My 2000 Mitsubishi Galant suddenly shut down at a stop sign and both the battery and oil lights came on. When I try to turn it back on, it does turn on but will not stay on unless I repeatedly keep pressing the gas pedal. If I hold the pedal down, the car will die out. The oil and battery are fine and when I looked under the hood, some part that is connected to the accelerator felt loose when I shook it as if something was broken maybe. What could be the problem?
SOURCE: engine drops speed when I press gas pedal
Ignition distributor caused problem. Rotor element needs replacement.
SOURCE: 98 galant motor stalls - dies when gas is pressed
I would take a look at possiable damage to the PCM (powertrain control module)
SOURCE: 2003 Mitsubishi Outlander died and won't start back up
If it does turn over but won't start, check for fuel and spark, if not spark then check to see if the crank sensor is cover with dirt.....
SOURCE: 2000 mitsubishi eclipse dies when idling
What you have is PROBABLY a bad Idle Air Control stepper motor... if the car stays running with your foot on the gas, and only dies when you let your foot OFF the gas... or if it dies when you shift (again, cause you foot is off the gas) that is definitely the problem. The stepper motors are kind of pricey (over $300) at the dealership, but you should be able to get one from an auto parts store for 150 or so. easy as heck to replace, it has three 8MM bolts into the throttle body, just unplug it, unscrew the bolts, and put the new one in... just be sure to be careful with the new o-ring... DON'T LOSE IT! :)
SOURCE: 1997 Mitsubishi Galant Died
Sounds like the EGR valve is bad and is stuck in the open position.Just replace that and you should also check the catalytic converter.
CAR NO START PROBLEMS:-----
It
can be the issue with weak battery or faulty battery or if battery is ok,then
its faulty starter causing the issue.
From
start to end troubleshooting these problem i suggest you to click the link
below and follow its procedure:-----
What to Do When Car Turns Over But
Won't Start?
http://technoanswers.blogspot.com/2012/11/what-to-do-when-car-turns-over-but-wont.html
Car starting issues?
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
Car Starting Problems
http://whoisbyme.blogspot.in/2012/06/car-starting-problems.html
1991 Toyota Trecel: Engine Starts fine but
dies when gets Warm?
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
1994 Toyota Pickup: Starts fine but dies in
few seconds?
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
1999 Chrysler Cirrus: 8 IGN Fuel Starter Fuse
Blows?
http://whatisbyme.blogspot.in/2012/06/1999-chrysler-cirrus-8-ign-fuel-starter.html
2001 Toyota Camry: No start After replacing Battery?
http://whatisbyme.blogspot.in/2012/05/2001-toyota-camry-no-start-after.html
1989 Toyota Pickup Truck: Turns over but not
start?
http://whatisbyme.blogspot.in/2012/05/1989-toyota-pickup-truck-turns-over-but.html
Car dead and will not Start?
http://whatisbyme.blogspot.in/2012/05/car-dead-and-will-not-start.html
1995 Lexus LS400: Running Hot?
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
2001 Toyota Prius will not start?
http://whatisbyme.blogspot.in/2012/05/2001-toyota-prius-will-not-start.html
1996 Jeep Grand Cherokee: Engine will not start?
http://repairhelpcenter.blogspot.in/2012/06/1996-jeep-grand-cherokee-engine-will.html
Mitsubishi will not start
http://www.howtorepairguide.com
These will help.
Thanks.
