Question about Gateway 2520796 Keyboard
Gateway 1150 won't boot to CD upon pressing Esc key.
I'm trying to clean reinstall Win ME with factory supplied recovery CD.
Many attempts. I'm suspecting Esc key is broken. How do I test the escape key to see if it works? Thanks for any help.
  • olderstudent Nov 23, 2008
    Thanks all.
    Passmark keytest shows Esc key is dead.
    Escape=exit from Bios failed also(key dead).
    I learned OEM Recovery CD should boot from that drive. If Esc key functioned.
    I am going to borrow a USB keyboard today and try again. Thanks again.
  • Gateway Master
  • 32,281 Answers
There are quite a few keyboard test programs on the WEB that are free.
Try these sites
www.Driver-Updates.net
www.passmark.com/products/keytest.htm
If you don't find these useful, do a Google search for other programs.
Posted on Nov 23, 2008
  • 76 Answers
Hmmm...unfortunately that is now a primary function key...
you can press F2, enter bios set up and make cd first boot option(follow instructions)..
then insert recovery cd, and restart system..
No bootable device, hit any key
The bios cannot find any device it can boot from. This can occur because of hard disk failure, a loose connection or file corruption. There usually is a boot menu that you can get to from the bios by hitting some key specified by your bios manufacturer during the POST bootup process. Usually there is some message on screen like 'press esc for bootup options' or 'press f2 to enter bios setup' or something similar. As your machine starts up, try hitting ESC, F2, F5, F8 or F12 -one at a time-hitting each key several times during bootup (maybe your manual can give you a hint). If you get into the BIOS setup screen, look at the screen that tells you what the BIOS thinks you have attached for storage. If you don't see a hard disk there, you have a definite hardware problem. If you get into a boot option screen, try putting a Windows Installation CD, or a recovery CD from your laptop manufacturer, in the CD-ROM drive of your computer and enabling the machine to boot from the CD-ROM. If the PC boots from the CD-ROM, you may be able to use Windows Recovery mode or your manufacturer's recovery disk to get your hard drive working again. If you have any files you can't live without on your hard drive, look into getting your hard drive out of your laptop and into a USB drive enclosure that you can use another PC to try and read those files from the hard drive prior to attempting any recovery options, as some of them erase all files on your hard drive. Also check to see if your PC has manufacturer diagnostics that you can boot into to check your hardware with before attempting any other type of repairs.
Sep 04, 2014 | Gateway Computers & Internet
How do i hard reset my hp mini 311
If the computer will boot into Windows, click Start , type recovery into the search field, and then select HP Recovery Manager from the list.
If the computer will not boot into Windows, turn on the computer and immediately press the esc key to display the Startup Menu, and then press the F11 key.
Aug 08, 2014 | HP Computers & Internet
I have an hp dv9925nr laptop running vista home premium 64. I tried to reset to factory settings and now when I try to start up I get a boot manager error. It says \boot\bcd status 0xc000000f error...
Most of the boot up of problem because of hardware problem, registry missing or crashed, file deleted or changed.
You can boot up your Windows with Tenorshare Data Recovery WinPE.It allows users to burn ISO file to CD/DVD/USB flash drive directly.
Step 1: Download Tenorshare Data Recovery WinPE in any available computer (not from PC that can't boot up). Then launch it.
Step 2: Insert CD/DVD/USB flash drive to the computer, choose ISO image file. Here we take USB flash drive for example. Then burn ISO file into flash drive.
Step 3: Insert the burned flash drive to the unbootable PC. Run computer and press "F2", "F10" or "Delete" to enter BIOS setup.
Step 4: Use the arrow keys to select Boot tab, select Boot Device Priority and press Enter. Please choose 1st Boot Device to USB, and then press F10 to save setting. Now,you can boot up your PC.
If you have a backup for your Windows then perform a system restore to fix it.If not,reinstall it.If you have no backups for all your data,you can use Tenorshare to retrieve data under any boot up problem.You can get it from http://www.any-data-recovery.com/product/datarecoverywinpe.htm
Here is tutorial to guide you how to do --How to Recover Data from Computer Won't Boot Up?-Windows Data Recovery.
Sep 19, 2011 | HP Pavilion dv9925nr Notebook
Problems with booting a Compaq presario cq 60 - black boot screen showing Compaq with 'Press the ESC key for Startup Menu' What should I be doing next - nothing seems to work?
