Question about Dyna-Glo (PPH16-LP) Utility Heater
The pilot light won't stay lite
I have a dyna-glo rmi-80lpt, when you light the pilot the flame goes on,ignates the gas,the flame comes on burns for a while and when it comes up to temperture the flame goes out and so does the pilot light. You have to relight the pilot everytime. Is there an online manual for this model or is it just out of date? Had it serviced but it still does it.Also we noticed the pilot light is at least 2 inches long and there's no adjustment.
  • Dyna-Glo Master
  • 3,328 Answers
Flame is way too high on pilot . blocked injector or hole on injector is too big . Being sucked off by main burner .
Posted on Jul 04, 2017
5 Suggested Answers
  • 3328 Answers
SOURCE: Dyna-glo parts
thermocouples you can buy from any heating spares oulet or national energy a hone well is most common for useing as a replacement
Posted on Feb 07, 2009
TheMobilian
  • 8220 Answers
SOURCE: cant find set screw on pilot burner. model no. rmi 70ng
Set screw for what? To raise the flame? Not one. What you gotta do is clean out the pilot. Least bit of dust makes the safety think oxygen is low and shuts down the heater. I flush the pilot with a drop of rust busted then I use the long spout on it to blow out the pilot. You could use a straw tubing or shop air. Take a look at the demo HERE
A great page that shows where to clean the pilot and has links to more good stuff: HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 31, 2009
FurnaceGuy
  • 74 Answers
SOURCE: The brick does not glow red you see the flame all
Both repairable and dangerous. The burner need blown out with a air compressor. This should take care of it. The unit not glowing red will create CO. Which will make you sick or even can kill you.
Posted on Jan 06, 2010
SOURCE: I have a Dyna-Glo unvented
MAKE SURE THERE IS AMPLE FRESH AIR IN THE ROOM, SOME MODELS ARE MADE TO NOT LIGHT IF THERE IS NOT ENOUGH FRESH AIR. RON G.
Posted on Dec 01, 2010
Dyna glo model rmi 80lpt parts
A thermocouple/Pilot Generator is pretty generic in its operation. If you can get one that will physically fit where the pilot flame is, positioned safely & securely, then any generic one will operate.
Jan 21, 2014 | Pool & Spa
I have a Dyna Glo model RMI-80LPT and the aluminum Gas Line going from the lower Regulator up to the Pilot switch / temperature control switch has a crack in it and I need to know what that part # is and...
If this aluminum tube has nuts on each end, I would bet that if you called your local plumbing supply house & described the part, they would have one in stock. Do you feel capable of removing the part?
Dec 21, 2010 | Dyna Glo "" Natural Gas Heater Mn200tba
Pilot will not light- rmi-80ngt-30,000 btu
if it wil light and wont stay lit replace your thermal coupling
Jan 23, 2010 | Dyna Glo "" Natural Gas Heater Mn200tba
Dyna glo tag along propane heater pilot stays on but when turning
sounds like either a bad thermocouple or more likely a pressure regulator problem. should have unit checked by someone familiar with propane systems.
Jan 13, 2010 | Dyna-Glo (PPH16-LP) Utility Heater
Cant find set screw on pilot burner. model no. rmi 70ng dyna-glo wall gas heater.
Dec 31, 2009 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Pilot light on Dyna Glo gas heater won't stay lit
Cleaned pilot light area with an air compressor. Problem solved!
Mar 02, 2009 | Dyna Glo "" Natural Gas Heater Mn200tba
Dyna-glo parts
Feb 03, 2009 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Keeping Dyna-glo D-E37 lit
sound s like the pilot is blocked and the flame is too small or thermocouple needs replacing
Nov 24, 2008 | Dyna-Glo D-E37 Wall Mounted Panel Heater
Blue flame heater pilot wont stay lit
There is a therma-couple that the flame burns against. When it is working correctly it allows gas to travel to the flame. When it goes out you get no gas, as a safety feature. Replace the therma couple and it should work again.
Oct 06, 2008 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Dyna-Glo (PPH16-LP) Utility Heater Logo
286 people viewed this question
Top Dyna-Glo Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
fordexpert
Are you a Dyna-Glo Heating and Cooling Expert? Answer questions, earn points and help others
