnects the speaker on the CB and a broken wire can cause the speaker to be disconnected.
Jun 28, 2014 | Connex Cx-366ce Night Runner 40ch Cb...
Rear Passenger Window Problem
it has some dust in it
Dec 02, 2017 | 2002 Buick Regal
When i plug in my mic i cannot hear my friends talk but it says my mic is in and i am talking.
You used the term "plug in my mic". I assume you mean the microsoft mic and head set. one of the best ways to check the headset and mic. is to go onto microsoft live and attempt to leave someonw a voice message. during the message you will get a message that says your mic is not working. also after you finish the voice message attempt to play if back if you do not hear anything then the problem is with your microsoft head set and attached mic. if new take if back to exchange for another one. there could possibly be something wrong with the port connection on you microsoft controller.
Jul 01, 2011 | Microsoft Headset for Xbox 360
My mircophone is broken? dont have money to fix? any cheap ways to still use
WOW this is an expensive camera, I would first HIGHLY recomend spending the money and send it to a good electronics or camera shop and have them fix it.
If this is not an option here are a couple or things you can do. Since this is a higher end camera it
should have a mic jack, if so just hook in a good microphone and it should work fine.
A couple of words of warning before tying the next solution you could permanetly mess up your
cameras sound. While this method theoretically possible, some companies intentionally make this
very hard. Often companies will use hair thin wires or wires that are so short thier is no way to
patch into them. Also, since this description doesn't use standard hardware you should disclose
this repair to anyone who might wish to buy the equipment if you decide to sell it. Also, the mic
that I've suggested may not be as good of quality as the original Sony. You can use
any mic of about the same size so long as it has wires to tie into.
If your not real familiar with electronics get a buddy with some experience repairing electronics to help.
If your really adventurous, you could take the mic assembly apart and put in a new mic. Just get a good compact mic like a KOSS M5 and splice off the end then shave the wires. Then carefully
take the mic assembly on you camera apart look for a small disk made of two magnets an a
fillament with 2 wires disconect the wires from the disk and hook them up to the shaved wires
from the KOSS microphone (one wire from a lead the other to the ground of the KOSS microphone). The KOSS mic will have 3 wires two sources/leads and a ground you might have to play around with it to figure out the wires and get it working properly. If your mic assembly has 2 mics figure out which wires are the lead by hooking them up one at a time (to the wires that originally were hooked to the internal microphones) with the ground on the other wire and trying them. Once you figure out which are the lead wires hook them each up to the old mic wires and take the other side and hook them both up to the ground. once you have it all wired back up and any splices insulated (elecrical tape should be fine) you should be able to re assemble the mic with the new microphones installed.
If the mics for the camea are intergrated into a circuit board the same method will work but
the old mics will need to be desoldered and the leads from the new mic will need to be soldered
where the old mics were. If this is the case get a buddy with some experience with electronics to help you.
Method three use an external recorder. For this method just record the sound with another external
device like a digital voice recorder then use an editing program like Sony Vegas to add the sound to your video. The hard part is syncronization. A clicker may help create sound tags to align the video with the audio with the sound.
May 04, 2011 | Sony Handycam DCR-VX2100 Mini DV Digital...
Tent poles have broken
Ours too. Very disappointed. The phone number is 18003742744. They were less then helpful for me. But maybe they can help you out. Will not buy their toys again.
Jan 09, 2011 | Play Inc Discovery Kids Adventure Play...
My tent support poles it broke
Hi! If the poles are broken no need to worries you can order that online. try to visit http://www.questoutfitters.com/tent_poles.htm.
Thanks.
Jan 01, 2011 | Play Inc Discovery Kids Adventure Play...
My Cobra 29 LTD sometimes does not work even though the lights remain on. In other words I can't talk on it or hear anyone even though it appears to be operational
Your mic or mic jack is faulty. Try a different mic. In cobra 29's and some other variants, when you disconnect the mic, the audio is disabled. It will still receive, and transmit(possibly) but you will hear nothing from the radio.
It could be,
  • Broken wire on the back of the mic jack in the radio.
  • Broken wire in the mic cord.
  • Disconnected wires in the mic for the switch.
  • Dirty mic connection pins.
Most likely the problem is with the mic, and not the radio.
Oct 21, 2009 | Cobra 29 LTD CB Radio
Guitar hero microphone wiring help
In all honesty, there is really no point in trying to fix this problem. Check for the PS3 Vantage USB Mic Logitech at Gamestop. You can pick this up for about $20 and is well worth spending the money for instead of the aggravation of trying to fix the old one.
Jun 25, 2009 | Activision Guitar Hero
Troubleshooting National Kids Red Mini Cooper Racer Ride On Car B
If the wiring harnesses are still in tact, they are all different and its just a matter of matching them up. I did it last night and worked fine. the only thing I wrote down was that the 2 wires which are not in a harness, they plug onto the switch. The one with two wires coming out of it goes on the prong at the end and the other with only one wire goes onto the middle prong. Hope this helps.
Nov 14, 2008 | National Kids Mini Cooper Racer Ride On...
Magic Prosong Microphone Logo
Top Magic Audio Players & Recorders Experts
Evan Benson
Evan Benson
Jojo
tornacious
Level 1 Expert
Are you a Magic Audio Player and Recorder Expert? Answer questions, earn points and help others
