Question about HP PSC 1610 All-In-One InkJet Printer
Hp 1610 all in one scanner failure turn power off
My printer is giving me the following error " scanner failure, turn power off," every time I try to print. It was allowing me to print, however I can no longer print, nor make any copies.
  • 3 more comments
  • Anonymous Jan 07, 2009
    scanner failure
  • nola151 Jan 07, 2009
    scanner failure message
    tried recommended methods
  • emil062 Feb 02, 2009
    I have a similar problem, except I can print. But when scanning I get a "Scanner Failure" message after each page. I have to power down after scanning every page.
  • Anonymous Feb 05, 2009
    I tried downloading the update.  No success.
  • dkenglish5 Feb 06, 2009
map9966
  • 2351 Answers
SOURCE: Office Jet K60xi Scanner Failure
Try HP's web site suggestions first.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01077492&cc=us&lc=en&dlc=en&product=61736
If your sacnner still fails to function, uninstall everything for the Officejet through add/remove in control panel. (Power off printer before uninstalling).
Go to Hp's web site. http://welcome.hp.com/country/us/en/welcome.html#Support
Step 1. Click, Download drivers and software (and firmware).
Go to step 2. For product, type in Officejet k60xi .
Power on your printer. (Wait for printer to fully power on).
Click, Start Detection>> button.
Allow HP to scan your system & install the latest software.
Follow the on scren instructions. (When finished, restart your PC). Test your scanner by scanning something.
If your scanner still fails to scan, you may be missing basic HP files loaceted in windows system & windows system32 folders.
(These missing files were not installed during your install of windows). Not your fault.
Posted on Apr 25, 2008
  • 105 Answers
SOURCE: HP photosmart c7180 scanner failure
you can run a reset on the printer and clear the scanner failure yourself. You can find the instructions at: http://www.inkbank.com.au/webcontent21.htm
good luck...
L.C.
Posted on Jun 13, 2008
SOURCE: Scanner failure message.
Scanner Failure, Power Off and On' Message Displays on the Control Panel when Copying or Scanning
Issue
The message 'Scanner failure, Power off and on' displays on the control panel of the product.
This error usually occurs when trying to scan, to make copies, or during the product start up.
Try the solutions in this document until the issue is resolved. It is not necessary to continue to the next solution if one solution resolves the issue.
Solution one: Check the scanner light
Make a color copy of any document by pressing the Start Copy Color button on the control panel. While the product is making the copy, slightly lift the scanner lid to see if the scanner light is visible.
CAUTION: Do not look directly at the light. It is not necessary to completely open the lid to see the light.
If the scanner mechanism moves across the scan bed, but the light is not lit, click here to service the product .
Solution two: Check operating conditions
Extreme temperatures can affect the operation of the product. Make sure the operating conditions match those recommended in the User Guide provided with the product.
Solution three: Check the power connections
1.
Make sure that the product is connected directly to a grounded wall outlet and not plugged into a power strip.
2.
Make a color copy by pressing the Start Copy Color button on the control panel.
3.
If the error message persists, temporarily move the product to a different room or outlet, and then make a color copy by pressing the Start Copy Color button on the control panel.
4.
Check the part number on the power supply to make sure that it matches the part number listed in the User Guide.
Solution four: Perform a power cycle
1.
Turn the product off.
2.
Unplug the power cord from the product.
3.
Wait 30 seconds, and then reconnect the power cord to the product.
4.
Turn the product on.
5.
Solution five: Reset the product
Follow these steps to reset the product.
Step one: Perform a partial reset
1.
2.
Press and hold # and 3 while plugging in the power cord.
3. Make a color copy of any document by pressing the Start Copy Color button on the control panel.
If the partial reset resolves the issue, do not continue to the semi-full reset.
Step two: Perform a semi-full reset
CAUTION: Performing a semi-full reset deletes any phone numbers that are saved on the product.
1.
2.
Press and hold # and 6 while plugging in the power cord.
Solution six: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Posted on Aug 19, 2008
leroyal
  • 2120 Answers
SOURCE: Hp officejet 5610 Wont scan . Print. Copy
your printer is dead and is uneconomical to repair. sorry
Posted on Jan 25, 2009
SOURCE: HP SSC 1610 scanning
INSTALL HP CD
PL CHECK MEM MIN 256 WIN XP RECOMMEDNDED
Posted on Mar 16, 2009
My HP Photosmart C5240 will print from computer but will not scan or make copies.
Is there any error message displayed on the control panel of the printer just like one of the following:
Scanner failure, power off and on
Scanner System Failure
Scanner failed, cannot make copies or fax
Scanner failure. Unable to scan, copy, or send a fax
Scanner failure, cycle power
You may want to try following these steps:
1. Check if the scanner light does turn on when you initiated the scanning process, if not you need to reset the product.
2. Try using your other electrical outlet because your AVR or Surge Extension may not be providing enough voltage for the printer.
