I just want to know where you fill up the gearbox oil on a 02 Kia Carnival LS V6 2.5ltr
SOURCE: How to remove engine valve cover of Kia Carnival
YOU HAVE TO REMOVE THE INJECTORS TO REMOVE THE CAM COVER YOU WILL NEED A INJECTOR PULLER OR SLIDE HAMMER AND HAVE TO REPLACE THE INJECTOR WASHERS WHEN YOU REFIT THE INJECTORS OR THEY WILL BLOW PAST
SOURCE: kia rio gearbox oil filler location? 1.3 2004 manual
half way-level- on front or side of gearbox,think its on the fifth gear housing behind wheel arch on this model ,round plug with a square drive in centre
SOURCE: Fuel Filter location on a Petrol 2004 Kia Carnival
The fuel filter is located in the fuel tank, pump removal is required to replace. There is an inspection cover behind the front seats on the floor to gain access to the pump. stupid idea. but whats not stupid about kia.
SOURCE: where is the fuel filter located in a kia carnival
it is build in to fuel pump motor, you have to take off the pump to replce it. To access the pump you have to take off the middle seat then you can see a cover on floor carpet then take it off to access the pump.
SOURCE: hi i have a 2000 2.5ltr v6 kia carnival need the camshaft belt
How do i set the timing in a kia carnival
