Question about Kenmore Elite 21086
Kenmore Dryer Wont Heat up or even warm
My kenmore dryer won't warm up or get hot. The motor is working fine, but no heat. Help!
  • 91 Answers
Chech ignitor if ok repl./ thermal fuse
Posted on Jan 04, 2009
I have a kenmore dry that seems to hum very load once it heats up. If you turn it off and rest for 30 minutes it will sound fine again until it is 15 minutes into the cycle. What would be the likely...
Hello Bill,
Sorry to be the bearer of bad news,but what your describing sounds exactly what a bad motor will do...run whiles is realitivly cool,cut off when hot the restart after a cool down period and run for a while till hot again.
GENE
Sep 12, 2011 | Kenmore 84072 Electric Dryer
I changed the heating element in my lady kenmore dryer, but still not heating...
If the previous element was burnt out, the following test can be done.
First unplug the dryer. then bridge the active and neutral on the plug with a bridging jumper. ( a piece of skinned wire will do ) then set the dryer control on heat (hot or warm) make sure the door is closed ( door switch cuts element as well as motor.) If this is impossible then you may be able to operate the switch by clamping it with something. then disconnect the element wires from the element. You should be able to read continuity across two of the element wires. If you can, then select the other temperature setting (hot to warm ect.) if you can read continuity across the common and the other then the element is faulty if you cant, then check hot temp switch, warm temp, switch belt breaker switch. if it has one.
Aug 31, 2011 | Whirlpool 279843 Whirlpool Kenmore Dryer...
I have a kenmore 90 series dryer. The heat element and timer work and belt is good but motor won't work? Any help would be appreciated.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 14, 2011 | Kenmore Dryers
Kenmore dryer 110 gas won't get hot only warm. I
more than Likely,, the thermostats are discs ,, located along the vent tube inside the back of the machine, one of yours is weak and allowing the switch to turn off to soon
Jun 29, 2011 | Kenmore Dryers
Hello-I have the Kenmore Electric Dryer model 110-66842501 series 80. Started the dryer and noticed a burning smell & the dryer was unusually warm to the touch. Now there is no heat. Drum turns...
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 12, 2010 | Dryers
I have a Kenmore electric drier # 110.60912990 It runs fine, but no hot air. What should I check. I checked the outside vent and air is coming out. I check the circut breaker and it is fine.
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
If your dryer is electric2_bing.gif..
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 03, 2010 | Kenmore 64942 Electric Dryer
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
Washing Machines Logo
124 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