3. Try using dirty cycle, meaning you need to directly cut the power of your printer by pulling of the power cord from the rear side of your printer and wait for about 30 seconds before inserting again and turn it on.
If all these steps do not improve your printer functionality, you may want to call the HP online help and ask for replacement.
Job Espinosa
Feb 15, 2011 | HP Photosmart C5280 Printer
I have an hp digital copier, stand alone, not connected to any computer. When I turn the power on the warm up message lasts for a long time. It then tells me there is a scanner failure and will not print....
Hello.
Give this a try (from HP Support):
The Scanner System Failure error occurs if the scanner bulb is not being heated up to the correct temperature or there is some other issue with the scanner hardware. Verify that the scanner bulb is lit.
Power cycle the all-in-one product and see if the error comes back. Perform the steps given below to power cycle your all-in-one product.
1. Shut the computer system off, then disconnect the all-in-one product from the power source. Leave the all-in-one product disconnected from the power source for at least one full minute.
2. Reconnect the power, then restart the computer system.
If it does, take it off of any power strip and plug it directly into a wall power outlet. The power strip may not be supplying enough power to the product. Cold ambient room temperatures may also cause this
error. Try moving the unit to a warmer room and see if the error reoccurs. The unit will need to be serviced if the bulb does not come on.
Perform a semi-full reset by following the steps given below:
Caution: A semi-full reset will reset or clear the following information:
* Return the user settings to the factory defaults
* Delete language and country settings on some models
* Fax logs
* Fax headers
* Fax speed dial information
Hope this helps.
Feb 07, 2010 | HP 610 Color Copier
HP 1610 "scanner Failure" message
It MIGHT be that the unit is no good. The downside of ALL IN ONE products. BUT, unplug the power cord from the back of the all in one, then unplug the USB cable, then unplug power cord from wall. Wait 10 minutes and plug everything back in in reverse order and see if it works. If not it is bad.
Jan 18, 2010 | HP PSC 1610 All-In-One InkJet Printer
I keep getting a scanner failure error
Let's try this. Turn power off, unplug the cord from the surge strip or wall socket. Leave unplugged for about 30 minutes, then plug back in and turn on. Hopefully this will fix your problem. Good luck.
Mar 19, 2009 | HP OfficeJet 7130 All-In-One Printer
HP Officejet 6310 scans once but then says scanner failure
hi,
that error message is nothing to do with the software part, it actaully hardware issue try the following,
1) unplug the machine and connect it to wall outlet directly,
2) unplug the power cord from the printer and press and hold ON for 1 min and release the ON button and plug it back..
3) Disconnect the power cord from the product.Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons and if printer turns off, turn it back ON and wait until it cmopletes its instialization and if still persists, it a hardware failure...............
regards,  raj_p5983
Jan 19, 2009 | HP Officejet 6310 All-In-One InkJet...
Printer error
Just had this problem myself on my HP PSC 1610 All in one. After some fiddling, I found out that the power connector in the back was not fully inserted and must have slid out a little over time and with movement. After pushing it the whole way in, it started up fine and didn't give the error.
To make sure that was in fact the problem, I pulled the connector out slightly and started it up to find it gave me the error again. Then pushed it in the whole way, and it started up fine with no error.
Hopefully this works for others as well.
Aug 06, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
Scanner Failure
this is very common problem many users of this type of printer are getting the same problem.final solution for this problem is change the scanner unit.it will cost you between 50$ to 60$ exact. rate this solution as fixya and give respect to our technical experince that saved your precious time.thank u for using fixya.
Jun 14, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Error code: 0xc52004 411:lib_micci2.0
This is your solution: s.gif s.gif
Issue The product displays an 0x ... error code when printing (for example Error: 0xf0af8004 ). These error codes indicate that the product has an internal condition. Solution Use the instructions below to resolve the issue by restarting the product.
  1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
  2. Open the cover of the product and remove the print cartridges.
  3. Close the cover and wait for the Insert Ink Cartridges message to display.
  4. Disconnect the power cord from the back of the product and wait for one minute.
  5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
  6. Open the cover and reinsert the print cartridges.
  7. Close the cover. If prompted, print a calibration page.
  8. Reconnect the USB cable, and try to print a print job from the computer.
If these steps did not resolve the issue, contact HP technical support for assistance.
May 29, 2008 | HP PSC 1610 All-In-One Printer, Scanner...
Our scanner wont work the printer and copier work fine
You should be able to find a white sticker on the bottom of the printer. The serial number will be there as well. If you have the PCS 1610 than follow the uninstall instructions given by Hp at this link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265838&cc=us&lc=en&dlc=en&product=390315&dlc=en&lang=en
Than go to the link below and download & install the 1610 software: HP Full Feature software/driver: No Network Support &
HP Image Zone/Photo and Imaging Unexpected Internal Error and Communications Failure Patch
That should fix your troubles. Look at the fixes while at Hp and if you feel you need other upgrades now would be a good time to download.
Dec 29, 2007 | HP PSC 1610 All-In-One InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
237 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
