Question about Mitsubishi WD52527 52" Projection HDTV
No picture lamp light on
Lamp light on mitsubishi model wd52527 no picture . if I have to replace bulb where would I look..
  • 106 Answers
You can find the lamp acces door on the lower back left side. You will have two philips head screw to remove and you will see the lamp. Remove it and look at it. It will probably be shattered. There is also a filter right beside the access door. Be sure to clean that.
You owners manual can provide you with info to ordered a lamp and have it sent to your home
Posted on Nov 26, 2008
Mitzibushi Tv model WD-65638 no picture no sound
Youre lamp has failed. you need to replace the lamp. Refer to the manual to see how to replace it. It only requires 2 or 3 screws on the back to be removed. Please check the manual.
You need a 915B441001 lamp. 915B441001 PVIP Mitsubishi DLP TV Bulbs
Feb 25, 2015 | Mitsubishi Televison & Video
What is wrong with my Mitsubishi Tv model WD-65638
Youre lamp has failed. you need a new lamp.http://projectorlamps.com/mitsubishi-dlp-tv-bulbs-915b441001-pvip.html 915B441001 PVIP Mitsubishi DLP TV Bulbs
Feb 25, 2015 | Mitsubishi WD Televison & Video
I have a mitsubishi projection tv. I need to replace the bulb. Does any one know the difference between a pure glare bulb and a osram neolux bulb? Which bulb is right product for my tv? Also, which bulb is...
When in doubt check with sites such as www.TvRepairKits.com - check their online store first then email them if they do not show it. In most csases OSRAM is a great lamp...nore sure about pure glare...
Feb 22, 2013 | Philips 915P028010-P Projection TV...
How to replace the projection bulb?
LAMP DOOR LOCATED IN THE BACK ON THE RIGHT HAND SIDE LOOKING FROM THE BACK. IT IS HELD ON BY 2 SCREWS THE LAMP IS SET BACK IN THE TV ABOUT 5 INCHES FROM THE LAMP DOOR SUGGEST A LONG FLAT HEAD SCREWDRIVER TO LOOSEN THE LAMP. INSERT NEW LAMP AND PUT LAMP DOOR BACK ON. THERE ARE INSTRUCTIONS IN YOUR OWNERS MANUAL.
Dec 16, 2010 | Mitsubishi WD52527 52" Projection HDTV
Burnt out lamps
There is only one lamp need. If you keep your user's manual refer to ...how to replace the lamp. (I recommend to use an original mitsubishi lamp) process is kind or smooth path to the user, But if you are not feeling comfortable replacing it a serviceman can give you an estimate on it.
Apr 22, 2009 | Mitsubishi WD52527 52" Projection HDTV
Green Blinking Light plus Red Lamp Light
You lamp bubl has burned out. You need to replace the bulb. you can order a new bulb on line by searching the web using your model number bulbs are about $110 if you reuse the cartridge and replace the bulb only. replacing the whole cartridge and bulb is around $ 200
Nov 27, 2008 | Mitsubishi WD-62531 Projection Television
Problems with my tv
When ever i turn on my Mitsubishi WD52527 TV it comes on, I hear sound but no picture for around 7 seconds, then the red light under lamp comes on, and the sound go away
Oct 16, 2007 | Televison & Video
Mitsubishi WD52527 lamp light
Replace the lamp, model 915P028010.  There is a lamp door on the back left bottom of the set (while looking at it from the back).  Take off the door (two screws) and then take off the two screws holding the lamp in place and pull on the handle.  Replace the lamp the same way.  Then make sure to clean the air filters (below the lamp, two screws; and bottom right).  If the set gets too hot it may destroy the set and/or the lamp.  Also, don't turn the set on and off again within a few moments.  It will destroy the lamp.  Take it from someone who had the same problem, keep the filters clean by cleaning at least once every couple of months....Dave
Sep 20, 2007 | Mitsubishi WD52527 52" Projection HDTV
Mitsubishi WD52527 52" Projection HDTV Logo
99 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