Reinstall Windows, the one you have now is corrupted: get your recovery disk, put it in press Esc and select the CD as boot device. Now follow the instructions on the screen
Feb 16, 2011 | Compaq Presario CQ60-212US Notebook
How to reset to factory settings a toshiba satellite A305-S6829 with Vista ? (pressing 0, or F8 didn't bring me far!
To access the Toshiba recovery partition, power off the laptop. Hold down the 0 (zero) key and turn the laptop on. Keep holding down the zero key until the TOSHIBA logo appears, where you should start tapping the zero key repeatedly. Stop if the unit beeps or when the TOSHIBA logo disappears. The screen should flash ** HDD RECOVERY MODE ** for a split second, then load the Toshiba recovery program right from the hard drive.
Note that this erases all data, and reloads all factory default software. Be sure to back up all your important personal data beforehand!
Dec 31, 2010 | Toshiba Computers & Internet
How do i reset my in spiron 1150 to factory reset
when u restart u r pc check it's showing some fuction key like F1 to continue esc for boot option F9 for diagnostics F10 or 11 their u can get factory recovery systeam but u may insure about that u having that drive on u r hard disk it's not be formatted
Dec 05, 2010 | Computers & Internet
Recovery problem
you need the cd to restore any vista laptop call acer and order one sorry
Sep 02, 2009 | Acer Aspire 5610-4648 Notebook
I cant get my gateway mt3705 to format,only three options setup available for boot menu,boot seq,setup and psx boot menu..no recovery disc either what do i do?
To delete everything on your hard drive and re-install all factory software: 1 If you can still run Windows: a Click Start, All Programs, Gateway Recovery Center, then click Gateway Recovery Center. The Gateway Recovery Center opens. b Click Recovery, then click Next. Your computer restarts. - OR - 2 If you cannot run Windows: a Turn on or restart your computer. b While the computer is starting up, repeatedly press F8 until the Recovery Options screen opens. If Windows starts to load instead, restart the computer and try again. 3 Press the arrow keys on your keyboard to select Repair Your Computer, then press ENTER. Gateway System Recovery starts, and the System Recovery Options dialog box opens. 4 Select a language and keyboard layout, then click Next. 5 Click the User name box to select a Windows user account, click in the Password box and type the user account’s password (if any), then click Next. The System Recovery Options menu opens. 6 Click Restore Application. The Welcome to Gateway System Recovery window opens. 7 Click Next. 8 To perform a recovery with data backup (recommended), click Recovery with automatic data backup, then click Next. Important Before your hard drive is recovered, your personal files will be automatically backed up to c:\backup. - OR - To perform a full factory recovery without data backup, click Full factory recovery, then click Next. Caution Continuing with the full factory recovery will delete everything on your hard drive. Make sure that you have backed up any important files you want to save. 9 Click Yes, then click Next. The Factory image recovery window opens, which shows you the progress of the system recovery. When recovery is finished, the Recovery is complete window opens. 10 Click Finish, then click Restart. Your computer restarts in its original factory condition. You still need to reinstall any software that was not pre-installed on your computer. If you selected Recovery with automatic data backup in Step 8, you can find your backed up files in c:\backup.
Sep 01, 2009 | Gateway MT3705 Notebook
Bootmgr is missing
Run a Chkdsk:
Take the Windows XP disk. Boot from it, then DO NOT select F2 (automated system recovery) but continue through the procedure until you get to the point where you can choose between installing Windows XP and entering the Recovery Console. Once you get into the Recovery Console, do chkdsk and fix potential errors on your disks! Chkdsk C: /R
OR:
Perform an XP repair:
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your Applications or data; it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 07, 2009 | Gateway MT3705 Notebook
Lost restore dvd supplied with computer.have no choice but to restore
On eMacines, the recovery partition contains your driver and software. But you needed to create the recovery cd set when you got your computer.
To restore it,if your computer came with XP, borrow an Win XP cd (cannot be a HP,Dell etc).
Try a repair first:
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your applications, it just reinstall the Windows files. This is great because when it works you don't need to reinstall all your software.
If a repair does not work, do a complete install.
Thanks, Joe
Oct 18, 2008 | E-Machines Computers & Internet
Gateway 2520796 Keyboard Logo
445 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
